Showcase your setups
18911131424
  • scubalab
    scubalab Posts: 3,105
    Scuba, those pads isolate that TT pretty well? I know they do mine.
    And did they finally air out....lol.
    LOL - yes, they did finally air out! I didn’t notice a huge difference, but they did help isolate the TT a little. The visible movement of the drivers is all but gone. They isolated the Audio Technical TT better than the Rega or the MCS. Good thing too since that’s the table that’s staying.
  • lightman1
    lightman1 Posts: 10,797
    ^^^Sweet! Gotta get back over there for some listening time. Rock on Victor!
  • halo
    halo Posts: 5,616
    lightman1 wrote: »
    You bet Russ!!
    DSkip wrote: »
    halo wrote: »
    1. Spikes.
    2. Toe them in.
    3. Grills off when listening.
    4. At some points I've also tried elevating the rear more than the front. Play with that and see if it improves.
    Thanks for the tips Skip!
    Can’t do spikes on the composite flooring and still be able to move them around. I’ll think about the spikes when I get them placed optimally.
    They are toed in. lol. I need to toe in the right a little more. Where do you recommend the tweeter placement? Directly at the ears? ? # of inches outside the ears? I have to buy a longer power cable so I can move the whole rack, and speakers, to the left.
    Ok on the grills off. :)
    I can try elevating the rear :)
  • halo
    halo Posts: 5,616
    DSkip wrote: »
    I liked them about 6" off axis from my ears. I also liked them more when my ears were level with the woofer.
    My ears sit a bit higher than most people when listening. I’m 6’ 3” and sit kinda high up in the wheelchair compared to an able bodied person sitting lower in a recliner or on a couch. ;)
    I will keep adjusting as best I can to get great results.
    These speakers look fantastic. The finish is smooth as glass. They had some smudges and spots on them when they got here but I used Über rinseless car wash, mixed with distilled water, applied with a Chemical Guys microfiber towel.
    Wondering if any of the past owners put a coat of auto wax on these? @vcwatkins @kharp1 Perhaps the original owner Craig got them from on eBay?
    I talked to Dave @daboyz and he just used a damp cloth.
  • kharp1
    kharp1 Posts: 3,453
    No. I never used anything other than a damp microfiber cloth. I did use a piece of gym floor mat as cushion for a 25lb hexagonal dumbbell placed on top of the speakers. I did this to determine if I wanted to order shot for the fill pockets. I did notice improvement by adding weight.
  • halo
    halo Posts: 5,616
    kharp1 wrote: »
    Thanks Kerry :)
  • Joey_V
    Joey_V Posts: 8,603
    Skip
    Are these the same as what I heard at your old place?
    audioluvr Posts: 5,975
    Kinda hokey compared to to others here but great ambiance.
  • Joey_V
    Joey_V Posts: 8,603
    DSkip wrote: »
    Joey_V wrote: »
    Skip
    I don't remember you hearing a pair of 6311, but these are the same ones I owned. You heard the Mini X.
    I heard those if you had them. I recall comparing them to the minix
  • marvda1
    marvda1 Posts: 4,954
    Joey_V wrote: »
    DSkip wrote: »
    Joey_V wrote: »
    Skip
    you heard the usher 6381's along with the mini dancer 2 at my house.
    Puritan PSM156
  • joecoulson
    joecoulson Posts: 4,943
    audioluvr wrote: »
    That an HD radio tuner in that rack?
  • vcwatkins
    vcwatkins Posts: 1,992
    halo wrote: »
    DSkip wrote: »
    I bought them used in South Carolina. Don't think the original owner did anything. I generally use a dry microfiber cloth. It's possible I used a bit of the Gibson guitar polish; not certain.
    My preferred placement was a bit wider than usual (probably close to an equilateral triangle) and toed in to a few degrees outside of direct line (a few feet behind listener's noggin). I did not try adjusting up/down and never got around to adding weight.
    Nice rig, enjoy!
  • halo
    halo Posts: 5,616
    vcwatkins wrote: »
    Nice rig, enjoy!
    I read through the thread when you bought them from the original owner on eBay with local pickup. Heck of a deal you got on these many moons ago :)
    la2vegas wrote: »
    That's a wonderful product, especially on the piano black found on the LSI lineup. m543ukmroi00.jpg
    Thanks for the heads up!
  • jonicont
    jonicont Posts: 281
    DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
  • motorhead43026
    motorhead43026 Posts: 4,017
    edited October 2018
    Some of you guys take this shet way to serious.
    Some really nice rooms as well as setups.
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
    nooshinjohn Posts: 25,955
    @jonicont.... sorry, but I have to ask... who in their right mind hangs a cutout of a Mustang II on their wall? :p;)
  • jonicont
    jonicont Posts: 281
    😄😄😄😄 good eye! From a great song about racing called Daddy's Cup
    https://m.youtube.com/watch?v=McW2NwWtR9E
  • jonicont
    jonicont Posts: 281
    Custom piece from an artist named Ben Lamb. He does a lot of Rock and movie themed pieces. Also happens to be the bass player for Lydia Loveless. https://www.etsy.com/shop/3rdShiftDesigner/items
    That's the songwriter sitting in the car. It's 3 dimensional
    mhardy6647 Posts: 35,149
    edited October 2018
    EDIT: oops.
    Irrelevant, immaterial, inadmissible.
    (well, it was redundant, at any rate)
    :p
    sorry!
  • Joey_V
    Joey_V Posts: 8,603
    marvda1 wrote: »
    Joey_V wrote: »
    DSkip wrote: »
    Joey_V wrote: »
    Skip
    That’s right
    Viking64 Posts: 7,591
    EDIT: oops.
    :p
    sorry!
    Alright now you have piqued, peeked, and peaked my interest. It's not too, to, or two late to retype your, you're, and yore comment. There, their, they're is still time, thyme. Although the parsley, sage, and rosemary is in a different thread.
    Clipdat Posts: 13,098
    jonicont wrote: »
    15'x18' room
    What's driving the Focal bookies?
  • jonicont
    jonicont Posts: 281
    edited October 2018
    Clipdat wrote: »
    jonicont wrote: »
    15'x18' room
    some Yamaha av receiver. 100w/ch IIRC. going on 18 years. used it in the kids playroom
    pitdogg2 Posts: 27,168
    edited October 2018
    jonicont wrote: »
    and it's a Cobra......
  • motorhead43026
    edited October 2018
    ^^Mustang II Cobra, a sheep in wolves clothing.
    The drawing is still kind of cool with the 3 dimensional look.
  • Joey_V
    Joey_V Posts: 8,603
    edited November 2018
    A little late to the party.
    Here’s our family room set up. Sonus Faber Olympica 3. Wife chose the Rotel Ra1592 integrated because of ease of use.
  • Willow
    Willow Posts: 11,242
    Joey_V wrote: »
    Dad, this sticker will look great on the side of those speakers.
  • Joey_V
    Joey_V Posts: 8,603
    Lol
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    This is loosely what mine looks like minus the Bose 301’s and picture Pink Floyd and movie soundtracks on the wall... and a few different electronics
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
