Show me your TT's !!!
  • Not sure what you mean by "not as purty as most", before I even read your comment I thought to myself "Wow, what a gorgeous table!".
    StevieB wrote: »
    My Traveler with a Denon 103R is not as purty as most but sounds very good and hopefully one day I hope to move up the VPI ladder. Also have an old Dual 505-2 and an 80's Technics linear tracker.
    edited February 2018
    In fact, on the strength of that photograph, I'd have to say that it's an Epic record player.
    Thank you, thank you, thank you. It took me all the way 'til now to come up with that.
  • On a scale of 1-10, how stoned are you right now?
  • I am hypercaffeinated, in point of fact.
  • At nearly 6pm? You must've got a late start.
  • No worries folks, Doc will be here all night.
  • Clipdat wrote: »
  • Nesmith98 wrote: »
    see? :)
    32547188461_abe8ed978c_b.jpgDSC_6964 (2) by Mark Hardy, on Flickr
    There is a GA-212 downstairs... someplace...
    I have a Philips 977 similar to that one. I think i got it at Goodwill for less than $10.00.
    The 977 is several notches up from the 777 shown before. Interestingly, in the initial lineup of those tts, the 877 was the top. The 977, with the digital display of platter speed (vs. just an LED "graph") came along subsequently.
  • halo wrote: »
    Technics SL-Q3 w/ Shure M95ED
    Bottlehead Reduction Phono pre with Integration upgrade (Amperex white PQ 6922 tubes) & Mahogany base
    Is that the "definitive version" of Fragile that just came out? One of my favorite albums ever and the new version is packaged perfectly and sounds great.
    Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra
  • afterburnt wrote: »
    Nice! What is that? Looks like you could play a 6ft diameter record on that thing!
    And some tether ball!
  • Clipdat wrote: »
    I've never used a record clamp/weight of any kind.
    I think they work to better the sound. I have experience with them.
    Now if you listen to heavy metal, there's no use, I don't think.
    Maybe I'm wrong.
    Will a heavy metal or heavy rock fan tell me if the clamps or weights make the music sound better?
  • Clamps no doubt help vinyl playback. On the rare occasion I'll spin a record it's part of the routine I go through; brush the record, clean the stylus and clamp the record. If you use a loudness button or a sub at a fairly loud volume I've found that spiking the subs and speakers is very important to keep the feedback away from the needle.
  • This looks minty. No cartridge. Deal?
  • Another pic.
    The problem is that cartridge choices are very limited.
    That's why it's forty smackers.
    I paid $7 for my TX-2 (as mentioned earlier) with a broken stylus... so I'd say $40 was a tad steep. Not outrageous by any means, but I couldn't see paying much more for a swingin' arm b&o like that one (looks like an RX-2?).
    It may well need a belt -- belts are available for it (someplace).
    Here're your cartridge opportunities:
    https://www.sound-smith.com/bo-cartridges
  • mhardy6647 wrote: »
    Yep. Haven't even hooked my Micro-Seiki yet! Help pull me out of the rabbit hole!
  • Pretty sure it's an RX-2 (borrowed image).
    Here're your cartridge options:
    https://www.sound-smith.com/lookup/bo-cartridges/108
    Enabler! :smiley: Thanks!
  • verb wrote: »
    afterburnt wrote: »
    That tt, by the way, is a Fairchild 750. One of the finest turntables made. Ever.
    And you can hang your clothes to dry as well...
    verb wrote: »
    afterburnt wrote: »
    I see why they call Doc. As in PHD, I presume. So what's up with that tonearm? It seems like it would be very hard to control dynamically. Counterweight seems insufficient. Is that for real?
  • Yes, a PhD -- otherwise I'd own nicer hifi stuff ;)
    It's probably real -- tracking error would be (could be) quite low.
    The sufficiency of the counterweight depends on its mass. I am guessing the whole arm/cartridge system is appropriate for a low compliance MC cartridge.
    http://twogoodears.blogspot.com/2017/02/analog-machism.html
  • You are an encyclopedia! Impressive. BTW BS Aero, MS Mech :smiley: yes you're credentials are longer than mine!
  • Whoa that looks cool!
  • A unique concept. Making a comeback?
  • verb wrote: »
    afterburnt wrote: »
    jk, that's for polo not music
  • nbrowser wrote: »
    This is cool and kinda looks like a turntable...I'd rock it!
    Circa mid 1970s
    On heavy rock, where there is some actual talent involved, ring clamps and center weights do make a difference.
    Nothing helps KISS sound good, but they are fun to listen to anyway. :p
  • Every time I see this thread title my mind adds an ‘i’ into it. And I am disappointed every time. :)
