Show me your TT's !!!
Not sure what you mean by "not as purty as most", before I even read your comment I thought to myself "Wow, what a gorgeous table!".My Traveler with a Denon 103R is not as purty as most but sounds very good and hopefully one day I hope to move up the VPI ladder. Also have an old Dual 505-2 and an 80's Technics linear tracker.
In fact, on the strength of that photograph, I'd have to say that it's an Epic record player.
Thank you, thank you, thank you. It took me all the way 'til now to come up with that.
On a scale of 1-10, how stoned are you right now?mhardy6647 wrote: »In fact, on the strength of that photograph, I'd have to say that it's an Epic record player.
I am hypercaffeinated, in point of fact.
At nearly 6pm? You must've got a late start.mhardy6647 wrote: »I am hypercaffeinated, in point of fact.
No worries folks, Doc will be here all night.
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I have a Philips 977 similar to that one. I think i got it at Goodwill for less than $10.00.
The 977 is several notches up from the 777 shown before. Interestingly, in the initial lineup of those tts, the 877 was the top. The 977, with the digital display of platter speed (vs. just an LED "graph") came along subsequently.
Technics SL-Q3 w/ Shure M95ED
Bottlehead Reduction Phono pre with Integration upgrade (Amperex white PQ 6922 tubes) & Mahogany base
Is that the "definitive version" of Fragile that just came out? One of my favorite albums ever and the new version is packaged perfectly and sounds great.
Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra -
afterburnt wrote: »
Nice! What is that? Looks like you could play a 6ft diameter record on that thing!
And some tether ball!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I've never used a record clamp/weight of any kind.
I think they work to better the sound. I have experience with them.
Now if you listen to heavy metal, there's no use, I don't think.
Maybe I'm wrong.
Will a heavy metal or heavy rock fan tell me if the clamps or weights make the music sound better?Most people just listen to music and watch movies. I EXPERIENCE them.
Clamps no doubt help vinyl playback. On the rare occasion I'll spin a record it's part of the routine I go through; brush the record, clean the stylus and clamp the record. If you use a loudness button or a sub at a fairly loud volume I've found that spiking the subs and speakers is very important to keep the feedback away from the needle.
This looks minty. No cartridge. Deal?
Another pic.
The problem is that cartridge choices are very limited.
That's why it's forty smackers.
I paid $7 for my TX-2 (as mentioned earlier) with a broken stylus... so I'd say $40 was a tad steep. Not outrageous by any means, but I couldn't see paying much more for a swingin' arm b&o like that one (looks like an RX-2?).
It may well need a belt -- belts are available for it (someplace).
Here're your cartridge opportunities:
https://www.sound-smith.com/bo-cartridges -
mhardy6647 wrote: »The problem is that cartridge choices are very limited.
Yep. Haven't even hooked my Micro-Seiki yet! Help pull me out of the rabbit hole!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Pretty sure it's an RX-2 (borrowed image).
Here're your cartridge options:
https://www.sound-smith.com/lookup/bo-cartridges/108
mhardy6647 wrote: »Pretty sure it's an RX-2 (borrowed image).
Enabler!
Thanks! Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
afterburnt wrote: »
That tt, by the way, is a Fairchild 750. One of the finest turntables made. Ever.
afterburnt wrote: »
And you can hang your clothes to dry as well... -
mhardy6647 wrote: »afterburnt wrote: »
I see why they call Doc. As in PHD, I presume. So what's up with that tonearm? It seems like it would be very hard to control dynamically. Counterweight seems insufficient. Is that for real?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Yes, a PhD -- otherwise I'd own nicer hifi stuff
It's probably real -- tracking error would be (could be) quite low.
The sufficiency of the counterweight depends on its mass. I am guessing the whole arm/cartridge system is appropriate for a low compliance MC cartridge.
http://twogoodears.blogspot.com/2017/02/analog-machism.html -
You are an encyclopedia! Impressive. BTW BS Aero, MS Mech
yes you're credentials are longer than mine! Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Whoa that looks cool!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
A unique concept. Making a comeback?
afterburnt wrote: »
jk, that's for polo not music -
On heavy rock, where there is some actual talent involved, ring clamps and center weights do make a difference.motorstereo wrote: »Clamps no doubt help vinyl playback. On the rare occasion I'll spin a record it's part of the routine I go through; brush the record, clean the stylus and clamp the record. If you use a loudness button or a sub at a fairly loud volume I've found that spiking the subs and speakers is very important to keep the feedback away from the needle.
Nothing helps KISS sound good, but they are fun to listen to anyway.
Every time I see this thread title my mind adds an ‘i’ into it. And I am disappointed every time.
