Show me your TT's !!!
1457910
  • ClipdatClipdat Posts: 9,507
    Not sure what you mean by "not as purty as most", before I even read your comment I thought to myself "Wow, what a gorgeous table!".
    StevieB wrote: »
    My Traveler with a Denon 103R is not as purty as most but sounds very good and hopefully one day I hope to move up the VPI ladder. Also have an old Dual 505-2 and an 80's Technics linear tracker.
  • mhardy6647mhardy6647 Posts: 27,362
    edited February 2018
    In fact, on the strength of that photograph, I'd have to say that it's an Epic record player.
    Thank you, thank you, thank you. It took me all the way 'til now to come up with that.
    On a scale of 1-10, how stoned are you right now?
    I am hypercaffeinated, in point of fact.
    At nearly 6pm? You must've got a late start.
  • FestYboyFestYboy Posts: 3,860
    No worries folks, Doc will be here all night.
  • verbverb Posts: 10,313
    Clipdat wrote: »
    Basement: Polk SDA SRS, Cary SLP-05 Pre with ultimate upgrade,Enlightened Audio Designs CD Transport, Northstar Designs Excelsio DAC, Cambridge 851N streamer, Marantz SA-14 SACD, McIntosh MC300 Amp, Silnote Morpheus Ref2 Digital Cables, Furman 15PFi Power Conditioner, Pangea Power Cables, Wireworld Oasis 8 RCA IC's, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC, EAR Acute CD Player, EAR 834L Pre, Northstar Designs Intenso DAC, PASS ACA Monoblocks, Denon UDR-F10 Cassette, Acoustic Technologies Classic FR Speakers, SVS SB12 Plus sub, MIT AVt2 speaker cables, IFI Purifier2, AQ Cinnamon USB cable, Groneberg Quatro Reference IC's
    Spare Room: Antique Sound Labs Wave AV-8 Monoblocks, Tisbury Mini Passive Pre, Tjoeb 99 tube CD player (modified Marantz CD-38), Analysis Plus Oval 9's, Zu Jumpers, AudioEngine B1 Streamer, Klipsch RB-61 v2, SVS PB1000 sub, Blue Jeans RCA IC's, Shunyata Hydra 8 Power Conditioner
    Garage: Cambridge Audio 640A Integrated Amp, Project Box-E BT Streamer, Polk Tsi200 Bookies, Douglas Speaker Cables, Shunyata Power Conditioner
    Nesmith98 wrote: »
    see? :)
    32547188461_abe8ed978c_b.jpgDSC_6964 (2) by Mark Hardy, on Flickr
    There is a GA-212 downstairs... someplace...
    I have a Philips 977 similar to that one. I think i got it at Goodwill for less than $10.00.
    The 977 is several notches up from the 777 shown before. Interestingly, in the initial lineup of those tts, the 877 was the top. The 977, with the digital display of platter speed (vs. just an LED "graph") came along subsequently.
  • dr1978dr1978 Posts: 358
    halo wrote: »
    Technics SL-Q3 w/ Shure M95ED
    Bottlehead Reduction Phono pre with Integration upgrade (Amperex white PQ 6922 tubes) & Mahogany base
    Is that the "definitive version" of Fragile that just came out? One of my favorite albums ever and the new version is packaged perfectly and sounds great.
    Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, B&K Ref 2220, AMC 2100, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra
  • afterburntafterburnt Posts: 8,026
    rpf65 wrote: »
    I’m thinking you’ve reached the point where people are afraid to open your posts.
    I disabled, I am the South Carolina woman who gouged her eyes out on meth.
    afterburnt wrote: »
    Nice! What is that? Looks like you could play a 6ft diameter record on that thing!
    And some tether ball!
  • Tony MTony M Posts: 9,838
    Clipdat wrote: »
    I've never used a record clamp/weight of any kind.
    I think they work to better the sound. I have experience with them.
    Now if you listen to heavy metal, there's no use, I don't think.
    Maybe I'm wrong.
    Will a heavy metal or heavy rock fan tell me if the clamps or weights make the music sound better?
  • motorstereomotorstereo Posts: 1,596
    Clamps no doubt help vinyl playback. On the rare occasion I'll spin a record it's part of the routine I go through; brush the record, clean the stylus and clamp the record. If you use a loudness button or a sub at a fairly loud volume I've found that spiking the subs and speakers is very important to keep the feedback away from the needle.
    This looks minty. No cartridge. Deal?
    Another pic.
    The problem is that cartridge choices are very limited.
    That's why it's forty smackers.
    I paid $7 for my TX-2 (as mentioned earlier) with a broken stylus... so I'd say $40 was a tad steep. Not outrageous by any means, but I couldn't see paying much more for a swingin' arm b&o like that one (looks like an RX-2?).
    It may well need a belt -- belts are available for it (someplace).
    Here're your cartridge opportunities:
    https://www.sound-smith.com/bo-cartridges
    Yep. Haven't even hooked my Micro-Seiki yet! Help pull me out of the rabbit hole!
    Pretty sure it's an RX-2 (borrowed image).
    Here're your cartridge options:
    https://www.sound-smith.com/lookup/bo-cartridges/108
    Enabler! :smiley: Thanks!
    verb wrote: »
    afterburnt wrote: »
    That tt, by the way, is a Fairchild 750. One of the finest turntables made. Ever.
  • ken brydsonken brydson Posts: 8,123
    afterburnt wrote: »
    And you can hang your clothes to dry as well...
    verb wrote: »
    afterburnt wrote: »
    I see why they call Doc. As in PHD, I presume. So what's up with that tonearm? It seems like it would be very hard to control dynamically. Counterweight seems insufficient. Is that for real?
    Yes, a PhD -- otherwise I'd own nicer hifi stuff ;)
    It's probably real -- tracking error would be (could be) quite low.
    The sufficiency of the counterweight depends on its mass. I am guessing the whole arm/cartridge system is appropriate for a low compliance MC cartridge.
    http://twogoodears.blogspot.com/2017/02/analog-machism.html
    You are an encyclopedia! Impressive. BTW BS Aero, MS Mech :smiley: yes you're credentials are longer than mine!
    Whoa that looks cool!
    A unique concept. Making a comeback?
    verb wrote: »
    afterburnt wrote: »
    jk, that's for polo not music
    rpf65 wrote: »
    nbrowser wrote: »
    This is cool and kinda looks like a turntable...I'd rock it!
    Circa mid 1970s
  • nooshinjohnnooshinjohn Posts: 23,239
    On heavy rock, where there is some actual talent involved, ring clamps and center weights do make a difference.
    Nothing helps KISS sound good, but they are fun to listen to anyway. :p
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with Pass Labs Xono Phono Preamp, Walker Precision Motor Drive, ClearAudio Goldfinger Statement V2 cartridge and Origin Conqueror Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X0.2 three chassis preamp, PS Audio PerfectWave DAC MkII, Pioneer Elite SC-LX701, Oppo UDP-205 4K Blu-ray player, Sony XBR70x850B 4k, Polk audio AB800 "in-wall" surrounds.
    “Every record has been destroyed or falsified, every book has been rewritten, every picture has been repainted, every statue and street building has been renamed, every date has been altered…History has stopped. Nothing exists except the endless present in which the party is always right” — George Orwell
    “If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
  • BlueFoxBlueFox Posts: 14,367
    Every time I see this thread title my mind adds an ‘i’ into it. And I am disappointed every time. :)
    Lumin X1 file player
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
Howdy, Stranger!
