Equipment Racks
1356718
    Clipdat Posts: 13,100
    I hesitate doing too many room treatments since it's a rental, but I might post up a pic or two and see what people suggest. Even though it'll be embarrassing how lame my speakers have to be positioned.
    I think the room might actually be slightly overdamped currently, but that's just my uneducated opinion.
    And yeah maybe if I get a VTI rack I'll notice an aural improvement straight away with no other tweaks...?!
    DSkip wrote: »
    I don't think your system is far off if at all from showing those kinds of changes. The key is a solid cable foundation and treated room. It doesn't even have to be overblown, just focus on first reflections first.
    Those are the two areas that made subtle differences blow into big ones in my own system.
  • WLDock
    WLDock Posts: 3,073
    edited January 2018
    If one has some DIY skills, time, and patience can make something with the look and quality of some of a $1500-$3500 rack for much less. I ran across a craigslist listing that has a DIY rack in the picture. It reminds me of some other DIY racks that use brass hardware that emulate the Samason racks sold at the Mapleshape site: http://shop.mapleshadestore.com/Equipment-Racks/departments/16/
    Tons of ideas around the net, forums, pinterest, etc.
    Couldn't hurt to try!
    DSkip wrote: »
    Some panels and command strips can go a long ways.
  • BlueFox
    BlueFox Posts: 15,250
    edited January 2018
    Clipdat wrote: »
    It's possible Bud's system is just really THAT much more revealing, and thus the little things like isolation feet start to add up and make a difference.
    When I first realized the benefits of clean power, and vibration elimination, I was using Cambridge Audio pre and amps, Wadia iTransport for iPod, and a Bryston DAC. All this on a flimsy home entertainment center. I was amazed at the improvement every time I upgraded a power cable, conditioner, a brass footer. The gear I have now is based on that foundation.
    Also, at that time I was using a shared circuit that the whole left side of the house used.
    Post edited by BlueFox on
    EndersShadow Posts: 17,722
    WLDock wrote: »
    PM me that CL ad lol...
  • kharp1
    kharp1 Posts: 3,453
    DSkip wrote: »
    Clipdat wrote: »
    Thanks for the insight. You might have better ears than I do. I don't know if I'd be able to discern/detect a sound wave's vibration/impact on the equipment and the associated negative sound quality.
    BlueFox wrote: »
    The vibrations on the equipment rack, and on the equipment, come from the speaker sound waves hitting them. Gear is susceptible to the tiniest vibrations, and those vibrations alter the sound. That is why in addition to having a solid, vibration resistant rack, the gear should also be on some type of vibration draining footer. I use Mapleshade Micropoint Brass footers, but there are other vendors and types.
    Don't ever say that again please. You can hear a difference... everyone can. If your system was at his level those details can greatly alter the sound. You would be intimately familiar with the sound and pick up on it quickly.
    I'm not being mean but that type of thinking is deadly to growth in this hobby. It represents a closed mind in a way.
    You don't know what you don't know, as the saying goes. I had to take myself out of the mindset of "most of that stuff is bull, and, wouldn't matter on my meager system" and actually try some stuff id just ignored because it was easier than having to spend money on something that "probably won't make a difference anyway." I started room treatments with acoustic foam purchased from Walmart online and placed on the wall with painters tape. Easy, removable and enlightening.
    It's all about lowering the noise floor, which is something one doesn't notice until it is lowered.
    Spot on here. Most don't know they even have an abundance of it, until it's gone and the results are eye opening. Because most don't realize they even have noise, they fail to even pursue cures for it.
    Which, sometimes your better off being blinded, your wallet may appreciate that fact. :)
    Nice racks btw, wish someone could make a reasonable one though that doesn't cost used car kinda money and looks nice.
  • WLDock
    WLDock Posts: 3,073
    edited January 2018
    WLDock wrote: »
    Coming your way, its from CL South Bend.
    txcoastal1 Posts: 13,519
    FYI--Timber Nation will do custom work including just slabs. He would do slaps with pre-drilled holes if you wanted to do a DIY Maple Shades stand, just tell him what you want. He'll also put the custom stains.
    pricing and shipping is very reasonable. Chris Futrick is his name and really a nice guy
    If you go back to the LSAF threads (pics of my rooms) all the rack and amp stands were made by Timber Nation
  • WLDock
    WLDock Posts: 3,073
    Here's an expensive rack that I think is cool. I actually misses out a chance to purchase one of their entry racks for a couple of hundred. I like the vented banboo shelves.
    Quadraspire X Reference
    quadraspire.com
    https://www.needledoctor.com/Quadraspire-X-Reference-Audio-Rack
  • kharp1
    kharp1 Posts: 3,453
    txcoastal1 wrote: »
    Going to contact Mapleshade tomorrow and see if I can order the gold/brass nuts, washers and cap nuts. I kind of like that idea. Could probably drill them out myself with a good Forstner bit. I can handle the stain part as well. Been looking, off and on, past year or two for the hardware like Mapleshade uses, but, I haven't found it, or anything like it.
    Oh hell yes! Those vented bamboo shelves are perfect!
    WLDock wrote: »
  • jdjohn
    jdjohn Posts: 3,384
    I'll reel this back in a bit with Salamander Designs racks which are a little more budget-friendly, and still fully adjustable and customizable.
    https://www.salamanderdesigns.com/modular-open-stands/ I picked-up a used one on CL for storing bullpen components.
    For strictly turntable setup, I have one of these from Turntable Lab.
    https://www.turntablelab.com/collections/turntable-listening-packages-alpha/products/line-phono-turntable-station These are quite solid and heavy, especially once weighted-down with a couple hundred records. I can actually move records in-and-out of the shelves with a record playing without any skipping.
    Tony M Posts: 11,727
    edited January 2018
    I built speaker stands using the same interlocking slots as that bottom rack. My stands tilted the speakers backward a little bit. And there was no glue or nails or screws. They were super strong and rigid too. Everybody liked them. They were kind-of hobo artsy.
    And I could take them apart and lay em flat. I used 1/4" Birch plywood though. I might still have them but I doubt it.
    edited January 2018
    Nice. I remember when TTL first introduced that stand. Pretty nice piece, but a lot of people were complaining about the price and that it's MDF.
    I'm pretty much sold on this VTI BL404SC rack at this point, with an additional 7" shelf added. Seems like it's a decent combination of looks, performance, and low price.
  • machone
    machone Posts: 1,565
    I bought a VTI with glass shelving. Loved the look but the glass ringed so a cut 3/4" mdf shelving to put under the glass. Filled the posts with sand. All good now!
    http://forum.polkaudio.com/discussion/179843/new-rack#latest
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    edited February 2018
    Went with the VTI BL404SC I posted above. Seemed to be the best price to performance ratio, it also looks damn good, IMO. Thanks to @helipilotdoug for the deal. Anyone looking for a VTI rack should hit up Douglas Connection.
    Pretty excited that I'll have a proper equipment rack soon!
  • Joey_V
    Joey_V Posts: 8,603
    Nice choice w vti
    I have one. Someday when I have extra cash I’ll spring for a new rack, but the vti has been so dependable, you’d have to spend a lot more to get significant gains.
  • Clipdat wrote: »
    Thank you Drew :) Looks like your rack and extra shelf will be delivered tomorrow. Fun weekend ahead for you!
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • What do think of BDI? Are they quality pieces? I’m looking for something around 48 inches wide.
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
  • stangman67
    stangman67 Posts: 2,328
    The VTI BL503 is a great rack, Its 44" wide. I run one in my 2 channel setup
  • verb
    verb Posts: 10,176
    Am i imagining something, but was there a rack pic on this thread (hint-bikini clad)? Was it removed?
    Yep, @Rick88 posted up some jugs that he couldn't afford, but now it's gone. Nice.
    verb wrote: »
    stangman67 wrote: »
    Nice man, sweet, clean looking set-up. How's those Focals breaking in for ya ?
    audioluvr Posts: 5,987
    My bad. I posted the unedited version. Here's the racks I like best.
  • stangman67
    tonyb wrote: »
    stangman67 wrote: »
    Focals are sounding good. Mullards have been the best tube match so far as the top end is still strong on those speakers
  • soundfreak1
    soundfreak1 Posts: 3,414
    If she played her cards right......she could get lucky with me!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • muncybob
    muncybob Posts: 3,267
    That VTI BL503 is something we might consider. A reservation though would be how does it handle being bumped by a wife running a vacuum cleaner? Do the points sit into a dimple of some sort to help lock/stabilize the shelves?
    Yep, my name really is Bob.
  • marvda1
    marvda1 Posts: 4,963
    yes they do.
    Puritan PSM156
  • stangman67
    Yop the stand is extremely stable. You’d have to hit it with a truck to know one of the “shelving units off
