Show me your TT's !!!
It was on the old forum format before it switched over to vanilla, so I don't think it gets indexed in the search results.Cool. I must have searched hard enough ....
Great dust cover!VPI Prime with SoundSmith Zephyr MIMC Cart. Pre is a Parasound JC3. Dust cover is a StereoSquare. -
NICE!!!Most people just listen to music and watch movies. I EXPERIENCE them.
I asked for a cork TT mat for Xmas and got one....man, talk about static. Had to take it off and go back to the stock rubber mat. I hope in the humid summer I can try it again. Anybody else experience this with cork?Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
No, actually (and now that you mention it, and FWIW) -- and it's dry here in the wintertime.
I have a carbon fiber mat on my TriangleArt, and love it.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »I have a carbon fiber mat on my TriangleArt, and love it.
That should be antistatic.
I have a home brew mat that I like a lot, basically its composed of a very thin cork sheet (a few sheets of paper thick) glued and compressed onto a thin piece of leather, (unfinished side up), not too ugly and works like a charm. A bit finicky to make correctly but worth it.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Of course it's carbon fiber. Direct from NASA I presume ...:)Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
McLaren...
Here's one I mentioned and a few more pics I found of my Technics SL1400Mk2.
Nice !!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
My main table (Micro Seiki DQ-50):
Beautiful TT !!! I like what looks to be all metal tonearm assembly.
So I was reading some of the Japan market Micro Seiki's were designed for only 100v. Some run a AC converter. Have you had any issues? Is your's designed for 100v?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Saw the thread title and was just wondering if I can buy an "I" for a 50. Be worth it dontcha think.
Nice TT's gents, keep 'em rolling.HT SYSTEM-
lsi 9's -
I have a DD40, love it.
Although I do need to get it out and hooked up agay.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
On that note....Saw the thread title and was just wondering if I can buy an "I" for a 50. Be worth it dontcha think.
https://youtu.be/HgU_D1-onK0
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
Heavy plinth heavy platter Lenco idler drive. Maple wrap, Walnut corner accents. Has tachometer with speed control. Oversize aftermarket stainless bearing, tight tolerance (use light turbine oil). Linear air bearing arm.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »Heavy plinth heavy platter Lenco idler drive. Maple wrap, Walnut corner accents. Has tachometer with speed control. Oversize aftermarket stainless bearing, tight tolerance (use light turbine oil). Linear air bearing arm.
Whoa !!! That is impressive !!! Tachometer? OMG !!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
BEST vinyl setup I've ever heard. Period.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Just got an education on the speed control and tach. Really cool stuff ...
http://hifiheaven.net/shop/Phoenix-Engineering-RoadRunner-Tachometer-for-all-TurntablesBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Marantz TT-15S1 spinning in the dark
-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
Bill retired and shut it down. He was a smart guy, approached TT speed control like nobody had before.
Thanks for the kind words Victor!Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
That's an interesting question. The DQ-50 is kind of a rare bird; The Micro Seiki it looks identical to is the DD-8, which *is* a 100V motor, I believe.
Tonearm is some iteration of their vaunted MA-505. It doesn't have the "on the fly" VTA adjusting that some of the standalone MA-505s do, but I'm happy with it.
Anyway, mine's fine directly plugged into the wall, so no worries for me.Jay
SCompRacer wrote: »
Looks like you're running a thousandth of an RPM too fast Rich. Better give that TT to me.Jay
I love looking at turntables. I was a HUGE fan of linear tracking, and owned 2 different brands of linear tables. IIRC, Yamaha PX-3 and a Pioneer PL1000?? Both very smooth and very quiet turntables. Wish I still had the PX-3.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Me too, but my neck gets sore and I get a headache moving my head in circles after about an hour or so.
Here's one with a little 'bling'...
https://www.ebay.com/itm/TECHNICS-SL-1200GAE-EXTREMELY-LIMITED-EDITION-GOLD-TURNTABLE-EXCELLENT/292399233159?_trksid=p2485497.m4902.l9144
That table sold for 4000.00 new not too many years back. They were a limited run but WOW that is quite the premium he is looking for. -
Newest addition, Sony PS-X60 with Audio Technica AT20ss cart
Sota Sapphire with Jelco 750D tonearm and in this case, Benz Micro Wood L cartridge
