where to buy black paint?
Emotiva amps are already black.
rednedtugent wrote: »Emotiva amps are already black.
Deep, deep insight into the issue from this man. I stand in awe.
As time has passed, perhaps it should be noted that orange is the new black.
And Emotive amps are black not because they lack color, but because they are inclusive of all colors.Sal Palooza -
[Cliff Clavin]
As you may know, there are two color systems - additive and subtractive.
In additive color (light), the three primary colors are red, green, and blue. All of the colors together sum to white.
In subtractive color (paint), the three primary colors are yellow, cyan and magenta. All of the colors together sum to poo brown.
[/Cliff Clavin]
Does black paint really help for "wood"? Do you spray it on or use a brush? Will it make my "wood" bigger? :razz:
Deleted to avoid the ban involved.
You know, I just came to the realization that I am going to have to source some black paint to make this 2" throat Emilar horn look purty.
DSC_7249 (2) by Mark Hardy, on Flickr
Thank Heavens for this thread!
mhardy6647 wrote: »You know, I just came to the realization that I am going to have to source some black paint to make this 2" throat Emilar horn look purty.
WHAT?????????Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
I would go with a candy apple red on those...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »I would go with a candy apple red on those...
ooooh. Is that easier to source than black?
oooh, oooh, oooh! I found some!
An audiophile brand, too!
Better hurry, though -- it's on clearance!
https://www.parts-express.com/peavey-black-touch-up-paint-12-oz-spray-can--248-8810
Awesome find. And they provide life time tech support!!!! So if sound does not get better after painting you can call for help._________________________________________________
That's right, I forgot the tech support! It's a no-brainer purchase, isn't it?
You cannot but black paint any longer, only this:
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
You guys think this paint can also give me blacker blacks on my projector and TV's? Might give it a try...._________________________________________________
So black that you see into a paralell universe. -
black is the new -- umm -- black.
I used to think black wives mattered...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »I used to think black wives mattered...
You bad boy!!¡Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Could you imagine how many coats to cover those walls up when it was time for a change
Unless it was certain shades of yellow, deep red or orange? I could do it in one coat, no bleed through or drips spraying with a 413 tip.
Yes, I am a professional. Please do not attempt to try this at home.
@pitdogg2 can be thanked for reviving this thread (yet again)
Thought I blame myself for being curious...
On a more serious note, I HAVE had trouble finding a high quality, low reflectivity black paint. Been looking for a solution for my dash on my car. -
Better sunglasses2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »Better sunglasses
Doesn't help with the reflection on the clear gauge cluster cover. At high solar angles, the reflection from the base of the cluster hood (which is black) actually whites out the view of the gauges. -
I don't need no stinkin gauges......
^ wow, that's an awesome picture.
