where to buy black paint?
16791112
  • Emotiva amps are already black.
    mhardy6647 Posts: 28,205
    Deep, deep insight into the issue from this man. I stand in awe.
  • As time has passed, perhaps it should be noted that orange is the new black.
    And Emotive amps are black not because they lack color, but because they are inclusive of all colors.
    MrBigBlueLight
    Here to pick your brain & steal your cookies
    Shifting to Plan B+
    [Cliff Clavin]
    As you may know, there are two color systems - additive and subtractive.
    In additive color (light), the three primary colors are red, green, and blue. All of the colors together sum to white.
    In subtractive color (paint), the three primary colors are yellow, cyan and magenta. All of the colors together sum to poo brown.
    [/Cliff Clavin]
    MrBigBlueLight
    Shifting to Plan B+
  • littlewoodboats
    littlewoodboats Posts: 823
    edited March 2017
    hertz9753 wrote: »
    Does black paint really help for "wood"? Do you spray it on or use a brush? Will it make my "wood" bigger? :razz:
    Deleted to avoid the ban involved. o:)
    You know, I just came to the realization that I am going to have to source some black paint to make this 2" throat Emilar horn look purty.
    32368861594_12cb40a849_b.jpgDSC_7249 (2) by Mark Hardy, on Flickr
    Thank Heavens for this thread!
  • Moose68Bash
    Moose68Bash Posts: 3,806
    WHAT?????????
    Family Room, Innuos Statement streamer with Morrow Audios USB cable to DirectStream DAC w/Bridge II; AQ Sky XLRs, McIntosh MC 220 Tube Pre; AQ Sky XLRs, CAT 600.2 Dualmono Amp, Morrow SP7 Speaker Cables, SDA SRS 1.2tls (RD0198s, Dreadnought, Black Hole 5, Acousta-Stuf, Dynamat Extreme, JBWeld. Vr3 Mods: "The Abbot" Monastery-Level Xovers, Custom Internal Wiring, Binding Post Plates, & SDA ICs).
    Exercise Room, Wadia 171 iPod Dock, PS Audio PerfectWave Transport, Innuos Streamer with Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ Sky XLRs, Perreaux PMF3150 Amp, Dreadnought, Supra Rondo 4x2.5 Speaker Cables, SDA 1Cs (Vr3 Mods Xovers).
    Synology 713+ NAS on Gigabit LAN serving PW MkII DAC & DirectStream DAC.
    nooshinjohn Posts: 23,043
    edited March 2017
    I would go with a candy apple red on those...
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with Pass Labs Xono Phono Preamp, Walker Precision Motor Drive, ClearAudio Goldfinger Statement V2 cartridge and Origin Conqueror Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X0.2 three chassis preamp, PS Audio PerfectWave DAC MkII, Pioneer Elite SC-LX701, Oppo UDP-205 4K Blu-ray player, Sony XBR70x850B 4k, Polk audio AB800 "in-wall" surrounds.
    “Every record has been destroyed or falsified, every book has been rewritten, every picture has been repainted, every statue and street building has been renamed, every date has been altered…History has stopped. Nothing exists except the endless present in which the party is always right” — George Orwell
    “If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
    ooooh. Is that easier to source than black?
    oooh, oooh, oooh! I found some!
    An audiophile brand, too!
    Better hurry, though -- it's on clearance!
    https://www.parts-express.com/peavey-black-touch-up-paint-12-oz-spray-can--248-8810
  • Ricardo
    Ricardo Posts: 10,584
    Awesome find. And they provide life time tech support!!!! So if sound does not get better after painting you can call for help.
    SOPA
    That's right, I forgot the tech support! It's a no-brainer purchase, isn't it?
  • vmaxer
    vmaxer Posts: 4,882
    You cannot but black paint any longer, only this:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Ricardo
    You guys think this paint can also give me blacker blacks on my projector and TV's? Might give it a try....
    SOPA
  • lightman1
    lightman1 Posts: 10,673
    Ricardo wrote: »
    So black that you see into a paralell universe.
    black is the new -- umm -- black.
    I used to think black wives mattered...
  • vmaxer
    vmaxer Posts: 4,882
    You bad boy!!¡
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    treitz3 Posts: 14,665
    ~ I have found excellence ~
    ~ The best way to enjoy digital music reproduction is to never listen to good analogue reproduction ~
    txcoastal1 Posts: 11,887
    treitz3 wrote: »
    Could you imagine how many coats to cover those walls up when it was time for a change :#
    Unless it was certain shades of yellow, deep red or orange? I could do it in one coat, no bleed through or drips spraying with a 413 tip.
    Yes, I am a professional. Please do not attempt to try this at home.
  • FestYboy
    FestYboy Posts: 3,857
    @pitdogg2 can be thanked for reviving this thread (yet again) :wink:
    Thought I blame myself for being curious...
    On a more serious note, I HAVE had trouble finding a high quality, low reflectivity black paint. Been looking for a solution for my dash on my car.
    Better sunglasses
  • FestYboy
    txcoastal1 wrote: »
    Better sunglasses
    Doesn't help with the reflection on the clear gauge cluster cover. At high solar angles, the reflection from the base of the cluster hood (which is black) actually whites out the view of the gauges.
    pitdogg2 Posts: 19,470
    I don't need no stinkin gauges......
