where to buy black paint?
1…79111213
  • littlewoodboats
    littlewoodboats Posts: 823
    edited March 2017
    hertz9753 wrote: »
    Does black paint really help for "wood"? Do you spray it on or use a brush? Will it make my "wood" bigger? :razz:
    Deleted to avoid the ban involved. o:)
    mhardy6647 Posts: 35,562
    You know, I just came to the realization that I am going to have to source some black paint to make this 2" throat Emilar horn look purty.
    32368861594_12cb40a849_b.jpgDSC_7249 (2) by Mark Hardy, on Flickr
    Thank Heavens for this thread!
  • Moose68Bash
    Moose68Bash Posts: 3,843
    WHAT?????????
  • Unknown
    edited March 2017
    I would go with a candy apple red on those...
    ooooh. Is that easier to source than black?
    oooh, oooh, oooh! I found some!
    An audiophile brand, too!
    Better hurry, though -- it's on clearance!
    https://www.parts-express.com/peavey-black-touch-up-paint-12-oz-spray-can--248-8810
  • Ricardo
    Ricardo Posts: 10,634
    Awesome find. And they provide life time tech support!!!! So if sound does not get better after painting you can call for help.
    SOPA
    That's right, I forgot the tech support! It's a no-brainer purchase, isn't it?
  • vmaxer
    vmaxer Posts: 5,124
    You cannot but black paint any longer, only this:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Ricardo
    You guys think this paint can also give me blacker blacks on my projector and TV's? Might give it a try....
    SOPA
  • lightman1
    lightman1 Posts: 10,802
    Ricardo wrote: »
    So black that you see into a paralell universe.
    black is the new -- umm -- black.
  • vmaxer
    vmaxer Posts: 5,124
    I used to think black wives mattered...
    You bad boy!!¡
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    treitz3 Posts: 20,363
    txcoastal1 Posts: 13,520
    treitz3 wrote: »
    Could you imagine how many coats to cover those walls up when it was time for a change :#
    Unless it was certain shades of yellow, deep red or orange? I could do it in one coat, no bleed through or drips spraying with a 413 tip.
    Yes, I am a professional. Please do not attempt to try this at home.
  • FestYboy
    FestYboy Posts: 3,861
    @pitdogg2 can be thanked for reviving this thread (yet again) :wink:
    Thought I blame myself for being curious...
    On a more serious note, I HAVE had trouble finding a high quality, low reflectivity black paint. Been looking for a solution for my dash on my car.
    Better sunglasses
  • FestYboy
    txcoastal1 wrote: »
    Better sunglasses
    Doesn't help with the reflection on the clear gauge cluster cover. At high solar angles, the reflection from the base of the cluster hood (which is black) actually whites out the view of the gauges.
  • Unknown
  • FestYboy
    ^ wow, that's an awesome picture.
    F1nut Posts: 52,406
    That's not true black on her, it's got a purple tone. >:)
    F1nut Posts: 52,406
    I wonder if this poor soul knows what he's getting himself into?
    http://audiokarma.org/forums/index.php?threads/touch-up-paint-for-minimus-7s.803148/
  • xfactor
    Try "House Of Color". Best auto quality paint on the planet. They also have all the different colors and grades of the metal flakes to make it def. Expensive. $60 a quart and you need a good sprayer or pay a shop[to do it right. Check out ''Candy Brandywine over Gold Metalflake" Remember, If you go to Wallymart and buy cheap paint. It's always gonna look like cheap paint. No matter what you do.
    If it looks like a duck? Quacks like a duck? It's prolly a *#!^%$ Duck!!
    S.
  • mrbigbluelight
    What kind of duck though ? It makes a difference.
    Someone may want to have their paint job feathered in which case I'd recommend a goose (or geese for bigger jobs).
  • xfactor
    black duck
    S.
    rimshot.
    man -- I could see that one comin' from the Andromeda galaxy...
