Power Conditioner - Who's using one? Which one? Did it help your sound?
It's a lot less to do with power fluctuations, as long as they are within reason and more to do with noise. You don't know how much noise is on the line until some of it is removed and I think most that haven't addressed better power conditioning would be surprised by how much the noise floor can drop.Political Correctness'.........defined
President of Club Polk -
^^^^ on amps that you are thinking of.
But from what I've seen, general line noise is fairly easily taken care of.
My Furman has done a great job. Again, I think it depends a lot on how bad your power is.
If you have fluctuations and a lot of noise, you might have to drop some coin. But if you just have general line noise associated with residential power and little to no fluctuations, you can get away with something far more reasonable.
Again, depends on what you're starting with... -
It's not all about price either as to which is better. My low line PS Audio kicked the snot out of Monsters top of the line for eliminating noise.
Some just do a better job at their intended function than others. Much like some cdp's sound better than others, they all do the same thing though, right ? Obviously we aren't saying throw 3k worth of power conditioning/regeneration at a 1k system.HT SYSTEM-
lsi 9's -
IMO it's pretty much the same as with cables - try upgrading to see if it makes a difference in your system/room/house. It is a bit tougher to do with power because the good stuff seems to be pricey relative to other components and heavy, which restricts resale somewhat.
I was very surprised at the degree of improvement in sound quality going to PS Audio Dectets and a Richard Gray RGPC from Furman, APC, and Panamax units. I ordered a PSA P3 to try as well.b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Have the Panamax MR 4300, picked it up 1/2 off at BB. Wasn't expecting anything, except better surge protection than the old Monster power strip type surge protector. Think I had that one for about 10 years, can't even remember the model number.
Hard to tell where I heard a bigger difference, the Panamax or running the dedicated circuit. To me there was a big difference in everything in my HT system. Sound is clearer, and picture on the tv was even a little sharper.
Guess it's just the opposite from subwoofers. If you never heard a good sub, you don't know what you're missing. With dirty power, you won't know what you're hearing until it's cleaned up to some degree. -
I'd say power at my house is better than what I see many places. It's usually very steady. Never seen it dip below 117. Usually stays steady at 121, 122. That's the least of issues in the power grid. My gains were far from minimal.
Started years ago with Monster. Some improvement until I installed the dedicated lines and then comparing between straight to the wall and into the Monster, well the Monster found a new home. Had a chance to aquire the single outlet Audience aRp1 and ran it into a CryoParts 6 outlet box that actually improved the experience. I have since moved up the Audience line to the aR2p-TO for my VAC Renaissance and VAC amp with excellent results.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
I have said for a few years now that clean power and vibration control are the foundation of a good stereo. If your foundation is weak then no matter what gear you use the end result will be weak. Now get some decent power cords and be prepared to really be impressed.
Three 20 amp circuits. -
Nobody mentioned Running Springs , I know a few guys here own them. Tad on the expensive side but those who own one swear by them.HT SYSTEM-
lsi 9's -
Sounds like an Indian name...feathers not dots. I've never heard of them.
...a power conditioner and surge system, it's not designed to make your system sound better.
What it actually does is make (or allows) [your equipment] perform the way it was designed. Supplying clean, stable power, your devices all work correctly.
Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work -
Dan
I don't think otherwise Dan, your correct actually. However by everything running better, getting fed clean power, the side effect of that is what ? Your system sounding better....isn't it ? So while they are not designed to make your system sound better, the effect of what they are designed to do will.
The rules of cause and effect apply here. An amp is designed to store power and deliver current. The side effect of that is better dynamics making your system sound....better, right ?
Power conditioners/regenerators vary in this also. While they all do basically the same thing, which is what they are all designed to do anyway like you said, the manner of which they do it varies, the build quality varies, and thus the effects you will get on sound as the side effect will also vary. Make sense ?HT SYSTEM-
lsi 9's -
Hi there,
Please don't laugh at me for this...
I currently have my nice (to me) goodies plugged into basic mid grade surge protectors I got from Costco. SDG&E guy said that is all I need.
So should I toss one of the power conditioner on my upgrade list. If I do get one should I plug everything into (sub, AVR, TV and BD players)?
For power cords I can't see buying $100 power cord for a $500 receiver or sub. I've been using the one my equipment came with.
Try to take into consideration I am an IT Warehouse manager living in San Diego so funds are tight.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
If you like your stuff, get the best surge protection you can afford.
rednedtugent wrote: »If you like your stuff, get the best surge protection you can afford.
OK, I will look into it, more reading time. The surge protectors I have now are decent.
better than what I currently have?
http://www.bestbuy.com/site/panamax-8-outlet-power-conditioner-surge-protector-gray/9518284.p?skuId=9518284When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
How old is the panamax?
I went with this;
Furman PST-8D(igital)
A bit pricey but it is supposed to drop output power on overages and
sags. Some are let thru's. It's in use on the bedroom system...
Not for amps however.
@dskip may be able to chime in here.
I used pro grade Tripp lite before an thought they were just o.k. -
So I go to BestBuy and the dude there was telling me about how these work. he shows me this one a lot better than the one I was looking at.
https://www.amazon.com/Panamax-MR4000-Management-Protection-Conditioning/dp/B009MQTC52
He got the price down to $140 for me so I got it.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
What ever happened to the Richard Gray power plants? Those were the shiznit not too many tears ago.
Still around and still building work horses:http://www.richardgrayspowercompany.com/
They are under new ownership, but, I don't think it was a major change. They sold to a group they had partnered with. Can find some good deals on them on the used market. -
Try this
https://www.amazon.com/PS-Audio-Power-Port-Classic/dp/B001HRDMLE/ref=sr_1_1?ie=UTF8&qid=1487515658&sr=8-1&keywords=ps+audio+outlet
and that
https://www.amazon.com/Panamax-MR4300-Management-Protection-Conditioning/dp/B00ILH7KJI/ref=sr_1_1?ie=UTF8&qid=1487515712&sr=8-1&keywords=panamax+4300
I notice the biggest difference in powered monitors, if you plug a pair of Genelecs into the wall they just don't sound right, but connect them to a Panamax unit and they are different speakers. Same goes for amps and preamps.
This is another cool unit I like to use if a sub is located too far away from the rest of the equipment:
https://www.amazon.com/Panamax-MD2-Outlet-Direct-Surge/dp/B003GSLLCO/ref=sr_1_1?ie=UTF8&qid=1487515992&sr=8-1&keywords=panamax+md2
also great for powered monitors.
B&W CM9Classé Sigma -
Same goes with cables, they can not and will not make your system better, better then using cables that hurt your system for sure. They just don't have the ability to make things better then what you actually start out with IF everything is running properly. A cable can't make a speaker that doesn't have good bass response by design magically give it lower and deeper bass. But they can bring out everything that speaker can play by providing all the signal sent to it.
Thats all I'm trying to say.Dan
So I had to return the Panamax I picked up at BestBuy. Went to go put it in and the only place on my stand it would fit most of my power cords wont reach. bummer @ $140 it was a decent pickup.
I did wind up ordering the PM8-AV from Home Depot, used all gift cards for it.
Clearly you have not been here long enough.
When faced with that issue many of us on here would just throw up our arms and say, "GREAT! Now I have to upgrade all of my power cords!". Pretending to be upset about it in front of our wives.
You made a common rookie mistake. You'll get there!
Upstatemax wrote: »
Lol! So true!2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Upstatemax wrote: »So I had to return the Panamax I picked up at BestBuy. Went to go put it in and the only place on my stand it would fit most of my power cords wont reach. bummer @ $140 it was a decent pickup.
lurking for 11 years, not long
Once I got it home and started in on it I wound up with 2 choices
1 cut into my TV stand that took me 2 weeks to build
2 take it back.
Considering funds are a little tight right now I took option #2 and ordered the PM8-AV with gift cards I had for Home Depot. Power strip type will mount where the current one is. On the TV stand I built I left the center open so my CSI-5 can breath.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Actually, your rookie mistake was not coming on the forum and posting your dilemma before deciding what to do. There is so much life experience here that when you post a situation like yours you'll find that you get so much useful information, information like how to con your spouse, how to rearrange your house, creative financing, how to lie to yourself, how to use your kids to get more gear. The list extends much further, but, I think you get the picture. We will help you find ways to get the gear you've always dreamed of but thought you couldn't afford.
