Jesse was kind enough to help me find a place to take my cabinets for a quote to get them redone in a veneer, I take them in Saturday, and they are close to my house..
Fingers crossed..
id like to see that when there done. Id like to do mine in the near future
Let's all try and be excellent to each other always. JMO
Unfortunately for most of us we only get to experience the first day and then we can't even remember it.
"Close only counts in Horseshoes, Hand Grenades and Thermonuclear Weapons."
"50% Why... That's almost half."
"I know, I'm sick and need help."
---- Gimpod Custom 4th & 5th Gen SDA Circuit Boards
"The best way to enjoy digital music reproduction is to never listen to good analogue reproduction." ~ Kenneth Swauger
I think changing the bottom rail is a nice touch. I am planning on changing my CRS+ by deleting that rail and adding bottom and top caps like my 1Cs along with cloth sides too. Sort of a compact version of the 1C of you will.
Dennis, I look forward to seeing that. I take it you'll make a new grill as well?
Yes I will use the old one as a template to extend down to the bottom of the existing cabinet and cap off the top and bottom in good wood! I'm excited too as I can see it in my head!
I thought about doing something like that as well.. But I'm sticking with the plan I have now..
Looking forward to seeing the finished project good idea on the bottom rail.
Larry while I like your idea, Wonder what polished copper or a bronze would look like?
Worse
I didn't use a heat gun to apply, I just wrapped them in a warm room, and used an exacto knife to trim it in, used a combination square for the 45 degree cuts on the corners....
For less than a $100 I'm happy with them... Better than the $1500 I was quoted to have them veneered...
Randy/Maine .. SDA-CRS+TL-RTA15TL-Cs1000p
Keep in mind the speakers will be Black..
Also see the last paragraph in this post of mine on page 2
"SDA CRS+ With an External Crossover Twist.... :-)
Do it!!
This will give you a better idea on how it will look..
Wowsers.
Someone re-post that "I am slightly aroused" pic again.
SDA 2BTL * Musical Fidelity A5cr amp * Marantz DV-9500 * Modded Adcom GDA-600 DAC * Rythmik F8 (x2)
Micro Seiki DQ-50 * A hodgepodge of cabling * Belkin PF60
Village Idiot of Club Polk
Way to make a thread turn sexy to ugly...shame on you
Polk RT8
Polk Monitor 7s
Working on getting SDAs
Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
Interconnect: Furez 10/2 with SpeakONs
ICs: Custom Furez by Douglas Connections
Den:
Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
Carver CT-3 Pre, Carver C-500
dhsspeakerservice.com/
Worse
