Warm up time or is it my ears?
I feel compelled to comment, despite the fact that this thread has deteriorated into… well, let’s just say that it’s not a dispassionate, intellectual conversation.
Below are portions of a couple of posts by AudioCircle forum member Duke (listed as an industry professional). I think this may help explain why some speakers may sound different after warming up vs. when ‘cold’.
Cheers, Jim
The most well-known power compression type is long-term thermal compression, which is primarily a function of the magnet heating up over time and temporarily losing strength. If operated at 1/10th its rated power for a while, it's typical for a driver to lose about 1 dB to compression. At 1/2 its rated power this rises to about 2.5 dB ballpark, and then about 4 dB at full power. By "rated power", I mean its Audio Engineering Society protocol power rating, which is typically 1/2 its "music program" rating, which in turn is typically 1/2 its "peak power" rating.
A less well-known and well-documented phenomenon is "thermal modulation", which happens much more quickly, and which is primarily a function of rapid voice coil heating, which causes the voice coil's resistance to rise essentially instantaneously (the voice coil then cools down much more slowly as the heat is absorbed by the nearby motor structure and the air). Stereophile did an article on the subject some years ago and concluded that the effects of voice coil heating are negligible, but several experts in the field have come to different conclusions. One of them is Earl Geddes, who applied for a patent on an alloy for use as voice coil material that exhibited little or no rise in resistance with temperature. I believe a patent on a functionally similar alloy has been granted to JBL. And then not long ago I had an interesting conversation with Floyd Toole on the subject, and here is what he had to say:
"The audibility of power compression in its many variations probably could use some more research to define what is audible and what is tolerable. The magnet heating that you describe is important in pro audio sound reinforcement systems where the loudspeakers are required to work at or close to their design limits for long periods. Such heating and cooling has a very long time constant. This is not the case in most home systems. Although the modification of motor strength through magnet heating is a factor, most of the audible effects are from voice coil heating, which has a much shorter time constant. I just saw a test of a high-end audiophile speaker that in going from an average level of 70 dB (loud conversation, background music) to 90 dB (a moderate crescendo, or foreground rock listening) lost about 4 dB in output over about 3 octaves in the mid-high-frequency range. It became a different loudspeaker at different listening levels."
So one sonic downside of losing a few dB off of peaks due to thermal modulation from voice coil heating is, loss of emotional impact, because musicians use dynamic range to convey emotion. Another possible downside is, changing tonal balance with change in sound pressure level, as Toole describes above.
If you've ever heard a speaker that needs to be turned up to "come to life", you may have heard one of the consequences of dissimilar power compression characteristics among drivers. The "come to life" level may be where the relative loudness of the different drivers is correctly balanced, and at significantly higher or lower levels the tonal balance may be wrong. One advantage of high efficiency and/or high thermal capacity drivers is, their thermal characteristics are less likely to diverge at levels normally encountered in home audio, so their tonal balance stays the same across a wider range of volume levels. As a result, high efficiency speakers and high-thermal-capacity low to medium efficiency speakers usually still "come to life" at low volume levels.
As an example of this issue, suppose we were tasked with "voicing" the speaker Toole describes above. Let's say we wanted it to sound great at 90 dB so that it would impress people in a fairly loud demo. So we voice the speaker to be "flat" at 90 dB, where the midrange driver is compressing by 4 dB more than the woofer and tweeter. So down at 70 dB, the bass and treble would be 4 dB softer than the midrange, probably rendering the speaker boring and lifeless. At still lower levels, if anything the discrepancy would be even worse.
This points to an advantage of single-driver speakers - their tonal balance usually changes little as a result of thermal compression or thermal modulation (the short-time-constant effect Toole was talking about).
A day without music is like a day without food. -
Can't we all just get behind the following statement:
"It only matters how it sounds to you".....
And yes I realize its mainly the TROLLS that cant... but just saying..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
The bet. We set up two identical systems. We test them with a bias controlled comparison to ensure they sound the same. We allow one to warm up all day and the other one for 10 minutes. Then we repeat the bias controlled test. If you can identify a difference, you get $5000. If you can't, I get $5000.
I have never tested this concept before so I am applying common sense to the issue. I did do a bias controlled test of speaker "break-in" once. We compare a pair B&W Matrix 801 speakers a dealer had had on demo for about three months to a brand new pair he unboxed to deliver to a customer. None of the 5 testers was able to distinguish between the two pairs.
I'm betting $5000 warm up of electronic audio gear will go the same way. Do you know where we can find two identical systems in the same room that can be switched to play through the same speakers?
I do that with my system every time I listen. Unless roughly an hour of warm up is allowed, the system definitely sounds different at start up vs. powered up for an hour or so. That's when the most marked differences are heard. Give it 1/2 a day and there are improvements as well, just much less.
What you and your bias control aren't taking into account is that some pieces of gear need (because of the design) to "settle in" before they start sounding their best. It's a know fact tubes take time to "settle in" before they start to perform optimally. Singled ended Class A amplifiers need about an hour for everything to bias up before they sound their best. You can even see that on a distortion analyzer. So it appears your blanket statement is flawed.
Please crawl back under your rock with Hab Monk and Jinjuku.
Cheers
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
I know this won't appease the bias control gods. But here is a quote from the father of transistor amps and he has more credentials than fmw could ever hope to have. I highlighted the important part.
It takes about an hour of warm up time to get the best performance out of the amplifier [Aleph 30]. It will take that long to reach operating temperature and exhibit lowest distortion and noise. This is not a subjective judgment, but based on actual distortion and noise measurements. Many customers have reported that longer warm up yields more improvement.
Cheers
Yeah, maybe that's why the manufacturers of high performance solid state audio gear, including Pass, advise leaving their gear on 24/7.
On the other hand, this could be a vast conspiracy between high end audio manufacturers and the electric power industry to jack up our power bills.
Proud and loyal citizen of the Digital Domain and Solid State Country! -
Read Somewhere in my benchmark manual to let the dac warm up for a half hour, will try to find it , probably won't now that I told everyone. So got home today, girlfriends out, time to crank it. So guess what? Did it cold. Yes it sounds good. I enjoyed it. At almost exactly a half hour, the bass came alive, the highs smoothed right out... Everything sounds fuller. Sound stage opened right up. Greater depth. I'm a believer. I bet in 2 hours it will sound even better.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Cheers
He could be right. I don't know. Neither do you. What I do know is that not all measurable phenomena are audible. I also know that doing the comparison sighted won't answer that question. So look around to see if there is rock under which you can crawl. I'll wave to from my rock.
And does it not also make sense that not all audible phenomena is measurable? I have heard subtle changes and marked improvements in my modest 2ch rig just fromHe could be right. I don't know. Neither do you. What I do know is that not all measurable phenomena are audible. I also know that doing the comparison sighted won't answer that question. So look around to see if there is rock under which you can crawl. I'll wave to from my rock.
different cables (power, IC, etc.). Were they measurable? I dunno, I lack the equipment
to make such determinations... well, other than my ears, which I rely on pretty heavily
when I am listening for sound.
There really is no right, is there? Test for yourself and decide for yourself. Do all that and post your findings, you might just end up helping someone else in the process.
H9 has owned that Pass amp for as long as I can remember, so I am sure he is not just "drinking the Kool-Aid" when he asserts that warm-up time makes a difference.
http://audiomilitia.proboards.com/ -
And does it not also make sense that not all audible phenomena is measurable?He could be right. I don't know. Neither do you. What I do know is that not all measurable phenomena are audible. I also know that doing the comparison sighted won't answer that question. So look around to see if there is rock under which you can crawl. I'll wave to from my rock.
No, measurment instruments are far more sensitive than our hearing. If the audible difference isn't measurable, it will disappear in a bias controlled test every time.
I am curious as to what measuring instrument I should be using to determine that a guitar solo is originating approximately 3' to the left of my left channel? Or that the lead vocals are just to the right of dead center, but a little higher than the top of the speakers?
But since we are stuck on bias control testing, and not sitting in my den enjoying some excellent Steely Dan, never mind. You win.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
Stereo imaging is determined at the mixing console. Nobody is suggesting that you can't hear the imaging. My comment was that changing amplifiers won't change the imaging. Changing speakers or speaker placement, however, can do so. -
Psychoacoustics disagrees with you.
https://en.wikipedia.org/wiki/Psychoacoustics
But I am sure that you people will come up with some way to claim that it isn't a *real* science or some other inane **** like you always do.
Nothing in that article disagrees with me.
Nonsense. I'm very aware of how hearing bias causes people to process sounds differently. I haven't dismissed that at all. All I have said is some audible differences are in the equipment and some of it is in those differences in the way people process sounds. We all have hearing bias. It is human nature. I understand it very well having spent so much time testing it. Nothing in that article disagrees with what I say.
Once again, your ignorance and/or lack of experience on the matter comes shining through.
On another note, I see you're not very good at keeping your word, but I'm far from surprised.
President of Club Polk -
My lack of experience, huh? That made me chuckle. I came back because a member of this forum asked me to. He explained that you and a few others are the loud mouthed bullies that try to get people who dissent from your beliefs to leave. I honored the request. Now, would you like to debate what I said or are you just a loud mouthed bully? -
So, you let one of the forum trolls pull your string. I'm sure X is laughing his a$$ off at you right now.
There's nothing to debate. You are wrong, period.Political Correctness'.........defined
Guys I've said this many times and it does hold true for me. The instant I turn on my Adcom 555 and what ever source I hear absolutely no difference from start up or for hours running. Now for the tubers I get it they do need the time and here's a little story. I bought some speakers years ago from a dude in his Florida room. I said this is nice stuff,so what do you use for your personal use. He says I usually don't show my house but since your not a kid I'll give you a look. At 1st I almost bumped in these huge Albert Van Alstines I think the TOTL models. Then on the floor were 2 giant mono blocks (brand not known) and I asked if I could hear these things. He said no they need a GOOD HOUR TO GET TO PRIME LISTENING FULFILMENT. An hour kishmeirinkuchas, I need instant gratification which my Adcom gives me.....2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
My SS Pass Aleph 30 needs an hour or two to sound its best. I leave it on most of the time because of this. Totally agree with H9's comments above, and I'm not about to argue with the designer.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
So what guarantees can you post that you are unequivocally correct other than you and some others said it was so....
Not a debate just a question
Just to be clear, you are saying my NAD 2150 and a pair of Pass mono blocks will create the same soundstage, and only my sighted bias can tell the difference?Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Hmmm, so all you Polk bung holios lead me astray, caused my divorce, and emptied my pocket book looking for the path of audio righteousness when i could have bought a **** amp that would give me all the sound stage I needed for cheap...shame on all of you
afterburnt wrote: »
15 years ago I shot the Lake Front Bate House owner because he had a sign "Worms Guaranteed to Catch Fish" didn't catch anything....he wouldn't give me a refund
Damned sorry I opened this can of worms
Agreed... Just give me those offensive boat anchors Ron. I will send you a Crown XPS. Everybody knows they sound EXACTLY the same.txcoastal1 wrote: »
nooshinjohn wrote: »
HMMMM it is hot down here in the south, would make since.....LOL2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »Stereo imaging is determined at the mixing console. Nobody is suggesting that you can't hear the imaging. My comment was that changing amplifiers won't change the imaging. Changing speakers or speaker placement, however, can do so.
Nothing. It has no more guarantee than your posts or anybody else's. -
Yes. If an amplifier has an inaudible variance from a flat frequency response, there isn't any way for it to affect imaging. If it has audible variances then it could make content at those frequencies to vary subtly from amp to amp. However, if such an audible difference did occur, I would suggest that one of the amps is not well designed or defective. Almost all solid state amps these days have an audibly flat frequency response. I assume your amps have an audibly flat frequency response. Did you compare it one that did not? -
So, you do concede amplifier design can affect soundstaging?Polk Lsi9
Keces DA-131 mk.II
