Warm up time or is it my ears?
2456
  • I feel compelled to comment, despite the fact that this thread has deteriorated into… well, let’s just say that it’s not a dispassionate, intellectual conversation.
    Below are portions of a couple of posts by AudioCircle forum member Duke (listed as an industry professional). I think this may help explain why some speakers may sound different after warming up vs. when ‘cold’.
    Cheers, Jim
    The most well-known power compression type is long-term thermal compression, which is primarily a function of the magnet heating up over time and temporarily losing strength.   If operated at 1/10th its rated power for a while, it's typical for a driver to lose about 1 dB to compression.   At 1/2 its rated power this rises to about 2.5 dB ballpark, and then about 4 dB at full power.  By "rated power", I mean its Audio Engineering Society protocol power rating, which is typically 1/2 its "music program" rating, which in turn is typically 1/2 its "peak power" rating.
    A less well-known and well-documented phenomenon is "thermal modulation", which happens much more quickly, and which is primarily a function of rapid voice coil heating, which causes the voice coil's resistance to rise essentially instantaneously (the voice coil then cools down much more slowly as the heat is absorbed by the nearby motor structure and the air).   Stereophile did an article on the subject some years ago and concluded that the effects of voice coil heating are negligible, but several experts in the field have come to different conclusions.  One of them is Earl Geddes, who applied for a patent on an alloy for use as voice coil material that exhibited little or no rise in resistance with temperature.  I believe a patent on a functionally similar alloy has been granted to JBL.  And then not long ago I had an interesting conversation with Floyd Toole on the subject, and here is what he had to say:
    "The audibility of power compression in its many variations probably could use some more research to define what is audible and what is tolerable. The magnet heating that you describe is important in pro audio sound reinforcement systems where the loudspeakers are required to work at or close to their design limits for long periods. Such heating and cooling has a very long time constant. This is not the case in most home systems. Although the modification of motor strength through magnet heating is a factor, most of the audible effects are from voice coil heating, which has a much shorter time constant. I just saw a test of a high-end audiophile speaker that in going from an average level of 70 dB (loud conversation, background music) to 90 dB (a moderate crescendo, or foreground rock listening) lost about 4 dB in output over about 3 octaves in the mid-high-frequency range. It became a different loudspeaker at different listening levels."
    So one sonic downside of losing a few dB off of peaks due to thermal modulation from voice coil heating is, loss of emotional impact, because musicians use dynamic range to convey emotion.  Another possible downside is, changing tonal balance with change in sound pressure level, as Toole describes above.
    If you've ever heard a speaker that needs to be turned up to "come to life", you may have heard one of the consequences of dissimilar power compression characteristics among drivers.   The "come to life" level may be where the relative loudness of the different drivers is correctly balanced, and at significantly higher or lower levels the tonal balance may be wrong.  One advantage of high efficiency and/or high thermal capacity drivers is, their thermal characteristics are less likely to diverge at levels normally encountered in home audio, so their tonal balance stays the same across a wider range of volume levels.  As a result, high efficiency speakers and high-thermal-capacity low to medium efficiency speakers usually still "come to life" at low volume levels.
    As an example of this issue, suppose we were tasked with "voicing" the speaker Toole describes above.   Let's say we wanted it to sound great at 90 dB so that it would impress people in a fairly loud demo.  So we voice the speaker to be "flat" at 90 dB, where the midrange driver is compressing by 4 dB more than the woofer and tweeter.  So down at 70 dB, the bass and treble would be 4 dB softer than the midrange, probably rendering the speaker boring and lifeless.  At still lower levels, if anything the discrepancy would be even worse.
    This points to an advantage of single-driver speakers - their tonal balance usually changes little as a result of thermal compression or thermal modulation (the short-time-constant effect Toole was talking about).
    A day without music is like a day without food.
    EndersShadow Posts: 17,687
    edited November 2015
    Can't we all just get behind the following statement:
    "It only matters how it sounds to you".....
    And yes I realize its mainly the TROLLS that cant... but just saying...
    heiney9 Posts: 25,406
    fmw wrote: »
    The bet. We set up two identical systems. We test them with a bias controlled comparison to ensure they sound the same. We allow one to warm up all day and the other one for 10 minutes. Then we repeat the bias controlled test. If you can identify a difference, you get $5000. If you can't, I get $5000.
    I have never tested this concept before so I am applying common sense to the issue. I did do a bias controlled test of speaker "break-in" once. We compare a pair B&W Matrix 801 speakers a dealer had had on demo for about three months to a brand new pair he unboxed to deliver to a customer. None of the 5 testers was able to distinguish between the two pairs.
    I'm betting $5000 warm up of electronic audio gear will go the same way. Do you know where we can find two identical systems in the same room that can be switched to play through the same speakers?
    I do that with my system every time I listen. Unless roughly an hour of warm up is allowed, the system definitely sounds different at start up vs. powered up for an hour or so. That's when the most marked differences are heard. Give it 1/2 a day and there are improvements as well, just much less.
    What you and your bias control aren't taking into account is that some pieces of gear need (because of the design) to "settle in" before they start sounding their best. It's a know fact tubes take time to "settle in" before they start to perform optimally. Singled ended Class A amplifiers need about an hour for everything to bias up before they sound their best. You can even see that on a distortion analyzer. So it appears your blanket statement is flawed.
    Please crawl back under your rock with Hab Monk and Jinjuku.
    Cheers
    I know this won't appease the bias control gods. But here is a quote from the father of transistor amps and he has more credentials than fmw could ever hope to have. I highlighted the important part.
    It takes about an hour of warm up time to get the best performance out of the amplifier [Aleph 30]. It will take that long to reach operating temperature and exhibit lowest distortion and noise. This is not a subjective judgment, but based on actual distortion and noise measurements. Many customers have reported that longer warm up yields more improvement.
    Cheers
  • heiney9 wrote: »
    Yeah, maybe that's why the manufacturers of high performance solid state audio gear, including Pass, advise leaving their gear on 24/7.
    On the other hand, this could be a vast conspiracy between high end audio manufacturers and the electric power industry to jack up our power bills. >:)
  • mikeyb128
    mikeyb128 Posts: 2,885
    Read Somewhere in my benchmark manual to let the dac warm up for a half hour, will try to find it , probably won't now that I told everyone. So got home today, girlfriends out, time to crank it. So guess what? Did it cold. Yes it sounds good. I enjoyed it. At almost exactly a half hour, the bass came alive, the highs smoothed right out... Everything sounds fuller. Sound stage opened right up. Greater depth. I'm a believer. I bet in 2 hours it will sound even better.
    2 channel:
    Theater:
  • fmw
    fmw Posts: 90
    heiney9 wrote: »
    Cheers
    He could be right. I don't know. Neither do you. What I do know is that not all measurable phenomena are audible. I also know that doing the comparison sighted won't answer that question. So look around to see if there is rock under which you can crawl. I'll wave to from my rock.
  • polrbehr
    polrbehr Posts: 2,842
    fmw wrote: »
    And does it not also make sense that not all audible phenomena is measurable? I have heard subtle changes and marked improvements in my modest 2ch rig just from
    different cables (power, IC, etc.). Were they measurable? I dunno, I lack the equipment
    to make such determinations... well, other than my ears, which I rely on pretty heavily
    when I am listening for sound. ;)
    There really is no right, is there? Test for yourself and decide for yourself. Do all that and post your findings, you might just end up helping someone else in the process.
    H9 has owned that Pass amp for as long as I can remember, so I am sure he is not just "drinking the Kool-Aid" when he asserts that warm-up time makes a difference.
  • fmw
    fmw Posts: 90
    polrbehr wrote: »
    fmw wrote: »
    No, measurment instruments are far more sensitive than our hearing. If the audible difference isn't measurable, it will disappear in a bias controlled test every time.
  • polrbehr
    I am curious as to what measuring instrument I should be using to determine that a guitar solo is originating approximately 3' to the left of my left channel? Or that the lead vocals are just to the right of dead center, but a little higher than the top of the speakers?
    But since we are stuck on bias control testing, and not sitting in my den enjoying some excellent Steely Dan, never mind. You win.
  • fmw
    fmw Posts: 90
    polrbehr wrote: »
    Stereo imaging is determined at the mixing console. Nobody is suggesting that you can't hear the imaging. My comment was that changing amplifiers won't change the imaging. Changing speakers or speaker placement, however, can do so.
  • fmw
    fmw Posts: 90
    ZLTFUL wrote: »
    fmw wrote: »
    Psychoacoustics disagrees with you.
    https://en.wikipedia.org/wiki/Psychoacoustics
    But I am sure that you people will come up with some way to claim that it isn't a *real* science or some other inane **** like you always do.
    Nothing in that article disagrees with me.
  • fmw
    fmw Posts: 90
    ZLTFUL wrote: »
    fmw wrote: »
    Except for the fact that you dismiss that everyone processes what they hear differently...a minor thing really.
    Nonsense. I'm very aware of how hearing bias causes people to process sounds differently. I haven't dismissed that at all. All I have said is some audible differences are in the equipment and some of it is in those differences in the way people process sounds. We all have hearing bias. It is human nature. I understand it very well having spent so much time testing it. Nothing in that article disagrees with what I say.
    F1nut Posts: 51,682
    fmw wrote: »
    Once again, your ignorance and/or lack of experience on the matter comes shining through.
    On another note, I see you're not very good at keeping your word, but I'm far from surprised.
  • fmw
    fmw Posts: 90
    fmw wrote: »
    My lack of experience, huh? That made me chuckle. I came back because a member of this forum asked me to. He explained that you and a few others are the loud mouthed bullies that try to get people who dissent from your beliefs to leave. I honored the request. Now, would you like to debate what I said or are you just a loud mouthed bully?
    F1nut Posts: 51,682
    So, you let one of the forum trolls pull your string. I'm sure X is laughing his a$$ off at you right now.
    There's nothing to debate. You are wrong, period.
  • Guys I've said this many times and it does hold true for me. The instant I turn on my Adcom 555 and what ever source I hear absolutely no difference from start up or for hours running. Now for the tubers I get it they do need the time and here's a little story. I bought some speakers years ago from a dude in his Florida room. I said this is nice stuff,so what do you use for your personal use. He says I usually don't show my house but since your not a kid I'll give you a look. At 1st I almost bumped in these huge Albert Van Alstines I think the TOTL models. Then on the floor were 2 giant mono blocks (brand not known) and I asked if I could hear these things. He said no they need a GOOD HOUR TO GET TO PRIME LISTENING FULFILMENT. An hour kishmeirinkuchas, I need instant gratification which my Adcom gives me.....
  • vcwatkins
    vcwatkins Posts: 1,993
    My SS Pass Aleph 30 needs an hour or two to sound its best. I leave it on most of the time because of this. Totally agree with H9's comments above, and I'm not about to argue with the designer.
    txcoastal1 Posts: 13,499
    fmw wrote: »
    fmw wrote: »
    So what guarantees can you post that you are unequivocally correct other than you and some others said it was so....
    Not a debate just a question
  • 11tsteve
    11tsteve Posts: 1,166
    fmw wrote: »
    polrbehr wrote: »
    Just to be clear, you are saying my NAD 2150 and a pair of Pass mono blocks will create the same soundstage, and only my sighted bias can tell the difference?
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
    11tsteve wrote: »
    fmw wrote: »
    polrbehr wrote: »
    Hmmm, so all you Polk bung holios lead me astray, caused my divorce, and emptied my pocket book looking for the path of audio righteousness when i could have bought a **** amp that would give me all the sound stage I needed for cheap...shame on all of you :p
    DSkip wrote: »
    Sell the thresholds Ron. It only makes sense.
    Where's the disagree button
    afterburnt wrote: »
    15 years ago I shot the Lake Front Bate House owner because he had a sign "Worms Guaranteed to Catch Fish" didn't catch anything....he wouldn't give me a refund >:)
  • afterburnt
    afterburnt Posts: 7,892
    Damned sorry I opened this can of worms
    nooshinjohn Posts: 25,882
    txcoastal1 wrote: »
    DSkip wrote: »
    Agreed... Just give me those offensive boat anchors Ron. I will send you a Crown XPS. Everybody knows they sound EXACTLY the same. >:)
    txcoastal1 wrote: »
    DSkip wrote: »
    HMMMM it is hot down here in the south, would make since.....LOL
  • fmw
    fmw Posts: 90
    txcoastal1 wrote: »
    fmw wrote: »
    fmw wrote: »
    Nothing. It has no more guarantee than your posts or anybody else's.
  • fmw
    fmw Posts: 90
    11tsteve wrote: »
    fmw wrote: »
    polrbehr wrote: »
    Yes. If an amplifier has an inaudible variance from a flat frequency response, there isn't any way for it to affect imaging. If it has audible variances then it could make content at those frequencies to vary subtly from amp to amp. However, if such an audible difference did occur, I would suggest that one of the amps is not well designed or defective. Almost all solid state amps these days have an audibly flat frequency response. I assume your amps have an audibly flat frequency response. Did you compare it one that did not?
  • 11tsteve
    fmw wrote: »
    So, you do concede amplifier design can affect soundstaging?
    Polk Lsi9
    Keces DA-131 mk.II
