Dreadnaught Avel-Lindberg 1000VA Transformer Group Buy?
1…1213151718…23
  • Dennis Gardner
    LeftCoast wrote: »
    I am brand new the the SDA club. Is there any way to still get in on this, or has the ship sailed?
    You will have to either wait for the next group buy, order 10 yourself from A\L, or wait until someone gives up on their SDAs and wants to unload their transformers. I imagine a few of these will hit the forum for sale in the next few months as they serve absolutely no other purpose to anyone other than SDA modders.
  • westmassguy
    LeftCoast wrote: »
    The 800VA Toroid is a stock Item with Avel-Lindberg
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • LeftCoast
    LeftCoast wrote: »
    Thanks for the info. I think I'll just wait for another group by of the 1000VA, even if it takes awhile. I'm a pretty patient dude and I'm up to my eyeballs in other projects anyway,
    Meanwhile I will do other upgrades, like Toolfan's rings, etc, and just enjoy what I have and be patient.
  • crispybrown
    LeftCoast wrote: »
    Isn't it basically a high quality 120v-to-120v isolating transformer? Some audiophiles like placing those between the power supply and equipment, so assuming you live in a country with 120v ac power, you could do that and convince yourself it improves the sound of a system without SDAs :-P
  • nspindel
    nspindel Posts: 5,343
    Sorry to get hopes up, but Melanie just emailed me and said she misquoted the shipping date by one week. These will ship by Oct. 10.
  • nspindel
    He is trying it out. He purchased one in the group buy.
  • crispybrown
    ZLTFUL wrote: »
    I would be in for a group buy although I remain skeptical - how would replacing a wire with a transformer help if I don't run bridged amps? If it does, are there other 'random' places in audio circuits we can throw expensive inductors too and expect an improvement? :-). It smacks of cutting a digital signal to vinyl then playing it back and claiming better sound to me!
    Translation: "I am skeptical and would rather insult others' intelligence rather than try it out myself and see if it really does or doesn't make a difference."
    You can pick up the 800va toroid from A/L for ~$135 shipped. You can buy a case from Digi-Key and connectors along with the speaker cable of your choice for a total cost of under $200. You can recoup most of that selling a complete Dreadnought on the forum.
    Frankly, for the $15-$25 you may lose, you have a ton to gain. So why not try it out for yourself instead of insulting everyone who has tried it and has experienced a difference?
    Maybe it doesn't come across that way here, but I see it as insulting my own intelligence: As you say many people here experienced a difference. I do not understand the science or logic behind why an isolating transformer would help in the sda link, so I am buying one to find out as you suggest.
    Similarly some people have reported an improvement from placing one in the power input path. Again I do not understand why that would/could improve the sound, but if I found myself with a nice a-l transformer and no SDAs, I would certainly give it a try. (Assuming I am correct in my assumption that the 1000va model is a 120v, 60hz compatible isolator. If not, it would be a good way to ruin an expensive transformer and perhaps start a fire...)
  • TNTsTunes
    ZLTFUL wrote: »
    Have you read this?
    http://vr3mods.com/uploads/SDA_Handbook_2011_Rev3.pdf
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • Moose68Bash
    ZLTFUL nails it.
    I have a Silver Circle Audio Pure Power One 5.0 power conditioner in between mains and all my equipment in my main rig. It is essentially a 5.0KV toroidal transformer with several receptacles. When I installed it, not only did I notice the "cleaner" sound, but my wife commented on it without prompting from me. Isolating the mains helps with SQ.
    The isolation transformer in the SDA interconnect circuit helps with the 1Cs in SQ, even though that rig has a common ground amp. (My wife noticed the improvement in SQ there, as well.
    Of course, I could not even use my mono blocks in my main rig with the SDA interconnect without the Dreadnought in that circuit -- they're non-common ground amps.
  • Sea
    Sea Posts: 317
    Have we lost the historical threads forever? I remember a thread that showed how the transformer was wired in, but I cannot find it now. I am, for one, going to need some advice when we get the transformers.
    Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
    Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
    Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
  • MrBuhl
    MrBuhl Posts: 2,419
    Sea wrote: »
    Amen to that! I might try to go it alone - but not without help! Here are a few I bookmarked.
    http://forum.polkaudio.com/discussion/74472/the-ai-1-dreadnought-project-pt-1/p1
    http://forum.polkaudio.com/discussion/158154/800va-dreadnought-build#latest
    http://forum.polkaudio.com/discussion/160494/dreadnought-assembly-questions#latest
    Some have pictures restored, some well...
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • Sea
    Sea Posts: 317
    Great. Thanks. There was some links that nspindel has posted further up in the thread that were dead. The wiring details were in third link of your post, Many Thanks.
  • agfrost
    agfrost Posts: 2,497
    You guys getting ready? I've got most of my preparations done-I made two 8' lengths of cable to use with the Dreadnaught, and a separate 14 footer for use without. At one point I thought I might be completing my Speakon work before receiving the transformer, but it sounds as if they'll be arriving on our doorsteps pretty soon. I'll still find use for the single cable if I'd like to A/B a little or if in the future I decide to move the speakers along separately (no plans for that as of now!).
    Left to do is a) Dynamat inside of case, and b) add the Speakon connector to my 2BTL's terminal cup. I've got a little extra bit of soldering work to do there, as I've got the B/B connector now and need to make the internal connection to what would be the blade connector in a pin/blade setup.
    Jay
    Jay
  • markamerica
    LeftCoast wrote: »
    Leftcoast, whenever there is another group buy, count me in.
    SDA SRS, SDA SRS1.2TL, SDA-1C,SDA 2B, Soundcraftsmen Amplification (A5002s, MA5002s, MA5002As)
  • TNTsTunes
    TNTsTunes Posts: 751
    agfrost wrote: »
    Jay
    I'm getting ready, my case arrived yesterday and now I'm waiting on the transformer. I'm not sure if Glen got his rerouted to me before they shipped. I have the dynamat, connectors and feet coming. Still need to get it all ready.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    ZLTFUL wrote: »
    My bad on the purchase side of it. You are trying it out for yourself and that is a good thing.
    The short of it, on the power side, the isolation transformer isolates the downstream circuitry from the mains. This is primarily for safety as the user of an isolated device now has no contact with the main's power. The side effect/benefit is that any noise on the mains is not transferred to the secondary winding. The "new" magnetic field created by the secondary tends to be cleaner power than the mains.
    On the Dreadnought side, it is to use inductance to transfer the signal which in turn decouples the ground from each side of the amp in non-common ground amps. This inductive signal tends to be cleaner.
    (At least this is how my limited understanding of electrical theory explains it)
    ZLTFUL's explanation sums it up nicely. The link below is to a thread that shows a circuit diagram:
    The AI-1 Dreadnought Project Pt.2 - Upgrade to 1000VA Transformer -Pg 7
  • Mr_Hz
    Mr_Hz Posts: 176
    agfrost wrote: » You guys getting ready?
    I've got my cases from Larry, ordered/received my female Speakon connectors. Ordered and have to go to the post office to pick up the cables from WestMassGuy/David for the interconnects. Just received my copper film tape which I will use to line the interiors of the enclosures, suppressing/reducing any possible RF interference. Many people talk of using Dynomat inside these enclosures... but to me it would seem copper used as an RF suppression agent is more effective than Dynomat as a noise suppressant. Am I missing something? Should both be used, or is that overkill?
    Your input is welcomed...
    2.3TL's - Living Room
    CRS+'s (4.1 TL's) - Office
    SDA1C's - Famdamly Rm
    SDA1C's - Master Bedroom
  • westmassguy
    westmassguy Posts: 6,850
    Mr_Hz wrote: »
    Ron, the Aluminum Case Filters RF, the Copper Foil Filters EMI, and the Dynamat adds mass to the enclosure, to suppress internal and external micro-vibrations/resonances.
  • drumminman
    drumminman Posts: 3,396
    Mr_Hz wrote: »
    Where did you order your copper tape? Can you post a link?
  • TennMan
    TennMan Posts: 1,266
    Did you consider adding a switch to the case to bypass the transformer? That way you could do an A/B test without swapping cables.
  • westmassguy
    drumminman wrote: »
    Mr_Hz wrote: »
    http://www.ebay.com/itm/251521269133?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
  • motorstereo
    motorstereo Posts: 2,428
    YEE HAH! Look what just arrived a few minutes ago; It looks like I'm the first one here and I'm certainly looking forward to my weekend project. Thanks to everyone that made this happen. g68etla1mpm2.jpg
  • motorstereo
    Ok now for a very important question as I seem to have misplaced the link. Which 4 wires do I connect to the speakons?
  • TNTsTunes
  • nspindel
    Ah wow, I hadn't even realized they had shipped! Good for you guys, glad to see they're starting to arrive!!!
  • TNTsTunes
    I wonder if mines going to get shipped to me or GlennDog first????
  • nspindel
    nspindel wrote: »
    I thought it might be useful in the interests of drumming up more participants to put up a good post explaining what this group buy is all about, with a few links to some highly useful threads.
    The original SDA design worked only with common ground amps. Some non-common ground amps allow you to strap the negative poles together, essentially making it a common ground amp, without a problem. Others do not, and very very bad things can happen if you do. You certainly couldn't use mono blocks with SDA's. Polk's later design iteration of the SDA's allowed for the use of a new cable they sold called the AI-1. You can still find them for sale on occasion on eBay or they come up here every now and then. The AI-1 allowed the SDA signal to pass between the speakers without requiring the grounds to connect by using an isolation transformer. However, like other parts of the crossover design, this cable was manufactured to meet a price point by using less expensive (i.e. inferior) components. It worked, and allowed you to use SDA's with non-common ground amps, but it didn't sound as good as using a straight cable.
    Enter DarqueKnight and his research into using much better isolation transformers. His original intention was to replace the original AI-1 he needed in a scenario where he was not using a common ground amp. He researched several different transformers and settled in on an 800VA transformer from Avel Lindberg for his original Dread:
    http://www.polkaudio.com/forums/showthread.php?73304-AI-1-Dreadnought-Preliminary-Results
    http://www.polkaudio.com/forums/showthread.php?74472-The-AI-1-Dreadnought-Project-Pt.1
    DK later discovered that improvements continued using an even bigger 1000VA transformer from AL, however these were not a stock part and required a minimum purchase of 10 units, hence these group buys:
    http://www.polkaudio.com/forums/showthread.php?131537-Plitron-1000VA-Transformer-Evaluation
    http://www.polkaudio.com/forums/showthread.php?129829-The-AI-1-Dreadnought-Project-Pt.2-Upgrade-to-1000VA-Transformer
    Somewhere along the line, he experimented with the Dread using a common ground amp, and discovered that when built with a boutique audio grade transformer like we're ordering here, the original AI-1 design actually sounds considerable better than a straight SDA connection when used with a common ground amp as well. That's when a lot of interest in these transformers came about, a lot of people including myself are using a Dreadnaught (either 1000VA or 800VA) with common ground amps and are loving the results.
    So this group buy is for the transformer. Sounds expensive for a transformer, but this thing is a massive hunk of audio grade copper. You'll need a case to mount it in. Save yourself time and get Larry's. You'll need to consider what kind of connectors you'll need. Save yourself time and get Speakons:
    http://www.polkaudio.com/forums/showthread.php?142058-A-slightly-different-take-on-the-Dreadnought
    Finally, you'll need to consider cables, and how they terminate on the speaker side. Personally, I replaced my pin-blade SDA connector with a Speakon and haven't looked back. You can also use a single binding post, connect the positive Dreadnaught cable, and connect the negative to the same negative post that you connect the negative speaker cable coming from the amp. Helps to use both a spade and a banana on the same terminal. I'd recommend going Speakon though!
    Hopefully I'll get paid three times today and we'll be at 15 paid units. Then we try to recruit 5 more over the weekend and get to 20!
    Here are all the cleaned up links from my above post:
    http://forum.polkaudio.com/discussion/73304/AI-1-Dreadnought-Preliminary-Results
    http://forum.polkaudio.com/discussion/74472/The-AI-1-Dreadnought-Project-Pt.1
    http://forum.polkaudio.com/discussion/131537/Plitron-1000VA-Transformer-Evaluation
    http://forum.polkaudio.com/discussion/129829/The-AI-1-Dreadnought-Project-Pt.2-Upgrade-to-1000VA-Transformer
    http://forum.polkaudio.com/discussion/142058/A-slightly-different-take-on-the-Dreadnought
  • motorstereo
    TNTsTunes wrote: »
    Yes; thanks that's the one; and thanks to Jesse also for posting the pic of how it should be wired.
  • nspindel
    TNTsTunes wrote: »
    Remind me which city, state you're in?
  • TNTsTunes
    Waterford WI 53185
    nspindel wrote: »
    TNTsTunes wrote: »
    Waterford WI 53185
