Post a picture... any picture
looks like the soft white underbelly of a stereo SUT (step up transformer) to my semi-trained eye (and semi-savvy brain).
EndersShadow wrote: »SCompRacer wrote: »
Rich what is that? The underside of a tube buffer?
Mr. Hardy is absolutely on top of things. It's a home made SUT. Two speed (low and high) with ground lift and "inny" transformers versus external.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
ooh, a two-speed! Gotta clutch, or is it a turbo-hydramatic ; - )
Seriously, what kind of transformers are they?
FWIW -- and not that it's all about me ; - ) -- I've got a nice pair of the Silk (Thailand) SUTs I need to assemble into some sort of permanent enclosure... someday.
mhardy6647 wrote: »ooh, a two-speed! Gotta clutch, or is it a turbo-hydramatic ; - )
Automatic. Powerslide.
I built two. Carl got the Cinemag blues and I picked up some used Cinemag reds.
SCompRacer wrote: »EndersShadow wrote: »SCompRacer wrote: »
I am guessing that something to do with turntables lol? Correct?
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
10 - 4 good buddy. A SUT is one way to convert the very low level signal from a LOMC (low output moving coil cartridge) -- often 100 microvolts or so -- up to the normal (several millivolts) level of a moving magnet (MM) cartridge. The SUT's output can then drive a normal MM phono preamp. As a passive device, the SUT should add no noise when it does so.
The other way to step up the output of a LOMC to drive a normal MM phono preamp is with a so-called "head amp" or "pre-pre amp" (or any phono preamp with adequate gain; typically ca. 60 dB) -- these active devices (e.g., Jim Hagerman's "Piccolo") can be pretty good, but will always add some noise and distortion when they do their job.
A really good pair of SUTs aren't cheap, though.
No free lunch, as always.
mhardy6647 wrote: »Nice woody... umm... should I rephrase that?
Did you take that one with the fog? I'd have that framed and hanging on my wall.
Bird in Hand winery, near Adelaide, South Australia."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Yup, last week -- haven't figured out how to hang pixels on the wall, though ;-)
Ditto - you should frame and hang this one up!
The interplay of the Carassius auratus auratus and the reflection is very nice.
So far, Target is the best place to have digital photos printed in my area. You can bring your photos in on a CD-R, thumbdrive, SD card, microSD. They turn out awesome. They have two choices, something like "in house" and "professional". That may not be what they call them, but one is basically a computer printer and the other is a huge piece of equipment/printer that does an amazing job. You can select whatever size you want. Bigger sizes are extremely pricey!
Because I am The Pumpkinking
There's a big art show every year in Louisville the first weekend in October. There's a guy that combines two black and white photos, that used to show his work there. I've got a bunch of his work matted and framed on the wall. These aren't the best quality scans.
Herm... Try walgreens.... They can do canvas prints as well and they look great.
I've had them do a bunch of stuff on canvas for my wife."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Do the employees at Walgreens ever comment about your g-e-n-it-als?EndersShadow wrote: »Herm... Try walgreens.... They can do canvas prints as well and they look great.
(Thought that word might get blocked)
5.4 in a 2001 Ford F-150 4x4. Cracked plastic intake manifold and a blown out spark plug. Was the family hunting truck / boat & camper hauler, but now will be son's transportation for school and dates. Thankfully, I didn't have to twist his arm to get him to help with the project.
DSC_2542 by mhardy6647, on Flickr
DSC_2547 by mhardy6647, on Flickr
DSC_2571 by mhardy6647, on Flickr
DSC_2556 by mhardy6647, on Flickr -
The new grass cutting rig:
Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Steve...either your garage is too big or you don't have enough toys
This is my Rig we were at the bottom of the Sunwapta pass at 6740 feet elv. On the ice fields parkway Jasper National Park.
Cheers
Roger -
Cheers
Roger
That is EXACTLY what I need to fill in my garage!
Tornado Red wrote: »Steve...either your garage is too big or you don't have enough toys
Thats the garage/shed that also is built to house an RV... He's got space for days..............
The shop is actually bigger than the house. About 2550 sqft (68' x 38'). It has a casita inside as well. The house has it's own 2.5 car garage.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
[/quote]
You have grass in AZ?
[/quote]
Surprisingly we do, now that we're out of town; but it's seasonal grass brought on by the monsoons.
Erik, I was confused about the same thing. I watched your ATV tour video and saw NUFFIN BUT DIRT! It must of been one of those gotta have it moments.
