Post a picture... any picture
    EndersShadow Posts: 17,543
    SCompRacer wrote: »
    Rich what is that? The underside of a tube buffer?
    mhardy6647 Posts: 33,085
    looks like the soft white underbelly of a stereo SUT (step up transformer) to my semi-trained eye (and semi-savvy brain).
    SCompRacer Posts: 8,354
    edited August 2014
    SCompRacer wrote: »
    Mr. Hardy is absolutely on top of things. It's a home made SUT. Two speed (low and high) with ground lift and "inny" transformers versus external.
    ooh, a two-speed! Gotta clutch, or is it a turbo-hydramatic ; - )
    Seriously, what kind of transformers are they?
    FWIW -- and not that it's all about me ; - ) -- I've got a nice pair of the Silk (Thailand) SUTs I need to assemble into some sort of permanent enclosure... someday.
    Automatic. Powerslide.
    I built two. Carl got the Cinemag blues and I picked up some used Cinemag reds.
    SCompRacer wrote: »
    SCompRacer wrote: »
    I am guessing that something to do with turntables lol? Correct?
    edited August 2014
    10 - 4 good buddy. A SUT is one way to convert the very low level signal from a LOMC (low output moving coil cartridge) -- often 100 microvolts or so -- up to the normal (several millivolts) level of a moving magnet (MM) cartridge. The SUT's output can then drive a normal MM phono preamp. As a passive device, the SUT should add no noise when it does so.
    The other way to step up the output of a LOMC to drive a normal MM phono preamp is with a so-called "head amp" or "pre-pre amp" (or any phono preamp with adequate gain; typically ca. 60 dB) -- these active devices (e.g., Jim Hagerman's "Piccolo") can be pretty good, but will always add some noise and distortion when they do their job.
    A really good pair of SUTs aren't cheap, though.
    No free lunch, as always.
  • Hermitism
    Hermitism Posts: 4,205
    Nice woody... umm... should I rephrase that?
    Did you take that one with the fog? I'd have that framed and hanging on my wall.
  • drumminman
    drumminman Posts: 3,396
    Bird in Hand winery, near Adelaide, South Australia.
    edited August 2014
    Hermitism wrote: »
    Yup, last week -- haven't figured out how to hang pixels on the wall, though ;-)
    Ditto - you should frame and hang this one up!
    The interplay of the Carassius auratus auratus and the reflection is very nice.
  • Hermitism
    So far, Target is the best place to have digital photos printed in my area. You can bring your photos in on a CD-R, thumbdrive, SD card, microSD. They turn out awesome. They have two choices, something like "in house" and "professional". That may not be what they call them, but one is basically a computer printer and the other is a huge piece of equipment/printer that does an amazing job. You can select whatever size you want. Bigger sizes are extremely pricey!
  • pumpkinman
    pumpkinman Posts: 9,528
    The Fab 4 and the Pumpkinman LOL
    Because I am The Pumpkinking
  • Hermitism
    There's a big art show every year in Louisville the first weekend in October. There's a guy that combines two black and white photos, that used to show his work there. I've got a bunch of his work matted and framed on the wall. These aren't the best quality scans.
    G1.jpg 524.6K
    G2.jpg 168.7K
    G3.jpg 521.3K
    G4.jpg 210.6K
    G7.jpg 80.2K
    G8.jpg 109.4K
    G9.jpg 88.6K
    g10.jpg 39.7K
    Herm... Try walgreens.... They can do canvas prints as well and they look great.
    I've had them do a bunch of stuff on canvas for my wife.
  • Hermitism
    Do the employees at Walgreens ever comment about your g-e-n-it-als?
    (Thought that word might get blocked)
  • Green '01
    My weekend project:
  • Green '01
    5.4 in a 2001 Ford F-150 4x4. Cracked plastic intake manifold and a blown out spark plug. Was the family hunting truck / boat & camper hauler, but now will be son's transportation for school and dates. Thankfully, I didn't have to twist his arm to get him to help with the project.
    edited August 2014
  • steveinaz
    steveinaz Posts: 19,522
    The new grass cutting rig:
  • Tornado Red
    Steve...either your garage is too big or you don't have enough toys :)
  • polk500
    polk500 Posts: 1,171
    steveinaz wrote: »
    Now that's a ride on mower.
    Cheers
    Roger
  • polk500
    This is my Rig we were at the bottom of the Sunwapta pass at 6740 feet elv. On the ice fields parkway Jasper National Park.
    Cheers
    Roger
  • steveinaz
    polk500 wrote: »
    Cheers
    Roger
    That is EXACTLY what I need to fill in my garage!
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited September 2014
    steveinaz wrote: »
    You have grass in AZ? :D
    Thats the garage/shed that also is built to house an RV... He's got space for days..............
  • steveinaz
    The shop is actually bigger than the house. About 2550 sqft (68' x 38'). It has a casita inside as well. The house has it's own 2.5 car garage.
  • steveinaz
    [/quote]
    You have grass in AZ? :D [/quote]
    Surprisingly we do, now that we're out of town; but it's seasonal grass brought on by the monsoons.
  • mrbiron
    mrbiron Posts: 5,711
    Erik, I was confused about the same thing. I watched your ATV tour video and saw NUFFIN BUT DIRT! It must of been one of those gotta have it moments. :p
