Post a picture... any picture
1…7778808283…1125
  • bikezappa
    bikezappa Posts: 2,463
    The POLK forum is not working very well.
    Peter
  • dh4645
    dh4645 Posts: 61
    yeah what is up with the site? also, all of a sudden i'm getting an email every time some one makes a post in this thread....which never happened before 2 or 3 days ago and i havent been back on this site in months to change my subscription options.
    My entertainment setup:
    Sony XBR9 52"
    C - Polk CS1
    F - 2 Polk Monitor 60's
    S - 2 Polk Monitor 30's
    SB - 2 Polk Monitor 30's
    Sub - Polk PSW111
    Onkyo 605 AVR
    Scientific Atlanta DVR
    Z-Line Vitoria Stand/Mount
    PS3 and Xbox 360
  • bikezappa
    Quick Upgrade. Be Back Soon
    Thanks,
    Patrick C
    That's the message I get when I try to sign in.
    I guess the forum is broken.
    mhardy6647 Posts: 35,562
    forum.polkaudio.com is the new link (but I am guessing you knew that already) -- the old site is muerto
  • bikezappa
    Thanks mhardy for the help.
    So... I am not a big Led Zeppelin fan... but mornings like this certainly put me to mind of a certain song by those zany lads...
    14813043098_c8000d21e2_b.jpgDSC_9810 by mhardy6647, on Flickr
  • Tornado Red
    Could be a Misty Mountain Hop, or maybe Over The Hills And Far Away, or I thought I saw a small Black Dog near the left tree line, or that place could get flooded if The Levee Breaks, and I don't see any pocket change in the picture so I'm sure there's No Quarter...
    all good points!
    no levees, fortunately.
    The black thingies are turkeys.
    I was thinkin' Misty Mountain Hop...
    14978063156_23a337c9bd_b.jpgDSC_9810 by mhardy6647, on Flickr
    tho' they are just hills, not mountains...
  • xjghost
    xjghost Posts: 1,115
    Where is that? It's nice!
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • Tornado Red
    all good points!
    Misty Mountain, I thought as much :p Looks like a serene place to spend an afternoon in a hammock contemplating life...
  • Tornado Red
    Though this is quite funny, your "weiner cutoff" had a more immediate impact...
    edited August 2014
    xjghost wrote: »
    It's my back yard.
    The Purple Hays JPG made me laugh so hard that Mrs H, from the kitchen, asked "Are you OK?"... : - )
  • headrott
    headrott Posts: 5,496
    Rick88 wrote: »
    Good Lord Rick!! :D
    Nice woody... umm... should I rephrase that?
    SCompRacer Posts: 9,395
    While not as exciting as the pics Rick posts, this is one of my fav car posters in the basement. Hard to take a pic of it without glare.
    427 shelby?
    Yes on the Shelby and 427 would be my choice!
    EndersShadow Posts: 17,757
    SCompRacer wrote: »
    Rich what is that? The underside of a tube buffer?
    looks like the soft white underbelly of a stereo SUT (step up transformer) to my semi-trained eye (and semi-savvy brain).
    edited August 2014
    SCompRacer wrote: »
    Mr. Hardy is absolutely on top of things. It's a home made SUT. Two speed (low and high) with ground lift and "inny" transformers versus external.
    ooh, a two-speed! Gotta clutch, or is it a turbo-hydramatic ; - )
    Seriously, what kind of transformers are they?
    FWIW -- and not that it's all about me ; - ) -- I've got a nice pair of the Silk (Thailand) SUTs I need to assemble into some sort of permanent enclosure... someday.
    Automatic. Powerslide.
    I built two. Carl got the Cinemag blues and I picked up some used Cinemag reds.
    SCompRacer wrote: »
    SCompRacer wrote: »
    I am guessing that something to do with turntables lol? Correct?
    edited August 2014
    10 - 4 good buddy. A SUT is one way to convert the very low level signal from a LOMC (low output moving coil cartridge) -- often 100 microvolts or so -- up to the normal (several millivolts) level of a moving magnet (MM) cartridge. The SUT's output can then drive a normal MM phono preamp. As a passive device, the SUT should add no noise when it does so.
    The other way to step up the output of a LOMC to drive a normal MM phono preamp is with a so-called "head amp" or "pre-pre amp" (or any phono preamp with adequate gain; typically ca. 60 dB) -- these active devices (e.g., Jim Hagerman's "Piccolo") can be pretty good, but will always add some noise and distortion when they do their job.
    A really good pair of SUTs aren't cheap, though.
    No free lunch, as always.
  • Hermitism
    Hermitism Posts: 4,352
    Did you take that one with the fog? I'd have that framed and hanging on my wall.
  • drumminman
    drumminman Posts: 3,396
    Bird in Hand winery, near Adelaide, South Australia.
