Post a picture... any picture
The POLK forum is not working very well.
Peter -
yeah what is up with the site? also, all of a sudden i'm getting an email every time some one makes a post in this thread....which never happened before 2 or 3 days ago and i havent been back on this site in months to change my subscription options.My entertainment setup:
Sony XBR9 52"
C - Polk CS1
F - 2 Polk Monitor 60's
S - 2 Polk Monitor 30's
SB - 2 Polk Monitor 30's
Sub - Polk PSW111
Onkyo 605 AVR
Scientific Atlanta DVR
Z-Line Vitoria Stand/Mount
PS3 and Xbox 360 -
Quick Upgrade. Be Back Soon
Thanks,
Patrick C
That's the message I get when I try to sign in.
I guess the forum is broken. -
forum.polkaudio.com is the new link (but I am guessing you knew that already) -- the old site is muerto
Thanks mhardy for the help.
So... I am not a big Led Zeppelin fan... but mornings like this certainly put me to mind of a certain song by those zany lads...
DSC_9810 by mhardy6647, on Flickr -
Could be a Misty Mountain Hop, or maybe Over The Hills And Far Away, or I thought I saw a small Black Dog near the left tree line, or that place could get flooded if The Levee Breaks, and I don't see any pocket change in the picture so I'm sure there's No Quarter...
all good points!
no levees, fortunately.
The black thingies are turkeys.
I was thinkin' Misty Mountain Hop...
tho' they are just hills, not mountains...
mhardy6647 wrote: »So... I am not a big Led Zeppelin fan... but mornings like this certainly put me to mind of a certain song by those zany lads...
Where is that? It's nice!HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
mhardy6647 wrote: »all good points!
Misty Mountain, I thought as much
Looks like a serene place to spend an afternoon in a hammock contemplating life...
ken brydson wrote: »
Though this is quite funny, your "weiner cutoff" had a more immediate impact...
It's my back yard.
The Purple Hays JPG made me laugh so hard that Mrs H, from the kitchen, asked "Are you OK?"... : - )
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
While not as exciting as the pics Rick posts, this is one of my fav car posters in the basement. Hard to take a pic of it without glare.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
looks like the soft white underbelly of a stereo SUT (step up transformer) to my semi-trained eye (and semi-savvy brain).
EndersShadow wrote: »SCompRacer wrote: »
Rich what is that? The underside of a tube buffer?
Mr. Hardy is absolutely on top of things. It's a home made SUT. Two speed (low and high) with ground lift and "inny" transformers versus external.
ooh, a two-speed! Gotta clutch, or is it a turbo-hydramatic ; - )
Seriously, what kind of transformers are they?
FWIW -- and not that it's all about me ; - ) -- I've got a nice pair of the Silk (Thailand) SUTs I need to assemble into some sort of permanent enclosure... someday.
mhardy6647 wrote: »ooh, a two-speed! Gotta clutch, or is it a turbo-hydramatic ; - )
Automatic. Powerslide.
I built two. Carl got the Cinemag blues and I picked up some used Cinemag reds.
SCompRacer wrote: »EndersShadow wrote: »SCompRacer wrote: »
I am guessing that something to do with turntables lol? Correct?
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
10 - 4 good buddy. A SUT is one way to convert the very low level signal from a LOMC (low output moving coil cartridge) -- often 100 microvolts or so -- up to the normal (several millivolts) level of a moving magnet (MM) cartridge. The SUT's output can then drive a normal MM phono preamp. As a passive device, the SUT should add no noise when it does so.
The other way to step up the output of a LOMC to drive a normal MM phono preamp is with a so-called "head amp" or "pre-pre amp" (or any phono preamp with adequate gain; typically ca. 60 dB) -- these active devices (e.g., Jim Hagerman's "Piccolo") can be pretty good, but will always add some noise and distortion when they do their job.
A really good pair of SUTs aren't cheap, though.
No free lunch, as always.
mhardy6647 wrote: »Nice woody... umm... should I rephrase that?
Did you take that one with the fog? I'd have that framed and hanging on my wall.
Bird in Hand winery, near Adelaide, South Australia."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
