Jim Salk gives Emotiva as an amp recommendation
13468911
    F1nut Posts: 51,822
    edited August 2013
    I know Polk calls them bookshelfs.
    And yet you continue to babble nonsense. So much for being a man of your word.
    In simple terms that hopefully you'll grasp this time. Just because the speaker is described as a bookshelf (a term carried over from long ago) does not mean the only place it can be used is on bookshelves. I mean really, who puts speakers on bookshelves these days!?!
  • brgman
    brgman Posts: 2,859
    edited August 2013
    Can we vote these trolls off the island!?!?!?
    I have yet to see any one of them bring anything positive to this forum.
    Only annoying sycophantic dribble about Emotiva.
    Other than that crap-
    Nothing.
    Zip.
    Zero.
    Nada.
    I’M OFFENDED!!!!
    EndersShadow Posts: 17,707
    edited August 2013
    DSkip wrote: »
    Just wait til they start stalking you...
    It's ok Skip... What's one more stalker to the list ;).
  • Habanero Monk
    Habanero Monk Posts: 715
    edited August 2013
    Yep... nothing quite like trying to put words and thoughts into the mouth and mind of a man you have never met. Your credibility is top notch with me.:rolleyes:
    Uh, you are the collective trying to put words in his mouth. Please remember I was the one after a good # of posts corrected the thinking that Mr. Salk is the one that mentioned 'Inexpensive'.
    Not too particularly worried where my credibility stands with you.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited August 2013
    That would be me. The CRS+s in my office at work are in bookshelves on the wall facing my desk.
    txcoastal1 Posts: 13,513
    edited August 2013
    Because you don'y have any
  • Habanero Monk
    edited August 2013
    Coming from the person that thinks a speaker is either a floor stander or a bookshelf. But then again considering the crowd at hand not to surprised at the limited breadth of understanding there are more shades to it.
    I'm supposedly not interacting with the person off the street here. Sheesh.
  • headrott
    headrott Posts: 5,496
    edited August 2013
    No we don't agree. That is asking of me to guess someone else's opinion of one vs the other. I know he recommended the amps, I don't know in what or if any particular order.
    I suggest you listen to both amps and form your own opinion. It is obvious for those that have heard Emotiva, vurses BAT to which order Jim Salk was referring to them. If you haven't heard the differences between the two amps/brands you should not suggest that it is "unknown" as you have no clue. If you have heard both amps/brands, but still have no clue to which order he was referring to them, you have no clue and should not suggest there is no order to which Jim Salk was referring to them. Why can I make this statement? I will quote my last post, again:
    headrott wrote: »
    Ah, so you do agree that when he mentioned the XPA-2, Jim Salk was listing it as a minimim level of "getting the job done" compared to the BAT VK-600 which excels at "getting the job done". Great! Let's close the thread. Also, there is no emphasis on 'inexpensive' implied. It is a fact that the XPA-2 is less expensive than the BAT VK-600. Just as it's a fact that the Emotiva XPA-2 has a narrower and less deep soundstage compared to the BAT VK-600.
    Also, as I already stated, the subjective and preferential qualities are the tonal qualities of these amps. That is, having a warm tone, neutral tone, or bright tone.
  • zane77
    zane77 Posts: 1,696
    edited August 2013
    I have both BAT and Emotiva, one is for HT and the other is for music, You definately can not put the two in the same class. I can't believe this has gone on this long, both have their place. The Emo equipment was a GREAT starting point for me with seperates but I would not compare BAT and Emotiva as equals. This is just my opinion with my ears. I will let everyone else have their own opinion because they are not listening with my ears. When I first got my Emo's, that was my first step into seperates and I couldn't believe the difference. but now i have taken a further step and their is another dimension to the sound that is presented. Just my 2 cents and please don't beat me up, I love both alternatives.
    Two Channel
    SCompRacer Posts: 9,114
    edited August 2013
    From this thread at avsforum, 10/2012. Post 7792. Copy and paste, no text omitted, I added bold to text. Another opinion with some good advice at the end, IMO.:cheesygrin:
    http://www.avsforum.com/t/939744/the-official-salk-sound-owners-and-discussion-thread/7770
    I have owned the Emotiva LPA-1 and also heard the XPA-2 in Jim Salk's shop. The W4S/Parasounds are superior in my opinion. The Emotiva's were thin in the mids and had an edgy sound to them in my opinion. They aren't what I'd call a "relaxed" or "smooth" amplifier. The W4S on the other hand is smoother but without losing detail or air, if that makes sense. It's hard to hear what an amplifier does (which usually is hardly anything in my experience) when it's not in your own system, though. I heard the W4S amps with my speakers, but it was at Patrick's house (Warpdrv), so not exactly apples to apples. I did, however, compare a number of amps in my own system including the Parasound and the Emotiva stuff. If I had to purchase an amp right now it would probably be the Parasound A21 for class A/B or a Wyred ST-500 for digital. For the money you're getting great build quality and a serious amount of performance; so much so that there's nothing to complain about in this price range in my opinion. And honestly, a lot of these amps sound very similar, if not the same, so once you reach a certain level of quality you shouldn't have a problem. Some people even say there's no difference between a 300 receiver's amps and dual monoblock 300 watt SS amps. To each their own, so long as they are happy.
    I hope that helps. The only way you'll be able to know for sure is by putting something into your system and listening, and that is why I recommend purchasing amps used, or perhaps from a company that has a liberal return policy (such as Audio Advisor).
    F1nut Posts: 51,822
    edited August 2013
    No matter how you try to twist things, as ususal you've still got a big 'ol bag of nothing. :rolleyes:
    F1nut Posts: 51,822
    edited August 2013
    Yeah, yeah....you know what I meant.
    Toolfan66 Posts: 18,085
    edited August 2013
    And, we have gained what?
    Nothing!!! That's what...
  • Nightfall
    Nightfall Posts: 10,084
    edited August 2013
    I'm confused. Is Emotiva bad or bad compared to high end?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • zane77
    zane77 Posts: 1,696
    edited August 2013
    I wouldn't say bad but if you want to spend the money there is always better. At their price point they are hard to beat for new, you can always check out the used market for others.
    Two Channel
    tonyb Posts: 33,072
    edited August 2013
    Nightfall wrote: »
    No, not bad. Emotiva is considered entry level, not high end. There's a difference between the 2 in price, build quality, and of course....sound quality.
  • Nightfall
    edited August 2013
    So they are good for the money, beginner, etc.
    afterburnt wrote: »
  • Jhayman
    Jhayman Posts: 1,548
    edited August 2013
    Check out there website and check their forum for info...
    This is the wrong forum to be asking about Emotiva as you can figure out not much Love here for them..
    The few that do own them here have no issues with them that I am aware of..
    One good thing they do offer is a 30 day trial see if any of the more expensive brands offer that..
    Nightfall wrote: »
  • Nightfall
    edited August 2013
    Jhayman wrote: »
    Surely there are members here that own high end but understand the position somebody like myself is in. DSkip seems to be fair about what I presume Emotiva to be.
    afterburnt wrote: »
    F1nut Posts: 51,822
    edited August 2013
    Nightfall wrote: »
    From the review link that SCompRacer posted...
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2013
    Emotiva makes perfectly fine gear at their price point, and many people love the gear, and are content with what they have. However, like anything else in the world, there is always something better, and generally speaking, it costs more. So, you can start with Emo and have a fine system, and if you get the urge you can always upgrade later.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited August 2013
    Are you telling me that Jim Salk had the nerve to recommend amps for his speakers without getting the approval of the Polk Forum Guru's? Who does he think he is?:rolleyes:
  • DarqueKnight
    edited August 2013
    WilliamM2 wrote: »
    I don't think any of the Polk Forum Gurus have a problem with Jim's recommendations. The problem was with some people trying to misrepresent that Jim Salk was implying that Emotiva was in the same performance class as Van Alstine and BAT. Emotiva engages in the same misrepresentation when they say things like this:
    "Emotiva’s Reference Series components are a cost-no-object assault on setting the standard for audiophile components - it’s just that Emotiva’s costs are still much less than the competition. Compare to the finest equipment in the world, and you’ll be surprised at the results!"
    Source: http://shop.emotiva.com/collections/reference-series
    On the web page referenced above, Emotiva is claiming that their amplifiers costing between $1500 to $2000 are "cost-no-object" assaults setting standards for audiophile components, when the truth is, $2000 won't even approach the parts cost of some top of the line audiophile amplifiers.
    Some people believe this nonsense that they are getting a "world class", "reference level" audiophile component "comparable to the finest equipment in the world", when in actuality they are only getting a very good entry level component.
    Emotiva knows damn well that someone shopping for a $1500 to $2000 amp is not going to go to the trouble of comparing it to the likes of BAT, Krell, Pass Labs, etc.
    nooshinjohn Posts: 25,933
    edited August 2013
    You raise some very good points as always DK... any mention of the words "entry level" and Emo in the same thread even will get you banned from their website. They are doing all that thy can to buy credibility, yet failing to understand that it is EARNED and not bought.
  • nguyendot
    nguyendot Posts: 3,594
    edited August 2013
    Hmm anyone want to unload some Emo gear for me to see what the buzz is all about? Good/bad whatever - I'd like to see first hand.
    Main Surround -
    edited August 2013
    nguyendot wrote: »
    They have an easy "no hassle" 30 day return policy... all you need to do is pay return shipping! What a great offer when you consider the cost of returning an 85 pound amp.:rolleyes:
  • nguyendot
    edited August 2013
    bahaha. I'll check the pawn shop hehe
    Main Surround -
  • Jhayman
    edited August 2013
    At least they offer a way to try their gear, I would be most Happy to pay return shipping if I could try a Pass, Krell or others..
    So kudos to them for offering it..
    Don't you think sales would increase for those companies if they offered this?
    How much is it to try the MIt cable program after paying shipping and insurance close to a bill I think?
  • DarqueKnight
    edited August 2013
    Jhayman wrote: »
    This Pass Labs dealer offers 10 day trials:
    "Satisfaction Guaranteed - All products from Reno Hi-Fi come with a ten-day, in-home demo so you can be absolutely sure you are happy with your investment in sound."
    http://renohifi.com/
    A Krell dealer list can be found here: http://www.krellonline.com/buy.html
    I have never encountered a high end dealer that did not allow some form of in home trial for amps. They typically keep demos around for this purpose. It is inconceivable that a dealer would expect you to keep an expensive amp that did not suit your needs.
    I look forward to your Krell and Pass Labs reviews!
    F1nut Posts: 51,822
    edited August 2013
    Depending on distance and whether FedEx (cheaper) or UPS was used to ship, about $40 to $50 to demo $3300.00 worth of S3.3 cables.
    Note: that demo is now closed. A new one is on the horizon.
