SVS PB-13 Ultra Subwoofer
1234568»
  • danz1906
    danz1906 Posts: 5,144
    edited November 2010
    colossus wrote: »
    Hello again guys.
    After extensive research about the Dual KW-120 THX and Dual PB-13 Ultra I came to a conclusion (after seeing numerous charts and reviews) that the PB-13 Ultra is better than the KW-120.
    If you compare the subs from frequency 20Hz+, they are practically the same. But if you compare them from 20Hz down, then you see the magic in the PB-13 Ultra.
    Therefore if you are looking for the dynamic punchy bass of the KW-120s but you want also the extra deep deep bass of 10-20Hz, then go for the Dual PB-13 Ultras.
    This is of course my personal opinion based on the research I have done.[/QUOTE
    The Dual PB-13 Ultra will be Awesome, theirs a couple of guys here with
    Dual Pb-13s. Although I liked both subs the PB-13 Ultra was my Favorite.
    I have Full-Range speakers(Linn AV5140s) front and rear.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • colossus
    colossus Posts: 9
    Ordered the DUAL PB-13 Ultras today. Hopefully they will arrive in a week's time. Will let you know my feedback after installation.
    What calibration methods did you use for the Ultras ? Spl meter ?
    Cheers guys ! and thanks for the input !
  • danz1906
    colossus wrote: »
    Congrats!!!!!!!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • megasat16
    megasat16 Posts: 3,521
    danz1906 wrote: »
    colossus wrote: »
    Hello again guys.
    I love my Dual Ultras in the 15Hz model. Sealed mode is a little much to ask even from dual Ultras. Too noticeable drop out on the output and a lot more concerns on the amps reliability.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • danz1906
    megasat16 wrote: »
    danz1906 wrote: »
    If I play my Cards right, I should have Dual Gloss Black Ultra-13s for
    Christmas:biggrin:
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • daviidwilson
    daviidwilson Posts: 1
    megasat16 wrote: »
    15Hz mode means sealing one out of three ports with the included foam inserts. So, there are only two port firing instead of 3 (20Hz mode).
    15Hz mode allows PB13 Ultra to dig lower and bass is noticeable tighter. But the down-side is a little less SPL than 20Hz mode.
    In addition, it's a little easier for me to get a flatter response in the 15hz mode. 20hz in a smaller room like mine is very dynamic, but I get an even higher shelf below 35hz that's hard to tame with the PEQ. That tends to make things sound a bit bottom heavy. I prefer an even response where the bass above 50hz, the slam, as well as, where it's musical is just as prominent as the deep stuff.
    Ron Temple is offline Report Pos
  • colossus
    colossus Posts: 9
    Hello guys !!! I got the Dual PB13 ULTRAS finally !! Awesome hehehe :-)
    After 2 whole days playing around positioning the subs (extremely heavy), finally got a nearly even response from 20HZ to 80HZ by placing them in the middle of the side walls. I preferred the 20Hz mode cause few movies go below 20Hz.
    I suggest to all owners of Dual PB13s to do the same if you want the low and mid bass on the same level - you can enjoy both music & movies fully !! Infact if you see the article on audioholics, they say the same thing:
    http://www.audioholics.com/tweaks/get-good-bass/multiple-subwoofer-setup-calibration-1
    For a single PB13 Ultra, it is ideally placed in the front corner, maybe 30-40 cms away from the wall. Corner placed subs peak mostly in 30-35Hz which you can tame by PEQ or Audyssey Multi EQ.
  • danz1906
    colossus wrote: »
    Congrats!!!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • danz1906
    edited December 2010
    With all the new subs coming out and new seal design, the Ultra-13 still
    remains one of the best for it's size and price!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
    VR3 Posts: 29,440
    This thread has been inactively active for a year and a half...
    Insane
  • thsmith
    thsmith Posts: 6,082
    Yep, mine is doing just fine where it is and still impresses me.
  • danz1906
    thsmith wrote: »
    SVS hit a Home-run with the Ultra-13, its just a Monster on HT:biggrin:
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • leroyjr1
    leroyjr1 Posts: 8,785
    danz1906 wrote: »
    It's decent.:smile:
  • danz1906
    leroyjr1 wrote: »
    It's decent.:smile:
    How about Duals:wink:
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • leroyjr1
    danz1906 wrote: »
    It's a ittle better but it doesn't compare to my .....
    Bose Acoustimass module.
  • danz1906
    leroyjr1 wrote: »
    You're the Man!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • danz1906
    edited February 2013
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • thsmith
    Congrats ! I have thought about selling mine and getting the one with the Sledge amp but the one I have works so well I just have not made the move.
    Let us know how it compares to one you have now which I assume is the non sledge amp model.
