SVS PB-13 Ultra Subwoofer
Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Quad DIY LMS Ultra subs (powered by dual IPR-7500 amps)
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
2ch: Emotiva Stealth 8's, Airport Express -
Thanks..........Great looking Sub!!!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Thanks man.
The driver sure is a thing of beauty. My cabinet on the other hand, could use some work. LOL! I do have plans on having one built professionally though. Probably in a rosewood veneer to match my speakers, A/V stand, & rack.
Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
Hey E,
Congrats! Took a peek over at the emotiva thread. Your DIY sub is taking shape and looking great. -
Thanks bro!
You playing with tubes yet?
Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
BTW E,
8 power tubes arrived but the amp is on the slow boat arriving probably late next week.
Yep, it's quite the torture to stare at tubes but no amp to use them in! Curse the shipper!:D -
Edogg,
Seems like a prominent piece of tube equipment is missing from your equipment list.:DUMC-1
UPA-1 (x2)
XPA-3
LS6's
Mirage OMD-5
18" LMS Ultra DIY Sub
Panny AE-4000u
Panny BD60
Onix XCD-99
Belkin PF60
Harmony 890 -
BTW E,
Lol! Thats sucks!
All in due time my friend.
Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
edogg,
seems like a prominent piece of tube equipment is missing from your equipment list.:d
fixed!!
Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
Who's using their Ultra-13 in the Seal mode???Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
I did for awhile and preferred it for many applications. I changed back after a few months due to a couple of wicked hot BDs that distressed the sub at high volume. You lose about 5dbs down low in sealed mode, but for music it's better. For movies, sharper attack, but you lose some of the visceral subsonic signature. I think it was The Hulk and Valkyrie that prompted me to change back.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote: »I did for awhile and preferred it for many applications. I changed back after a few months due to a couple of wicked hot BDs that distressed the sub at high volume. You lose about 5dbs down low in sealed mode, but for music it's better. For movies, sharper attack, but you lose some of the visceral subsonic signature. I think it was The Hulk and Valkyrie that prompted me to change back.
What did you notice that made you believe the sub was stressed, Bottoming/popping? -
I ran my Ultra-13 sealed when i had it. It was great!! I did lose output but i had a second sub to help make up for that.
Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
No, nothing like that, the driver just didn't sound happy, right at it's limits. I'm probably going to go with the new Sledge amp when it's available for a swapout. It will allow you to run at limit without distress, as well as, a db or 3 more output. After, I will probably keep it in sealed mode.What did you notice that made you believe the sub was stressed, Bottoming/popping?
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote: »No, nothing like that, the driver just didn't sound happy, right at it's limits. I'm probably going to go with the new Sledge amp when it's available for a swapout. It will allow you to run at limit without distress, as well as, a db or 3 more output. After, I will probably keep it in sealed mode.
The New Amp looks impressive, any word when it will be available???Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
I was told 6-9 weeks about a month ago, but I think it's slipped. Cost...no idea.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote: »I was told 6-9 weeks about a month ago, but I think it's slipped. Cost...no idea.
ThanksLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
as for the new sub i think there will be no ultra look at the specs of the plus!!!! =ORoom Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Sub...svs pc13 ULTRA
Amp:Emotiva xpa3 -
I am in the process of buying two subs for my cinema room. I am mixed up between these two:
a) Dual Klipsch KW-120 THX + Emotiva XPA-2 amp OR
b) Dual SVS PB-13 Ultra
I have a Klipsch THX Ultra2 9 Channel Speaker Step up in the cinema room. Of course my heart beats for the Klipsch subs but after reading through the forums, they say that the PB-13s are mightier in both HT and music.
I only managed to find the Freq vs SPL chart of the DUAL KW-120s and SINGLE PB-13. What about DUAL PB-13s ? Is there a chart ?
Money wise, they will cost me the same brand new ........ so my door is open for both !!
Thanks for your opinion guys !! -
would suggest emailing SVS. I have emailed them with my questions and got responses quite quickly and with more than enough info."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Since you have the Thx Ultra2 speaker setup, I would say go for the KW-120
subwoofers and the KA-1000 THx amp.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Personally I don't mind buying the dual PB-13s even though I have a Klipsch THX Ultra2 setup. Just want to know which is the best.
Dual Klipsch KW-120 specs:
130dB @ 30Hz, 122dB @ 20Hz, 112dB @ 15Hz 1/8 space, 1m (2 enclosures side-by-side per THX Ultra2)
Dual PB-13s ??? -
Yes I will email SVS and hopefully get an answer from them.EndersShadow wrote: »would suggest emailing SVS. I have emailed them with my questions and got responses quite quickly and with more than enough info. -
Both are great sub-woofers, I think you would be very happy with
either one. The Thx Ultra2 KW-120 may be a better match for your
Thx speakers.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
SVS reply:EndersShadow wrote: »would suggest emailing SVS. I have emailed them with my questions and got responses quite quickly and with more than enough info.
For dual, co-located subs you can add simply add 6dB onto the single measurements.
By the facts displayed in the Freq vs SPL charts, it seems that the Klipsch subs are more dynamic and powerful.
But that does not convince me. I want to know the opinion of someone who experienced both !!
Anyone ??? -
Check the SVS PB-13 Ultra FREQ vs SPL Chart from 1 foot away:Both are great sub-woofers, I think you would be very happy with
Thx speakers.
http://www.hometheaterhifi.com/volume_14_3/svs-pb13-ultra-subwoofer-9-2007-part-3.html
This sub can go maximum to 100dBs (1 foot away). Adding another sub, will go to 106dBs. What do you conclude guys ? Need your help.
KW-120s are THX certified therefore the results are 100% true.
Danz you heard both ! Need your honest opinion PLEASE
You seem to like the PB-13 Ultra more ...... hehehe -
My vote goes to SVS because its got the amps built in for you so it saves you some rack/entrainment center room...that and I really really like SVS..
Or get both and return the one you dont like (SVS has 30 day return, so does Emotiva, not sure about Klipsh)"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Hello again guys.
After extensive research about the Dual KW-120 THX and Dual PB-13 Ultra I came to a conclusion (after seeing numerous charts and reviews) that the PB-13 Ultra is better than the KW-120.
If you compare the subs from frequency 20Hz+, they are practically the same. But if you compare them from 20Hz down, then you see the magic in the PB-13 Ultra.
Therefore if you are looking for the dynamic punchy bass of the KW-120s but you want also the extra deep deep bass of 10-20Hz, then go for the Dual PB-13 Ultras.
This is of course my personal opinion based on the research I have done.
