SVS PB-13 Ultra Subwoofer
Ron Temple wrote: »Congrats bevo, I knew you were having room issues from your previous comments. Very capable subs can sound like crap if you're overloaded below 40hz masking the midbass. Sounds like you've got it licked. I don't use a room curve. I try to stay flat and run mine cold to keep the blend between my SDAs and the sub seamless. The 1Cs add alot of bass.
I'm sure my your SDAs have just a tad more bass then my A5's
. I imagine I'm gonna have to run some sort of curve to make up for it. right now I think I have about a 8 or 9db curve depending on how accurate my RS spl is. It's about where I want it, but it's hard to tell not having an eq to experiment with.
I should have the SMS-1 wednesday, but after getting my sub how it is now, I think I might have jumped the gun on the SMS. I'm not really sure if I'll need it now, at least though once it comes I should be able to get everything exactly how I want it, and get the most out of the ultra. If nothing else, it will give me something to play with.
For movies the ultra was always impressive, but I can't believe how much better it sounds now with music. If anyone still thinks you can just plop your sub in a corner and forget it. Do yourself a favor and experiment, the results could amaze you, just like they did me.Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra) -
can't freaking wait for my ultra...:DPolk monitor 70's- front
Polk cs2- center
Polk monitor 30's- surround
SVS PB-13 ULTRA- SUB
Pioneer ELITE vsx-21- AV reciever
Pannisonic G10 50" - Display
PS3- Does everything
Monoprice for all my wires -
mikedup2003 wrote: »can't freaking wait for my ultra...:D
Welcome to the Club!
Congrats on the Ultra-13Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
How does that sub compare to Polks DSW Micro-Pro and Pro line?
(Just curious on your comparison thoughts)Zone 1
(5.1 Setup)
-- VM 20 (L/R)
-- RM 8 Center (center)
-- VM 10 (S.L/R)
-- DSW microPRO 1000 (LFE)
Zone 2
-- Atrium 45
Denon AVR-2809
(7.1 Setup)
-- RM 6600 (L/R + center + S.L/R)
-- RM 7 (SB.L/R)
-- PSW 350 (LFE)
Denon AVR-1909 -
Much bigger, more powerful, plays much deeper and has various tuning options that allow for more extention. You can even seal it. It's recognized as one of the best commercial subs available at any price due to it's looks, features, output and sound quality. I'm sure the MicroPro 4000 is a nice sub and comes closest.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ultra..now thats sweetOffice Update: Jim is tired of office noise...Especially the ladies whispering beside me right now.
Google says: http://www.google.com/search?q=speech+privacy+systems
First pick: www.speechprivacysystems.com -
Hey guys just wanted to give my first impressions of my new PB Ultra. All i can say is :eek: this thing is a beast. I played the tank tapping scene from finding nemo (with gain at 11 o'clock on svs and pioneer avr subwoofer gain at -6.0) I could feel the bass in my chest! I'm sort of afraid to raise the levels anymore but I can't resist.
I still need to tweak around with it though because when i playback music im not getting that same bass. Anyone with a similar experience? advice?Polk monitor 70's- front
Polk cs2- center
mikedup2003 wrote: »Hey guys just wanted to give my first impressions of my new PB Ultra. All i can say is :eek: this thing is a beast. I played the tank tapping scene from finding nemo (with gain at 11 o'clock on svs and pioneer avr subwoofer gain at -6.0) I could feel the bass in my chest! I'm sort of afraid to raise the levels anymore but I can't resist.
I have the pc ultra ,you won't get that "same" bass because MOST music doesn't have content that low ,like in movies. Pretty well all subwoofers sound more impressive/powerful with sound effects from movies. -
good to know. im new to this home audio thing, i come from the world of car audio. Just got to get use to it. Thanks for the info:)Polk monitor 70's- front
Polk cs2- center
Movies allow for 30db peaks in the LFE channel and they can be quite astounding. Music, as mentioned, normally doesn't go as low and are recorded much more linearly throughout the range. Also, you'll never be able to pressurize a living room like a car...should sound more balanced and cleaner though (in the house, not the car).
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote: »Movies allow for 30db peaks in the LFE channel and they can be quite astounding. Music, as mentioned, normally doesn't go as low and are recorded much more linearly throughout the range. Also, you'll never be able to pressurize a living room like a car...should sound more balanced and cleaner though (in the house, not the car).
very true. I didn't think of it that way. However the PB13 bass is so crisp/clean as you can imagine:DPolk monitor 70's- front
Polk cs2- center
Agreed -
I recently read that using the ultra in sealed mode creates a better musical subwoofer. Any thoughts on sealing it?Polk monitor 70's- front
Polk cs2- center
I ran mine sealed for awhile. It tightens up a bit and the attack is sharper, midbass more pronounced. You lose some efficiency and the visceral low end, but it's still extremely powerful. I put it back in 15hz tune due to a couple of BDs that seemed to stress it at high output. Sealed works better in a small room. Mine's medium small, but with a large opening into the rest of the house.mikedup2003 wrote: »I recently read that using the ultra in sealed mode creates a better musical subwoofer. Any thoughts on sealing it?
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote: »I ran mine sealed for awhile. It tightens up a bit and the attack is sharper, midbass more pronounced. You lose some efficiency and the visceral low end, but it's still extremely powerful. I put it back in 15hz tune due to a couple of BDs that seemed to stress it at high output. Sealed works better in a small room. Mine's medium small, but with a large opening into the rest of the house.
+1
I noticed the very same things as Ron.
For me 15hz tune is best. Sealed seemed to loose impact and I rarely listen to just music. Plos I also have medium-small room that opens to the rest of the house. -
Agreed,Sealed mode does make it more Musical. The bass seem to be Quicker.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Hello,
How good is this Sub?
How does it compare to the Ultra-13??
http://www.svsound.com/products-sub-box-ultra2.cfmLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Say What?
:D:D Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Say What?
:D:D
Nice Sub!! Also, a pleasure to meet you Dan. Have fun with that thing
bdaley6509 wrote: »Nice Sub!! Also, a pleasure to meet you Dan. Have fun with that thing
Thanks Bronson, the Sub looks new!!!!!!!!!
Two would look even better;)Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
I apologize if this against forum rules, but here's a link to one im selling.
http://www.audiogon.com/cgi-bin/cls.pl?homesubw&1285775645&/SVS-PB13-Ultra-In-Beautiful-Ro
Feel free to PM me if there's any interest. I have plenty of positive feedback in other forums (emotiva, av123, ebay). Thanks!
Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Quad DIY LMS Ultra subs (powered by dual IPR-7500 amps)
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
2ch: Emotiva Stealth 8's, Airport Express -
I use to own a Rosenut Ultra-13, that I sold. Good luck with your sale.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Thanks!
Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Yes sir!
Should have my DIY project completed this week.
Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
Yes sir!
Sweet,,,,,,,Let me know how it comes out!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
For sheazy!
Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Thanks bro!
Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
