SVS PB-13 Ultra Subwoofer
  • bevo
    bevo Posts: 306
    edited February 2010
    Ron Temple wrote: »
    Congrats bevo, I knew you were having room issues from your previous comments. Very capable subs can sound like crap if you're overloaded below 40hz masking the midbass. Sounds like you've got it licked. I don't use a room curve. I try to stay flat and run mine cold to keep the blend between my SDAs and the sub seamless. The 1Cs add alot of bass.
    I'm sure my your SDAs have just a tad more bass then my A5's :). I imagine I'm gonna have to run some sort of curve to make up for it. right now I think I have about a 8 or 9db curve depending on how accurate my RS spl is. It's about where I want it, but it's hard to tell not having an eq to experiment with.
    I should have the SMS-1 wednesday, but after getting my sub how it is now, I think I might have jumped the gun on the SMS. I'm not really sure if I'll need it now, at least though once it comes I should be able to get everything exactly how I want it, and get the most out of the ultra. If nothing else, it will give me something to play with.
    For movies the ultra was always impressive, but I can't believe how much better it sounds now with music. If anyone still thinks you can just plop your sub in a corner and forget it. Do yourself a favor and experiment, the results could amaze you, just like they did me.
    Denon 1909, want to upgrade for pre outs
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
    Panasonic plasma 50 inch
    Buttkicker(don't use or need it anymore since getting the Ultra)
  • mikedup2003
    mikedup2003 Posts: 42
    edited March 2010
    can't freaking wait for my ultra...:D
    Polk monitor 70's- front
    Polk cs2- center
    Polk monitor 30's- surround
    SVS PB-13 ULTRA- SUB :D
    Pioneer ELITE vsx-21- AV reciever
    Pannisonic G10 50" - Display
    PS3- Does everything :)
    Monoprice for all my wires
  • danz1906
    danz1906 Posts: 5,144
    edited March 2010
    Welcome to the Club!
    Congrats on the Ultra-13
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • ikolbyi
    ikolbyi Posts: 77
    edited March 2010
    How does that sub compare to Polks DSW Micro-Pro and Pro line?
    (Just curious on your comparison thoughts)
    Zone 1
    (5.1 Setup)
    -- VM 20 (L/R)
    -- RM 8 Center (center)
    -- VM 10 (S.L/R)
    -- DSW microPRO 1000 (LFE)
    Zone 2
    -- Atrium 45
    Denon AVR-2809
    (7.1 Setup)
    -- RM 6600 (L/R + center + S.L/R)
    -- RM 7 (SB.L/R)
    -- PSW 350 (LFE)
    Denon AVR-1909
  • Ron Temple
    Ron Temple Posts: 3,212
    edited March 2010
    Much bigger, more powerful, plays much deeper and has various tuning options that allow for more extention. You can even seal it. It's recognized as one of the best commercial subs available at any price due to it's looks, features, output and sound quality. I'm sure the MicroPro 4000 is a nice sub and comes closest.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • jimsage85
    jimsage85 Posts: 1
    edited April 2010
    Ultra..now thats sweet
    Office Update: Jim is tired of office noise...Especially the ladies whispering beside me right now.
    Google says: http://www.google.com/search?q=speech+privacy+systems
    First pick: www.speechprivacysystems.com
  • mikedup2003
    edited April 2010
    Hey guys just wanted to give my first impressions of my new PB Ultra. All i can say is :eek: this thing is a beast. I played the tank tapping scene from finding nemo (with gain at 11 o'clock on svs and pioneer avr subwoofer gain at -6.0) I could feel the bass in my chest! I'm sort of afraid to raise the levels anymore but I can't resist.
    I still need to tweak around with it though because when i playback music im not getting that same bass. Anyone with a similar experience? advice?
    Polk cs2- center
  • rubin
    rubin Posts: 565
    edited April 2010
    I have the pc ultra ,you won't get that "same" bass because MOST music doesn't have content that low ,like in movies. Pretty well all subwoofers sound more impressive/powerful with sound effects from movies.
  • mikedup2003
    edited April 2010
    rubin wrote: »
    good to know. im new to this home audio thing, i come from the world of car audio. Just got to get use to it. Thanks for the info:)
    Polk cs2- center
  • Ron Temple
    edited April 2010
    Movies allow for 30db peaks in the LFE channel and they can be quite astounding. Music, as mentioned, normally doesn't go as low and are recorded much more linearly throughout the range. Also, you'll never be able to pressurize a living room like a car...should sound more balanced and cleaner though (in the house, not the car).
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • mikedup2003
    edited April 2010
    Ron Temple wrote: »
    very true. I didn't think of it that way. However the PB13 bass is so crisp/clean as you can imagine:D
    Polk cs2- center
  • rubin
    rubin Posts: 565
    edited April 2010
    Ron Temple wrote: »
    Agreed
  • mikedup2003
    edited April 2010
    I recently read that using the ultra in sealed mode creates a better musical subwoofer. Any thoughts on sealing it?
    Polk cs2- center
  • Ron Temple
    edited April 2010
    I ran mine sealed for awhile. It tightens up a bit and the attack is sharper, midbass more pronounced. You lose some efficiency and the visceral low end, but it's still extremely powerful. I put it back in 15hz tune due to a couple of BDs that seemed to stress it at high output. Sealed works better in a small room. Mine's medium small, but with a large opening into the rest of the house.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • gelinas
    gelinas Posts: 226
    edited April 2010
    Ron Temple wrote: »
    +1
    I noticed the very same things as Ron.
    For me 15hz tune is best. Sealed seemed to loose impact and I rarely listen to just music. Plos I also have medium-small room that opens to the rest of the house.
  • danz1906
    edited May 2010
    Agreed,Sealed mode does make it more Musical. The bass seem to be Quicker.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • danz1906
    edited May 2010
    Hello,
    How good is this Sub?
    How does it compare to the Ultra-13??
    http://www.svsound.com/products-sub-box-ultra2.cfm
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • danz1906
    edited July 2010
    Say What? :D:D:D
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • bdaley6509
    bdaley6509 Posts: 1,167
    edited July 2010
    danz1906 wrote: »
    Say What? :D:D:D
    Nice Sub!! Also, a pleasure to meet you Dan. Have fun with that thing :)
  • danz1906
    edited July 2010
    bdaley6509 wrote: »
    Thanks Bronson, the Sub looks new!!!!!!!!!
    Two would look even better;)
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • edoggrc51
    edoggrc51 Posts: 584
    edited July 2010
    I apologize if this against forum rules, but here's a link to one im selling.
    http://www.audiogon.com/cgi-bin/cls.pl?homesubw&1285775645&/SVS-PB13-Ultra-In-Beautiful-Ro
    Feel free to PM me if there's any interest. I have plenty of positive feedback in other forums (emotiva, av123, ebay). Thanks! :)
    Denon 4311ci
    MINIdsp OPEN-DRC
    XPR-5
    LS6 Line Arrays
    LS-C Center Channel
    A/V-1RS Surounds
    Quad DIY LMS Ultra subs (powered by dual IPR-7500 amps)
    Panny AE-8000u
    2:35 110in Screen
    Oppo BDP-103
    Belkin PF60
    Harmony ONE
    2ch: Emotiva Stealth 8's, Airport Express
  • danz1906
    edited August 2010
    edoggrc51 wrote: »
    I use to own a Rosenut Ultra-13, that I sold. Good luck with your sale.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • edoggrc51
    edited August 2010
    Thanks! :)
    Denon 4311ci
    MINIdsp OPEN-DRC
    XPR-5
    LS6 Line Arrays
    LS-C Center Channel
    A/V-1RS Surounds
    Panny AE-8000u
    2:35 110in Screen
    Oppo BDP-103
    Belkin PF60
    Harmony ONE
  • danz1906
    edited August 2010
    edoggrc51 wrote: »
    Thanks! :)
    Did you sell it????
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • edoggrc51
    edited August 2010
    Yes sir! :) Should have my DIY project completed this week. :)
    Denon 4311ci
    MINIdsp OPEN-DRC
    XPR-5
    LS6 Line Arrays
    LS-C Center Channel
    A/V-1RS Surounds
    Panny AE-8000u
    2:35 110in Screen
    Oppo BDP-103
    Belkin PF60
    Harmony ONE
  • danz1906
    edited August 2010
    edoggrc51 wrote: »
    Sweet,,,,,,,Let me know how it comes out!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • edoggrc51
    edited August 2010
    For sheazy! :)
    Denon 4311ci
    MINIdsp OPEN-DRC
    XPR-5
    LS6 Line Arrays
    LS-C Center Channel
    A/V-1RS Surounds
    Panny AE-8000u
    2:35 110in Screen
    Oppo BDP-103
    Belkin PF60
    Harmony ONE
  • danz1906
    edited August 2010
    edoggrc51 wrote: »
    For sheazy! :)
    Nice Subwoofer-Congrats!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • edoggrc51
    edited August 2010
    Thanks bro! :)
    Denon 4311ci
    MINIdsp OPEN-DRC
    XPR-5
    LS6 Line Arrays
    LS-C Center Channel
    A/V-1RS Surounds
    Panny AE-8000u
    2:35 110in Screen
    Oppo BDP-103
    Belkin PF60
    Harmony ONE
  • danz1906
    edited August 2010
    edoggrc51 wrote: »
    Thanks bro! :)
    You should start a thread with your new DIY subwoofer:cool:
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
