Hardware Rings for your Passives and MW6XXX
2456712
    Toolfan66 Posts: 18,290
    edited June 2010
    Right now on just the 6.5" rings the cost I have it quoted for will be $5.80 ea. + shipping + 3% paypal if you choose to pay with paypal.. Now if we had a thousand of these going out the door the cost would drop big time..
    I figured this would give some of you an idea what it will cost just to do your drivers....
    Keep in mind:
    Material cost,
    Laser cut time,
    Hardware cost,
    Installing hardware time.
    Pack and ship...
    I will just run this through the shop as a job...
    When I did the crossover plates my boss let me have some drop aluminum to make them with, and that saved those of you guys that got them a lot of money. That and I cut and time saved them myself, and did it on my own time..
  • audiobilly
    audiobilly Posts: 351
    edited June 2010
    Is this a one time thing? Will there be an opportunity down the road to get these? If not then I can up my order count.
    nooshinjohn Posts: 26,064
    edited June 2010
    Have you got a cost for the 15" passives yet?
  • nadams
    nadams Posts: 5,877
    edited June 2010
    Price seems reasonable... I'm still in!
    Ludicrous gibs!
  • vmaxer
    vmaxer Posts: 5,121
    edited June 2010
    Keep in mind:
    Material cost,
    Laser cut time,
    Hardware cost,
    Pack and ship...
    Sounds good!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • dane_peterson
    dane_peterson Posts: 1,903
    edited June 2010
    Count me in for a pair of 1Cs and Monitor 7s.
    edited June 2010
    audiobilly wrote: »
    No I plan to keep the program, and some on the side just in case...;)
  • headrott
    headrott Posts: 5,496
    edited June 2010
    Cool Larry, that means I wouldn't have to buy them all at once and go broke. I could do one set of speakers at a time. Much better.......
    Greg
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2010
    Keep in mind:
    Material cost,
    Laser cut time,
    Hardware cost,
    Pack and ship...
    Six bucks a pop seems very reasonable to me. Now to find out what the PR ring would cost.
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited June 2010
    The PRs will require a lot of real estate on the sheet metal. Unless you could cut at least one mid driver out of the middle, maybe two on the 15 inchers. Let's just hope Polk was accurate with their hole drilling.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited June 2010
    that shouldn't be a big deal. Worst case you could fill the original holes and drill new ones.
    F1nut Posts: 52,154
    edited June 2010
    I'll take complete sets for a pair of 2.3TL's, 2B's and CRS+'s. If you are selling the bolts as well, I would like black ones.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited June 2010
    If you are selling the bolts, I want a set of black and a set of brass.
  • Conradicles
    Conradicles Posts: 6,396
    edited June 2010
    I'll take a set for my SDA-1C's with black hardware.
    F1nut Posts: 52,154
    edited June 2010
    Is brass on the table too?
  • nadams
    nadams Posts: 5,877
    edited June 2010
    Would the bolts not be of a standard thread size/pitch that you could get them from your local hardware store?
    Ludicrous gibs!
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2010
    If any thread pitch is involved, you should keep it 1/4-20....since almost everything Polk is of that measurement.
  • Janne
    Janne Posts: 139
    edited June 2010
    Not sure but could the PR be cut in 4 pieces to save on scrap and size for shipping.
    I hope you could add the screws for us overseas guys. Brass, black or gold plated :p
    I really appreciate you offering this!
    HT/2 CH
    McIntosh MX120, MC500, MC206, MEN220
    polkaudio SDA SRS 1.2TL, XO, Inductor, Tweeter, Larry's rings, WBT Binding posts, Moretite and Dynamat mod. Built by Mollie Jones 27:th of February 1991, CS350-LS XO mod, LS-f/x, DSW MicroPro 4000
    MIT Shotgun S3.3 Bi-wire SC, Shotgun S3.3 SC, Shotgun S3.3 Proline IC, Shotgun S3.3 IC, Shotgun S3.3 Sub cable, AVT 1 Optical IC, EXP 3 Speaker interconnect.
    edited June 2010
    I have some concerns with doing the passives for all models.
    The SRS,1.2,1.2tl and the 1C's of course are no problem. And I have a passive for the monitor 7's so no problem there as well.
    So I need help with the other models. I'm sure the passive in the 1C's is the same in one in the SDA 2B's.
    No reason to worry about where Polk drilled there holes I will send a drill template with the set.
    So some help from you SDA gurus would help.
    F1nut Posts: 52,154
    edited June 2010
    Larry, the SDA SRS 2, 2.3, 2.3TL, SDA SRS, 1.2 and 1.2TL all use 15" PR's. All the CRS versions are 10". All the rest are 12". I can make a template for the 10" if you need me to.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2010
    Larry, count me in for a set for my 2A's.
    That would be four MW's, and two 12" PR's.
    I'll probably get a set for my M7's eventually too, but the SDA's take priority.:cool:
    $6 a pop seems VERY reasonable to me.:)
    You're one of the ones at the forefront of SDA tweaking. Keep up the good work!
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • ESavinon
    ESavinon Posts: 3,067
    edited June 2010
    Any love for the SRT's?
    I'm placing an order for my Sda's.
    1.2tl, srs 2, srs 2.3tl, srs 3.1tl, sda 1c, crs +.
    One complete set each plus black bolts if available.
    At a later date I will do all my monitor series. I have too many of those to do right away.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • headrott
    edited June 2010
    Cool Jesse. I knew you'd come through with the stats.
    By the way, Larry. I think you'll need a lot of black bolts (and some brass ones too).
    Greg
  • hearingimpared
    edited June 2010
    headrott wrote: »
    Greg
    Was there ever even an iota of a doubt?;)
  • xsmi
    xsmi Posts: 1,804
    edited June 2010
    In for a pr. of SRS 2's.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • gimpod
    gimpod Posts: 1,793
    edited June 2010
    I've in for a full set for a pair of 1C's with black allen head bolts.
    Just need to know how you want to do this.
    Can you ship them so i can get them like yesterday :D
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited June 2010
    1 set for SDA2B's MW and PR also for tweets if you do them too.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • helipilotdoug
    edited June 2010
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    edited June 2010
    "Ok" I have the Dimensions for the 10" 12" and 15" passives.
    Thanks Jesse!!
    On the 10" passive did Polk ever use all 8 holes in any of the models? I will hardware for all eight but I was just curious.
    This might seem slow for me to get all of this together, but I am slammed at work right now. As soon as I have everything ready to roll I will start going through the list and get PM's to to you guys. I don't want to hold on to your money to long, I want you guys to be able to pay and know you will see them within two weeks max.
    Thanks for being patient,
    Larry.
  • helipilotdoug
    edited June 2010
    Thanks Jesse!!
    Larry.
    Larry these will be worth the wait! Thanks for doing this. :D
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
