Avatar
***Potential Spoiler***
So I finally made it to the theater the other day to see this. I really had mixed feelings ahead of time. These types of movies are not my thing, but there was so much hype I had to at least try it. Plus even if the movie totally sucked I figured I could be entertained by the novelty of the 3D.
Overall I was pretty entertained. For being soooo long it seemed to go fairly quick. IMO the story line was a little weak. Once you look past the CGI and 3D, it's basically just another David and Goliath type plot. The Man comes in with it's infinate power, and tries to drive out the seemingly weak and inferior natives, and fails.
There were also a couple of things that really irritated me in this movie, especially when you consider the amount of money spent making it. The lead actor's accent was there one second, and gone the next. This seems really dumb not to fix, since in a lot of the scenes it was just voice-over work. It's not like they would have had to re-shoot the scene.
I also thought it was lame that they took the time to create futuristic looking helicopters that had 2 counter-rotating and articulating blades per side, yet they made them sound like your standard turbine powered single rotor helicopter. I mean really...that much time and money spent, and you get lazy, and/or overlook that? Just seemed kinda stupid to me.
To me the movie is worth seeing, but is nowhere near an Epic like many claimed it to be.HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
James Cameron sinks the Titanic:eek:. Just happened today...
http://www.mtv.com/movies/news/articles/1630535/story.jhtmlThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
FFFFFFFFFFFFFFFFFFFFFFFFFFFF YEEEEEEEEEEEEEEEEEEEEEEEEESSSSSSSSSSSSSS SWEETTT keep going avatar!!!!HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
I didn't notice this...and I usually pick up on these types of discrepancies. Did the lead actor's accent vary according to whether he was in his human or avatar body, or would it vary from one minute to the next while he was in one body for an extended period? I know you said the accent was there one second and gone the next, but you might have meant that figuratively rather than literally.
I know several people who spent their childhood or teens in other countries, but later moved to the US. They either have no, or a slight, foreign accent when speaking normally. However, if they are stressed or excited, their native accent will appear and then disappear again when they calm down. I have also noticed the same thing with US citizens who spent their early years in one region of the country and substantial time in another.I also thought it was lame that they took the time to create futuristic looking helicopters that had 2 counter-rotating and articulating blades per side, yet they made them sound like your standard turbine powered single rotor helicopter. I mean really...that much time and money spent, and you get lazy, and/or overlook that? Just seemed kinda stupid to me.
Missed this one too...but then, I'm not an aircraft design buff. However, nothing escapes my scrutiny when it comes to starship design.:)Proud and loyal citizen of the Digital Domain and Solid State Country! -
I should see this.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Serendipity wrote: »I should see this.
Um ya go see it GO SEE ITHT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
DarqueKnight wrote: »I didn't notice this...and I usually pick up on these types of discrepancies. Did the lead actor's accent vary according to whether he was in his human or avatar body, or would it vary from one minute to the next while he was in one body for an extended period? I know you said the accent was there one second and gone the next, but you might have meant that figuratively rather than literally.
The accent seemed pretty random, and no, I wasn't being literal when saying it was there one minute and gone the next. I just know at one point he was starting one of his video journal entries, and I picked up on the accent. At first I just wondered if I had not noticed it before, but then noticed throughout the rest of the movie it was pretty hit-n-miss.
Regarding the sound. I'm no aircraft engineer or anything, but I've been around enough to know that if those machines were real, there is no way they would sound anything like that.:rolleyes:HT
2 CH
Far in the future, advanced design aircraft might sound different, especially if they are flying on a different planet with different gravity and a different atmosphere.Proud and loyal citizen of the Digital Domain and Solid State Country! -
DarqueKnight wrote: »Far in the future, advanced design aircraft might sound different, especially if they are flying on a different planet with different gravity and a different atmosphere.
The movie takes place in the future so agreed everything is different. I work around allot of engines and I can tell you for sure an engine designed or used in 2000, is totally different than what we use today. For example would be our Tier 3 and Tier 4 Engines.Shoot the jumper.....................BALLIN.............!!!!!
ummmm....WOW! The world of Pandora is simply breathtaking.If...
Ron loves a film = don't even rent. -
Yeah, pretty impressive...not just a CGI/3D extravaganza IMO. Whether you liked the story or not, you've got to give kudos to the depth of world building, the editing and pacing all wrapped up in the unbelievable visual and auditory journey.ummmm....WOW! The world of Pandora is simply breathtaking.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
For certain Ron. This should be one hell of a Blu-ray 3D presentation as well, cannot wait!If...
I enjoyed watching the movie and the 3D effects. I thought the story line should give credit to Apocalypse Now, “I’ll get you a case of beer”, Pocahontas and Lord of the Rings, I was waiting for the trees to attack at the end but they never showed up.
It's still Hollywood and just about every film rips off other films.
With films likes like these, I don't look for a plot or even care if it has one, it's all about the visuals and taking me away, away from here and it exceeded that more then just about any film I've ever seen.
Going to go back to Pandora next week, must go back.If...
Ron, welcome to the addiction of Pandora.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Ron lets take a trip to the Hallelujah mountains. Oh wait probably would not even be close to the real thing.
http://www.geekologie.com/2010/01/china_renames_mountain_to_hono.phpHT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Wow... this Kool-Aid sure is tasty! I mean..... ugh.... (gasp).... arghrghsrtghrghsghsgh....I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
LOL that was sort of my reaction when I saw the link.
On another side note a friend called me FYE is now taking pre orders for the avatar movie.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
To be honest... I didn't even look at the link. I was referring to Avatar.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
zombie boy 2000 wrote: »Wow... this Kool-Aid sure is tasty! I mean..... ugh.... (gasp).... arghrghsrtghrghsghsgh....
:D I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
nooshinjohn wrote: »James Cameron sinks the Titanic:eek:. Just happened today...
What happens when you apply correction for inflation?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
nooshinjohn wrote: »james cameron sinks the titanic:eek:. Just happened today...
finally!!!!!!!Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier -
concealer404 wrote: »What happens when you apply correction for inflation?
If you take inflation to account, then it will take another ten days to be a true comparison at the rate this film keeps raking it in. I would be happy with just 1/10th of 1 percent of the money this film has made.:)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
nooshinjohn wrote: »If you take inflation to account, then it will take another ten days to be a true comparison at the rate this film keeps raking it in. I would be happy with just 1/10th of 1 percent of the money this film has made.:)
Maybe you should have applied for the role of the big blue savage creature... i think you would be making 1/10th of 1% in that role
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
lol... :rolleyes:Maybe you should have applied for the role of the big blue savage creature... i think you would be making 1/10th of 1% in that role
Saw this last night in 3-d. While I loved the visual effect, which was outstanding, It remained a typical JC film, great visual,terrible dialog,story line,plot with holes. You had no emotional connection to any character, he's horrible at building characters. Take the movie "UP" as a comparison,great story line,the dialog matched, you had an emotional bond with the characters, thats a good movie. Avatar was just so-so, if not for the visual, this movie would not be getting as much attention, but then again,if thats all you care about,it's just right for you.HT SYSTEM-
lsi 9's -
Call me crazy saw it for the 6th time last night with a friends that has not seen it. He said it just sucked him in and he could not help but say it exceeded his expectations.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
bigaudiofanatic wrote: »call me crazy saw it for the 6th time last night with a friends that has not seen it. He said it just sucked him in and he could not help but say it exceeded his expectations.
crazy!!!!
:d :d :dHonoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
bigaudiofanatic wrote: »Call me crazy saw it for the 6th time last night with a friends that has not seen it. He said it just sucked him in and he could not help but say it exceeded his expectations.
I truly hope there is not a very long delay between it being pulled from theaters and it's appearance on DVD/Bluray. If there is I am not certain they have an effective treatment program for the withdrawl you will have to suffer through.:p:DThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
