SVS PB-13 Ultra Subwoofer
  • thsmith
    thsmith Posts: 6,082
    edited November 2009
    danz1906 wrote: »
    What do you think about corner placement of the Sub?
    You typically will get more gain but depending on your room it may not have the best sound. Need REW or something like it to find best placement to remove as many dips as possible and then EQ to clip the peaks.
  • thsmith
    megasat16 wrote: »
    I wonder what kind of correctly setup single sub will sound better than duals that are setup correctly.
    IS that even possible ? duals setup correctly will have more output than a correctly setup single. I guess it depends on what you are trying to do.
  • bassaholic
    bassaholic Posts: 315
    I ended up picking one the these up tonight. They're better looking in person than in pics. I am so curious to see how it will compare to the PB12+2 I just recently sold. Gonna have to wait until I have the house to myself though. Mama-bear (GF) doesn't appreciate fine subwoofers.
    Pioneer SC-37
    RTiA9-fronts
    CSiA6-center
    RT55i-surrounds
    SVS PB13 Ultra & PSW650
    Monster Power 3250 amp
    Monster Power 2250 amp
    Monster Power HDP-2500 surge pro.
    Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust
  • danz1906
    danz1906 Posts: 5,144
    bassaholic wrote: »
    Congrats.........Its a awesome sub:D
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Sherardp
    Sherardp Posts: 8,038
    Congrats and let me know your thoughts compared to the plus 2.
  • thsmith
    Nice ! A couple of acoustic panals and bass traps would be a nice addition.
  • bassaholic
    A word to describe this sub. WOW. I have been without my PB12+2 for a little over a month. After playing songs ( I haven't played any movies yet) from various artists from (Toto- Bone Thugs&Harmony) using the factory settings this sub is right on. Not that the PB+2 was sloppy but IMO the Ultra is much more tight, accurate and in your face when you want it to be. The bass is unbelievable and I had the gain set a little past 12 o-clock. I can't imagine running two of these. I was a little reserved about getting this due to the single as opposed to 2 woofers and smaller amp. Ron at SVS emailed me and basically said...no worries I won't be disappointed. That was an understatement. I couldn't be happier. This sub comes highly recommended and to be honest... again IMO. This sub runs circles around my old PB12+2.
    Pioneer SC-37
    RTiA9-fronts
    CSiA6-center
    RT55i-surrounds
  • thsmith
    If you have REW or something like it to find best placement and use the PEQ filter assuming one is all you need. It will sound even better. If you need more than one filter then use a BFD 1124
  • Ron Temple
    Ron Temple Posts: 3,212
    Mine is one of the first off the line 2 years ago. It's a wonderful sub and a joy everyday. Yours has been improved, both the driver and the amp. Enjoy. While the output of the Ultra is similar to the /2+, there's no comparison with it's impactful midbass, deep bass and minimal ringing. Get it dialed and calibrated, it will (probably) never disappoint.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • danz1906
    Ron Temple wrote: »
    Agreed, the Ultra-13 is a great subwoofer:)
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • beardog03
    beardog03 Posts: 5,550
    you guys are makin me want to sell my PC-Ultra and get the new 13 !!!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • danz1906
    beardog03 wrote: »
    Go for it!:D
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • beardog03
    I`m on a quest for tubes right now !!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • landry_p2000
    landry_p2000 Posts: 1,313
    bassaholic wrote: »
    Man that is a thing of beauty! Nice!
    Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
    Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
  • danz1906
    beardog03 wrote: »
    Tubes Rule! Good luck with your search.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • speakergeek
    speakergeek Posts: 555
    Nice sub there!
  • danz1906
    bassaholic wrote: »
    Mannnn, that Gloss black looks Awesome!
    Now I want a Gloss black Ultra-13:p
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • danz1906
    bassaholic wrote: »
    Did you get a chance to make it RUMBLE?:)
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • bassaholic
    danz1906 wrote: »
    See post 69.
    Pioneer SC-37
    RTiA9-fronts
    CSiA6-center
    RT55i-surrounds
  • danz1906
    bassaholic wrote: »
    Sweet, SVS has a Winner with the Ultra-13-Enjoy!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • gelinas
    gelinas Posts: 226
    bassaholic wrote: »
    I've wondered this same thing myself. It is amazing that a single 13.5" ultra can outperform dual 12's.
    Kudos to SVS.
  • danz1906
    gelinas wrote: »
    Kudos to SVS.
    WElcome to the Club!
    The SVS PB-13Ultra is very impressive:D
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • gelinas
    gelinas Posts: 226
    thanks for the welcome. We've had our ultra for almost a year now and I have loved every moment. My wife is learning to like it.
    Our neighbors......thats a different story.
  • Sherardp
    I really want to sell both my +2s and go for dual Ultras. I know the impact would be sick. Shipping kills the deal but I will check with SVS again and see what they can work out. I have been wanting these for awhile. How is the Ultra relative to size compared to the +2? Roughly same size or smaller footprint?
  • danz1906
    gelinas wrote: »
    I have a Rosenut finish Ultra-13,which do you have?
    I really like the look of that Gloss Black:cool:
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • danz1906
    Sherardp wrote: »
    Two Ultra-13s would be CraZY Awesome. The 13 is pretty big!
    Size: 27” D x 20.5 " W x 22" H (w/o grill)
    Santa may bring me another Ultra-13 for X-mas if lm good:p
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • Sherardp
    danz1906 wrote: »
    Your one lucky guy. I want to hear them so bad.
  • bassaholic
    Sherardp wrote: »
    The ultra is 1" wider and about 4" shorter than a +2. I highly recommend the new 13 not only for the sound but because it looks so much better than a +2.
    Pioneer SC-37
    RTiA9-fronts
    CSiA6-center
    RT55i-surrounds
  • danz1906
    bassaholic wrote: »
    Agreed, on the Looks:)
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • gelinas
    gelinas Posts: 226
    danz1906 wrote: »
    Ours is rosenut as well. It's the best color in my opinion. While it doesn't completely match our cherry Polks it blends in just fine. I also much prefer it's looks to the Plus 2, I love looking at the driver when it's really moving, or even when its sitting still. Here's a couple pictures of our minature schnauzer snuggling up to it (he doesn't go near it when there is a lot of air flowing out of the ports...)
