SVS PB-13 Ultra Subwoofer
What do you think about corner placement of the Sub?
You typically will get more gain but depending on your room it may not have the best sound. Need REW or something like it to find best placement to remove as many dips as possible and then EQ to clip the peaks.Speakers: SDA-1C (most all the goodies)
I wonder what kind of correctly setup single sub will sound better than duals that are setup correctly.
IS that even possible ? duals setup correctly will have more output than a correctly setup single. I guess it depends on what you are trying to do.Speakers: SDA-1C (most all the goodies)
I ended up picking one the these up tonight. They're better looking in person than in pics. I am so curious to see how it will compare to the PB12+2 I just recently sold. Gonna have to wait until I have the house to myself though. Mama-bear (GF) doesn't appreciate fine subwoofers.Pioneer SC-37
RTiA9-fronts
CSiA6-center
RT55i-surrounds
SVS PB13 Ultra & PSW650
Monster Power 3250 amp
Monster Power 2250 amp
Monster Power HDP-2500 surge pro.
Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust -
bassaholic wrote: »I ended up picking one the these up tonight. They're better looking in person than in pics. I am so curious to see how it will compare to the PB12+2 I just recently sold. Gonna have to wait until I have the house to myself though. Mama-bear (GF) doesn't appreciate fine subwoofers.
Congrats.........Its a awesome sub:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Congrats and let me know your thoughts compared to the plus 2.Shoot the jumper.....................BALLIN.............!!!!!
Nice ! A couple of acoustic panals and bass traps would be a nice addition.Speakers: SDA-1C (most all the goodies)
A word to describe this sub. WOW. I have been without my PB12+2 for a little over a month. After playing songs ( I haven't played any movies yet) from various artists from (Toto- Bone Thugs&Harmony) using the factory settings this sub is right on. Not that the PB+2 was sloppy but IMO the Ultra is much more tight, accurate and in your face when you want it to be. The bass is unbelievable and I had the gain set a little past 12 o-clock. I can't imagine running two of these. I was a little reserved about getting this due to the single as opposed to 2 woofers and smaller amp. Ron at SVS emailed me and basically said...no worries I won't be disappointed. That was an understatement. I couldn't be happier. This sub comes highly recommended and to be honest... again IMO. This sub runs circles around my old PB12+2.Pioneer SC-37
RTiA9-fronts
CSiA6-center
RT55i-surrounds
If you have REW or something like it to find best placement and use the PEQ filter assuming one is all you need. It will sound even better. If you need more than one filter then use a BFD 1124Speakers: SDA-1C (most all the goodies)
Mine is one of the first off the line 2 years ago. It's a wonderful sub and a joy everyday. Yours has been improved, both the driver and the amp. Enjoy. While the output of the Ultra is similar to the /2+, there's no comparison with it's impactful midbass, deep bass and minimal ringing. Get it dialed and calibrated, it will (probably) never disappoint.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote: »Mine is one of the first off the line 2 years ago. It's a wonderful sub and a joy everyday. Yours has been improved, both the driver and the amp. Enjoy. While the output of the Ultra is similar to the /2+, there's no comparison with it's impactful midbass, deep bass and minimal ringing. Get it dialed and calibrated, it will (probably) never disappoint.
Agreed, the Ultra-13 is a great subwoofer:)Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
you guys are makin me want to sell my PC-Ultra and get the new 13 !!!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Go for it!:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
I`m on a quest for tubes right now !!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Man that is a thing of beauty! Nice!Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD -
Tubes Rule! Good luck with your search.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Nice sub there!
Mannnn, that Gloss black looks Awesome!
Now I want a Gloss black Ultra-13:pLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Did you get a chance to make it RUMBLE?:)Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Pioneer SC-37
RTiA9-fronts
CSiA6-center
RT55i-surrounds
bassaholic wrote: »A word to describe this sub. WOW. I have been without my PB12+2 for a little over a month. After playing songs ( I haven't played any movies yet) from various artists from (Toto- Bone Thugs&Harmony) using the factory settings this sub is right on. Not that the PB+2 was sloppy but IMO the Ultra is much more tight, accurate and in your face when you want it to be. The bass is unbelievable and I had the gain set a little past 12 o-clock. I can't imagine running two of these. I was a little reserved about getting this due to the single as opposed to 2 woofers and smaller amp. Ron at SVS emailed me and basically said...no worries I won't be disappointed. That was an understatement. I couldn't be happier. This sub comes highly recommended and to be honest... again IMO. This sub runs circles around my old PB12+2.
Sweet, SVS has a Winner with the Ultra-13-Enjoy!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
I've wondered this same thing myself. It is amazing that a single 13.5" ultra can outperform dual 12's.
Kudos to SVS. -
Kudos to SVS.
WElcome to the Club!
The SVS PB-13Ultra is very impressive:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
thanks for the welcome. We've had our ultra for almost a year now and I have loved every moment. My wife is learning to like it.
Our neighbors......thats a different story. -
I really want to sell both my +2s and go for dual Ultras. I know the impact would be sick. Shipping kills the deal but I will check with SVS again and see what they can work out. I have been wanting these for awhile. How is the Ultra relative to size compared to the +2? Roughly same size or smaller footprint?Shoot the jumper.....................BALLIN.............!!!!!
I have a Rosenut finish Ultra-13,which do you have?
I really like the look of that Gloss Black:cool:Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Two Ultra-13s would be CraZY Awesome. The 13 is pretty big!
Size: 27 D x 20.5 " W x 22" H (w/o grill)
Santa may bring me another Ultra-13 for X-mas if lm good:pLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Your one lucky guy. I want to hear them so bad.Shoot the jumper.....................BALLIN.............!!!!!
The ultra is 1" wider and about 4" shorter than a +2. I highly recommend the new 13 not only for the sound but because it looks so much better than a +2.Pioneer SC-37
RTiA9-fronts
CSiA6-center
RT55i-surrounds
bassaholic wrote: »The ultra is 1" wider and about 4" shorter than a +2. I highly recommend the new 13 not only for the sound but because it looks so much better than a +2.
Agreed, on the Looks:)Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Ours is rosenut as well. It's the best color in my opinion. While it doesn't completely match our cherry Polks it blends in just fine. I also much prefer it's looks to the Plus 2, I love looking at the driver when it's really moving, or even when its sitting still. Here's a couple pictures of our minature schnauzer snuggling up to it (he doesn't go near it when there is a lot of air flowing out of the ports...)
