Spearker cables..fact or fiction?
Well Ben I am disappointed -is this really the best you can do?? Fire away with a scientific / technical approach to my statements YAWWWWNNN:eek:
Seafire, quick question for you:
Could you please list all of the components in your rig, followed by a list of each type of speaker wire and interconnect that you have tested in this system?
Its a simple question; I just want to get a sense of how you reached your conclusions.
Norm2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects -
Uhuh doesn't matter how short the signal path is ..bottom line it is a foil thin track "breaking out into your male ego big is better cable syndrome which I again repeat) prove me wrong.Yes there will be a difference if you have normally functioning ears but you don't need multi dollar hype cables to achieve the same thing.Once you have nailed:) the short comings ie.distance resistance etc you still do not need multi dollar **** cables to achieve this!!comfortablycurt wrote: »Nice try. Actually I've barely spent any money on cabling before. I've just barely gotten started with my cable experimentation.
Thank you for saving me from spending MY money. You've completely convinced me that the differences I hear in cables are imaginary.
I state once again...what is this cable that doesn't change the signal path at all? Any wire is going to change the signal path, on the pure and simple fact that it is a device that is in the signal path.
Your reference to the micro thin wires on the PCB's are basically irrelevant...I see your point, but the incredibly short lengths of those wires compensate for the difference. Sure, the internal wiring of an amp is just plain wire the majority of the time. Those wires are also all of an inch long.
In case you didn't know, some people also upgrade these things too.
Why is it that people have to come in here and try to "save" us all? As many people have said, numerous times in this thread...If you don't hear/don't want to hear the difference, good for you. Those of us who do, are going to continue "imagining" the difference. Just let it go...you aren't changing anyones mind. -
Nice try :cool:I am telling you and the forum that if you use a basic good quality cable.ie oxygen free copper more than 12 gauge if you are more than 3 meters will be complete anything you here from there are short comings in the way electronic audio is presented to you today...micron pc board to thick cable..whatever..you sound like someone who spent a lot of money on cable without giving it thought BOTTOM LINE IF YOU CHANGE IT YOU HAVE FAILED =YOU HAVE ALTERED THE ORIGINAL SIGNAL PATH TO CONFIRM TO WHAT YOU THINK IS NICE!!.. sorry that **** doesn't work for me maybe you lost the thread a long the way:p
You're a moron.Political Correctness'.........defined
President of Club Polk -
Boring!!! stopped wasting my time on this crap about 10 years ago...they still stock and sell this **** in my friend's high end audio shop for guys like you that want to spend the money....in both our houses we use CAT 45 CABLE:rolleyes:MY rigs change by the month but I also have 30+ items I have accumulated over the years but speaker cable and connects YAWNNNNSorry adding something..I do not use grandads cheap sheilded cable for interconnects...I look for something cheap and decent sounding at a good price..then I spend my time finding 10% between various amplifiers cd players etc...INSTEAD OF DAYS TRYING TO FIND THE 0.0055% BETTER INTERCONNECT THAN I HAVE...GIVE ME A BREAKNorm Apter wrote: »Seafire, quick question for you:
Norm -
So, I can conclude from your post that you have not tried any cable that has come out within the last 10 years?2 Ch.
HT
Denon 2808ci AVR
I've always enjoyed 'tricksters' on both sides Sea....you're in the Indian Ocean??? Really? or is that an imagined location.
Also there seem to be two of 'you' one whose grammar and typos are premeditated to seem less than literate, or someone for whom Engilsh is a second or third language? And another...who seems quite capable of writing a decent English sentence. What's up with that? It certainly makes one suspicious as to whether or not you're pulling our leg.
I don't particularly care for cable discussions because they are, as I've said above, A NEVER ENDING STORY. Which this VERY thread 'proves'. I have yet to see a definitive ending to this...although 'you' seem quite sure you know where the end is.
Unless you happen to have a Ph.D. in solid state circuits and engineering (which I certainly do not) I just can't give you the final word you want me to. And, no, I don't own 100s or 1000s of dollars of I/Cs, wires, etc. So I have no stake in this debate!
Will the Real Seafire please sound-off!
Make me believe you're not just playing around!
thanks....
But what if we like our signal altered?????????????????????????
Cat 5 based speaker cables have been around for a while.
They have a following. And they aren't everyone's cup of tea.
As far as using cat 5, Beldon, AT&T, CDT/Nordex
are all big guys in the cat 5 market. You hardly need to survey
"local" It guys. It's available everywhere in the U.S.
It sounds like you've put a lot of thought into this. WAAAAY too
much thought. For most of us, a litlle research, trial and error,
and we end up with a suitable speker cable. As far as what
the recording should sound like, that is a subject that generates
more chatter than even cables do. We can pick out certain intruments
as sounding right, but overall presentation is up for grabs."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Wrong I hear that crap at least twice a month in my friends sound shopNorm Apter wrote: »So, I can conclude from your post that you have not tried any cable that has come out within the last 10 years? -
I still think you're a trickster! Right? (See above)
less filling!----tastes great! Damn this thread is entertaining!
Ok well you sound like my type of guy / girl I really dont care for your individual taste of what it sounds like/I can respect that ...but I am surely not going to spend thousands of dollars on cable so that I can hear Katie Meleue 1 foot forward hahahha:Dsucks2beme wrote: »But what if we like our signal altered?????????????????????????
as sounding right, but overall presentation is up for grabs. -
Damn, I'm so disappointed. I was hoping that you could point me in the right direction. I guess your not the man for the job. See, I wanted to know what you would recommend.Hi well you are in Charlotte North Carolina phone a local reputed IT company and found out what local cable is good ..usually they will have the tech specs.I am in the Indian Ocean ....right now I am using South African manufactured cable that would not be applicable to you;)~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Solder snot isn't wet, but I wouldn't put it in my nose!
thanks....
cnh
I really 'hate' quoting 'myself' don't you?Currently orbiting Bowie's Blackstar.!
Ok CNH
what is with the third world grammar? Well its 6am in the morning here and I'm not the worlds greatest typist,Are you referring to the fact that I make frequent typo mistakes well I don't know what your location is but I am fully schooled in the British higher education system.When i hit the keyboard i don't look up as I'm a two finger typist!.i usually have an assistant doing all my typo..sorry to disappoint you but it's the real me...anyway I'm off to work..enough of this crap -
I didn't. With a little shopping $175 for speakers cables, $100 per I/C.
And you would know what my taste in sound is HOW????????????
I don't recall seeing you in the room. You, sir, are an unknown.
We don't know you. You don't know us. You may know something
about sound. Or not. Please don't take that as an insult. But at this point
with about 65 posts you could be an asset to club Polk or our worst nightmare.
Either way, it's cheap entertainment to watch!"The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Ok CNH
Oh, a security guard, eh?VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Oh yes! not to be outdone...I used some washing line cable for my system the other day...have to say '' the tightly wound mild steel spring coil gave such superior noise rejection to our radio wave polluted sky waves man can you hear it the attack on those snare drums is so much faster....not to mention the expanded sound stage hear the depth wow:rolleyes:aawh GIVE ME A FRIGGEN BREAK:mad: cheers all SEAFIRE
speaker cables..... $100
IC cables.... $75
laughing so hard I pissed in my pants reading this thread.....Priceless! -
Spend your money on the part of an audio system that really counts...not some " rip off company" who has there product mass produced in China and sells it to fools for insane prices.sucks2beme wrote: »I didn't. With a little shopping $175 for speakers cables, $100 per I/C.
What do they say IF YOU CAN'TDAZZLE THEM WITH BRILLIANCE -BAFFLE THEM WITH ****!!!:D -
ic cables.... $75
laughing so hard i pissed in my pants reading this thread.....priceless!
:d me too -
Is it only security guards that go to work so early in your country?Wow no wonder you productivity and economy is up to ****:cool:inspiredsports wrote: »Oh, a security guard, eh? -
no because you dont have a d/a converter in your speaker!!:cool:hmmm maybe depending on how long your speaker cables are...glad to see you starting to ask valid questions
Seabass, err..I mean Seafoam,
Actually my question was in reference to a "digital" cable (see above); and actually it would work electrically, but not physically, as a 50ohm BNC connectors' collet won't properly fit a 75ohm female BNC.
I'm just bustin your chops. Nothin but love on this side of the table man...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
You're a moron.
They say one of the greatest talents a person can have, is the ability to say so very much, with so very few words. This is a talent you're very adept with Jesse...lol
This thread is hilarious...squirm non-believer...squirm.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
yeah yeah not that I really care but anyway they are both co axial the former not so popular anymore...I think I have frustrated some ppl but have also given some food for thought...been around in this game for many years and seen a lot of ****!Seabass, err..I mean Seafoam,
catch you later;) -
I like seafoam, the dude has me rolling. I take back anything mean I have said. Are we good homie? I'm serious, he's like the little brother I never had. Right, wrong or otherwise, you stand by your comments---and I DIG that about you baby.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
comfortablycurt wrote: »They say one of the greatest talents a person can have, is the ability to say so very much, with so very few words. This is a talent you're very adept with Jesse...lol
Yeah I hear you...fact is your still here reading the posts:D -
dont call me baby:di like seafoam, the dude has me rolling. I take back anything mean i have said. Are we good homie? I'm serious, he's like the little brother i never had. Right, wrong or otherwise, you stand by your comments---and i dig that about you baby. -
I'm good dude really enjoy handing out some stick like testing other peoples minds:D
Seafoam is outta here before I become seasplat....but listen to my tip of the week homie....try washing line cable you know the spring coiled one MAN it will blow your mind..the staging is outta this world
