Post a picture... any picture
Ken's Minions
Whoa what kind of twisted DNA comes out of that??
aprazer402 wrote: »
Been there, seen that.... -
Sorry but my toilet has never looked that bad..
Randy/Maine -
boston1450 wrote: »Im thinking your truck is the 6. So understand the settle in part. Not sure the 4 has enough ump to do that lol. That system you installed is way better than mine. How do you like it ? Would you do it again ? Mine was only 420.00 installed & alignment so I'm very happy. If I upgrade truck I plan on lifting to the sky. I see a 4doors lifted like 5-6 inches & drooled. I like the looks of Tacomas over Tundras anyways. My son-in-law talked me into buying this. He shitt when i bought the Taco & 4banger at that. It will never hit the mud. He has Tundra Ted pro sport or something like that. 55000.00 truck. Crazy
No it’s unlikely to settle any significant amount with spacers. I didn’t realize you were including the additional height from the tires. That makes sense. I had a 1” “Cornfed” spacer/leveling kit for about a year before I went with the full on suspension lift. Never had any issues and it maintained the stock ride. You can’t go wrong with the 4cyl unless you need to tow a boat. That engine is as reliable as they get.
My neighbor just bought a new Tundra TRD sport as well. Nice Truck. Has those sport tuned Bilsteins from the factory and oversized sway bars.
My 2/1 lift, the coil springs started out about an inch an a half higher than expected and it took about 1000 miles for them to settle in to the 2” front and 1” rear it was supposed to be. I really like the 6100 5160 combo with the matching Bilstein coil springs on all four corners. It got rid of the excessive brake dive I had on the OEM struts and improved handling as well; despite the extra height. The ride still feels close to original but a little firmer over broken pavement.
I also added FALKEN Wildpeak AT3Ws and ICON wheels, but kept the OEM tire size. The zero offset wheels gives it nicer stance IMO. The tires are still under the fenders which is what I wanted. I also added tubular upper control arms with more caster built in to ensure the alignment angles were still achievable. I did the install myself but had Toyota do the alignment after. Other things I added was a roof rack, the predator step bars were an add on, and the black badges.
My 4Runner is a 2018 SR5 because with 4 kids I need the 3rd row which isn’t available in any of the TRDs. I’d love a Tacoma though for the obvious utility of the bed. I do miss having a pickup. When my kids are older and driving I won’t need the seats and look forward to another truck.
Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
Haha... Not Canada
No, but we can see it from here on a clear day!
OK... almost. -
mhardy6647 wrote: »mhardy6647 wrote: »
Haha... Not Canada
OK... almost.
I listen to CJRT. Does that count?
jeremymarcinko wrote: »boston1450 wrote: »Im thinking your truck is the 6. So understand the settle in part. Not sure the 4 has enough ump to do that lol. That system you installed is way better than mine. How do you like it ? Would you do it again ? Mine was only 420.00 installed & alignment so I'm very happy. If I upgrade truck I plan on lifting to the sky. I see a 4doors lifted like 5-6 inches & drooled. I like the looks of Tacomas over Tundras anyways. My son-in-law talked me into buying this. He shitt when i bought the Taco & 4banger at that. It will never hit the mud. He has Tundra Ted pro sport or something like that. 55000.00 truck. Crazy
Your 4runner is beautiful. You have the wheels & step I like too. I put my cheap tube step on before I put lift on. It was 130 bucks I think. I knew when I ordered them I was going to change them out. At time I did NOT know I was going to lift it.Then I lifted it & added 10ply tires, now i want a step like yours. Wheels, I like the black with aluminium tips to break up the black like yours. Very nice. Btw the rack looks great.... Does the 4runner ride comfortable compare to the Tacoma ? I've heard the 4dr Tacoma ride better than AC long bed like mine. Maybe more like yours. Overall is there anything you don't like about the 4runner ? Do you drive in snow & how does it do ?..
Randy/Maine -
as seen Elsewhere (ahem, ASR, ahem)
boston1450 wrote: »jeremymarcinko wrote: »boston1450 wrote: »Im thinking your truck is the 6. So understand the settle in part. Not sure the 4 has enough ump to do that lol. That system you installed is way better than mine. How do you like it ? Would you do it again ? Mine was only 420.00 installed & alignment so I'm very happy. If I upgrade truck I plan on lifting to the sky. I see a 4doors lifted like 5-6 inches & drooled. I like the looks of Tacomas over Tundras anyways. My son-in-law talked me into buying this. He shitt when i bought the Taco & 4banger at that. It will never hit the mud. He has Tundra Ted pro sport or something like that. 55000.00 truck. Crazy
There isn’t much I don’t like about it. The fuel mileage isn’t that good 17/20mpg because of the 4.0v6 and 5spd auto. Toyota has been using this combo for over a decade so it’s not as efficient as some of the competitors. It works well though and has proven its reliability. The OEM SR5 ride is very comfortable not near as firm as the Tacoma, but does tend to dive under normal braking more than most would want. The Bilstein struts fixed this. Unlike most other mid size SUVs it’s still built on a truck frame which I like and it feels like a truck. Like you with your Tacoma I like the 4Runner more now than when I bought it. I needed 3rows but didn’t want a car crossover or a minivan. The Tahoes and Expeditions were too big to allow both the wife and I to park in the garage easily. The 4Runner had all the things I needed, space, a true 4wd, tow package. After having it for two and a half years I love how versatile it is. We’ve taken it camping several times, it goes fantastic in the snow, hauls all of us when I need it to, and the rear seats hideaway wonderfully when I don’t need them. I’ve used it to pull trailers and stumps. It doesn’t have a lot of modern tech and it’s on a chassis Toyota has been using well over a decade. Those things don’t bother me though and I’ve actually grown to like that. Did I mention the rear window rolls down too. It’s nice to put all the windows and back glass down and the sunroof back and just go drive. It’s a Jeepish feel, but not quite.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
hoarfrost.
it was one degree F when we got up this morning.
Sunset (well, almost -- since the hill obscures the horizon to the southwest) on Thursday (Dec. 17) after the snowstorm.
KennethSwauger wrote: »
A Nakamichi 1000 and an AKAI 8 track cartridge deck. Cool. -
Thank you kindly for all the info. It may make me change mind as I like SUV's & have trucks now. I miss my XC90 & wish i hadn't sold it now. Too many vehicles & ins is killing me. Thanks again. Happy Holidays to you & your family.
Randy/Maine -
Wow, old age! I glanced at ^^^ this before I had my glasses on. I thought it looked like a drive-in car hop tray with a soda and a glazed donut at the bottom. Carry on!
Probably safe to bring that hummingbird feeder in.
Winter time in Florida.
You should be on television.
That's actually rime (as in "of the Ancient Mariner") on that hummer feeder -- at least if teh interwebz are to be believed. Rime tends to form on one side as opposed to all around... although rime also tends to be chunkier than frost/hoarfrost. Again, this is all according to teh webz.
This... this is definitely rime:
I thought the technical term was Roan. Tomato tomoto...Gustard X26 Pro DAC
Just took this shot from my phone of "The Great Conjunction" on my balcony in Cabo. Can't see it from the picture but with my Nikon 12x 50 mm binoculars I could see the rings of Saturn and 5 Moons of Jupiter. Way cool!
That is so awesome. That thing has a better zoom than my telescope. I also was looking at Jupiter and Saturn last night. I can see any rings on Saturn but could easily see 4 of Jupiter's moons.
In Cabo right now? Nice..... doing any fishing?
We had a good look last night (when it was brilliantly clear and the crescent moon not too bright) with Mrs. H Swarovski spotting scope. Even by eye the viewing was good, although Saturn's none too bright at this point.
Tonight we've got clouds.
I did take some photos last night with a 300 mm zoom on my DX format DSLR (about equivalent to 450 mm on full-frame 35 mm format, if memory serves). I had to manually focus (which was nontrivial) and I did a lousy job -- I also bracketed the exposure extensively (and manually), but not especially well.
Still, at least you can see 'em both.
Crescent moon and a passing airplane last evening.
Great shots Mark.
Have a Waborita for me..
