Dreadnaught Avel-Lindberg 1000VA Transformer Group Buy?
  • dhlogic
    dhlogic Posts: 26
    Frank left off the end bell on those Neutrik connectors. Pretty cheesy, IMO.
    I'm not sure exactly what you mean. Could you explain further?
  • westmassguy
    westmassguy Posts: 6,850
    The End Bell is there, he just added heat shrink tubing with his company name on it.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • dhlogic
    dhlogic Posts: 26
    Yeah, nothing is missing from the connectors. When you mentioned the end bell, I assumed you were referring to the same part that Neutrik calls the housing on their instructions/drawings, but I wasn't 100% sure.
    The SPX and STX series of connectors do look different as they have an overall longer housing as compared to the FC series, and with these being covered in heat shrink it might have made them look different than what you were expecting at first glance.
    Why did I go with the FC series? Mostly cable size flexibility. The FC series comes in 4 and 8 pole options only and I know I planned on using only 2 of them. But, the FC series comes with two separate strain relief chucks. These chucks go inside of the housing/bell end, allowing it to handle cables from 6-15mm outer diameter. I don't think the length the housing really has anything to do with strain relief either as that is handled by the chuck inside of it.
    The SPX series only has 2 and 4 pole connectors and they only come with one chuck for strain relief. The 2 pole NL2FX is suitable for cables from 6-10mm and the NL4FX is for 7-14.5mm.
    The STX series are all metal construction and I didn't feel for my application the benefits would be worth the added price.
    I could have asked for specific dimensions of the cable from Frank, and asked for the appropriate SPX series that would fit, but decided to go with the connector that gave me the most options. I also suppose having 2 strain relief chucks covering nearly the same range of cable diameter instead of 1, provides better strain relief performance as each can be more specialized to its particular range of diameter than a compromise covering the whole range.
    Anyways, it will be awhile before I listen to them, but I am pleased with their construction.
  • agfrost
    agfrost Posts: 2,421
    Yeah, the end bell of those NL4FC's is truncated compared to the NL4FX, and/or the blue colored ring is in a different place on them.
    Jay
    F1nut Posts: 49,834
    Yep, you and David are correct. My apologies to you and Frank. I missed that it was the 2 pole type. I prefer the 4 pole versions that are rated to handle high current.
    Toolfan66 Posts: 16,945
    What part numbers did you use Jesse?
    F1nut Posts: 49,834
  • vmaxer
    vmaxer Posts: 5,116
    nspindel wrote: »
    Hey guys, just saw this thread pop up, with just about all the info you'll need to wire up your Dreadnought. So I figured it'd be handy to post a link to it:
    http://www.polkaudio.com/forums/showthread.php?160494-Dreadnought-Assembly-Questions
    Well, I guess the links created in the old version don't work now....
    I was going to look at this one, no workie, BUMMER!!¡¡
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,116
    vmaxer wrote: »
    nspindel wrote: »
    Found it, see if this works.
    http://forum.polkaudio.com/discussion/comment/2041163#Comment_2041163
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    F1nut Posts: 49,834
    Toolfan66 wrote: »
    So you used a four pole but only used two of the poles?
    Correct
  • dhlogic
    dhlogic Posts: 26
    The connector I'm using is a 4 pole connector as well, but it and the socket I'm using are rated to 30A rms, unlike the higher rated ones F1nut is talking about. Those are rated 40A rms continuous and 50A rms at a 50% duty cycle.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited August 2014
    vmaxer wrote: »
    It sucks that I have to redo all of my forum thread bookmarks.
  • vmaxer
    vmaxer Posts: 5,116
    vmaxer wrote: »
    Yes it does, bet that would take a minute. :o
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Toolfan66 wrote: »
    Correct
    Thanks!!
    Fred,
    I got yours drilled out for binding posts today, it will ship out tomorrow...
  • drumminman
    drumminman Posts: 3,396
    Thanks Larry!
  • dpowell
    dpowell Posts: 3,056
    What type of screws do you recommend be used to attach the Neutric plugs to the dreadnaught case? Do you pre-drill the holes for the screws?
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, ADCOM GFA 7807 + 5400, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
    F1nut Posts: 49,834
    edited August 2014
    The screw holes in the Neutrik are designed for 3mm (3M) screws. I used stainless steel Philips flathead screws, lockwashers and nuts from Fastenal.
    Yes, you have to pre-drill the holes.
  • stogie
    stogie Posts: 230
    I was able to get the above mounting hardware from the local Ace Hardware.
    Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
    Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
    Power Amp: Sunfire Architect's Choice Series II
    Preamp: Adcom GFP-750
    SACD/CD: Oppo BDP-95
    Tuner: Sansui TU-717
    TT: Technics SL-MA1
    Phono Pre: Emotiva XPS-1
    Music Server: Mac Mini w/JRiver - iPad w/JRemote
    DAC: Eastern Electric MiniMax Plus
    Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
  • dpowell
    Without having to go read 15 pages of thread and re-live the stupidity of the former name-calling member, what is the ETA for the tranny's? I have a very lonely dreadnaught box that keeps asking.
  • dpowell
    Found it. ~10 weeks.
  • vmaxer
    vmaxer Posts: 5,116
    dpowell wrote: »
    From when???? What is the delivery date???
    Can't wait to try this out!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • nspindel
    nspindel Posts: 5,343
    I made the first payment on July 30, so figure 10 weeks from there is October 8. I'll call Melanie if we don't hear something by end of the month, to see if they have a shipping date.
  • vmaxer
    vmaxer Posts: 5,116
    nspindel wrote: »
    Thanks a lot, I can be patient, but anxious at the same time..
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • drumminman
    Believe me, it's worth the wait.
  • nikonik
    nikonik Posts: 120
    Just read the entire post as Im trying to learn more about all the mods or recommendations by all those that contribute to this forum. Im learning and will eventually consider one of these transformers the next time there a group buy. For now, I have to get my post count up and learn from the experts.
  • nspindel
    Good news to pass along. Just heard from Melanie that these should ship by end of next week!
    Also - Voltz and MrBuhl, Melanie confirms that you guys have done a buy/sell of this unit, and it will ship to MrBuhl.
  • Moose68Bash
    Moose68Bash Posts: 3,842
    edited September 2014
    Bravo!
    Thank you, again!
  • voltz
    voltz Posts: 5,384
    awesome Thanks Neil :)
