HELP! Problem w/browsing Club Polk
123457»
  • Serendipity
    Serendipity Posts: 6,975
    edited October 2007
    audiobliss wrote: »
    You always just use the start menu?
    That's what I do, don't know about Trey.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Serendipity
    edited March 2008
    ARGH!
    This problem is back again! Last time I uninstalled some programs and it went away...but I didn't install anything recently and this damn thing is back!
  • cnjvh
    cnjvh Posts: 253
    edited March 2008
    Didn't read the whole thread but:
    http://support.microsoft.com/kb/899811/
    No earth robot is going to tell ME which button to press!!
    --Stuff--
    Front: Polk Audio RTi12
    Center: Polk Audio CSi5
    Surrounds: Polk Audio RTi8 (x4)
    Sub: SVS PB10-ISD (Dual)
    AVR: Denon AVR-3805
    Blu-Ray: Panasonic BD30
    Display: Sony KDL-55NX720B
    STB: Xfinity X1DVR
  • Serendipity
    edited March 2008
    Hmm, I think I have those hotfixes installed already...the patch seems to be from November 2007...
    Why is it that I only experience this when browsing the forum?
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited March 2008
    Maybe because there is nothing Polk in your signature?
  • Serendipity
    edited March 2008
    RuSsMaN wrote: »
    I think I'm going to buy a Polk XRT12 soon...
  • Face
    Face Posts: 14,340
    edited March 2008
    I'm not going through this whole thread. Do yourself a favor, dump IE, FF is the way to go.
  • Serendipity
    edited March 2008
    I finally got rid of Symantec AntiVirus though, since so many of you were saying it's crap.
  • Serendipity
    edited March 2008
    Face wrote: »
    Hey,
    In your email today you told me to reformat the computer and start over. Do you think this really requires it? Seems like a minor problem except the fact that I have difficulty installing/uninstalling programs AND the occasional freeze-ups...
  • nms
    nms Posts: 671
    edited March 2008
    appadv wrote: »
    Hey,
    Your bizarre and random problems are probably symptoms of a deeper underlying instability in your system. If you really want to make sure it's fixed, wiping and re-installing is the best way to go (and there are other advantages, like making your computer run faster). However, if you don't want to go to the trouble to re-install, you can probably force a work-around and live with it.
    With the proper precautions, re-installing an OS is not really that difficult or dangerous (to your data). It will probably take a couple of days after re-installing to get all your programs and options re-setup. If you're interested, I have some tips to help make it go smoothly :)
    My system
    "The world is an ever evolving clusterf*ck." --treitz3
  • Serendipity
    edited March 2008
    Hmm, if I *have* to do a reinstall, I'll do it, but I don't really want to. Instead I've been trying to find whatever is the culprit (I've already uninstalled Symantec AntiVirus, but that didn't help)...
    These are the programs that are currently installed on my system, aside from the AntiVirus I haven't changed anything else. Would you recommend uninstalling any of these? I don't know what "J2SE Runtime Environment" or "Viewpoint Media Player" is, either.
  • nms
    nms Posts: 671
    edited March 2008
    Damn man, running a pretty minimal system!
    click on: start>run>type "msconfig" and go over to the startup tab and take a screenshot if you wouldn't mind.
    The J2SE is Java, don't un-install that, I doubt it's your culprit.
    What version of IE are you using? Or if you're not using IE, what browser and version?
    My system
  • Serendipity
    edited March 2008
    nms wrote: »
    Here ya go:
    I'm using IE6, but people have been telling me to upgrade to Firefox so I might try that. Now WTH is this Viewpoint Media Player?
  • nms
    nms Posts: 671
    edited March 2008
    IDK what Viewpoint MP is - never heard of it.
    Did you try the hotfix in the link to MS's website? It sounds like that might fix your problem.
    At this point I would recommend upgrading to IE7, BUT DO THIS AT YOUR OWN RISK! I upgraded on a previous install of windows and it permanently killed a video editing suite I had - even after un-installing IE7 it was still broken.
    To me, it sounds like the problem is in IE6, so upgrading to 7 should take care of your problem. But first I'd try the "hotfix" from Microsoft.
    My system
  • Serendipity
    edited March 2008
    IE7? Ha, tried installing it already and it sucked!
    appadv wrote: »
    So - I wake up, go to class, come back to my computer and find it stuck on the portion that says "backing up files." It was still installing IE7. So I wait 30 minutes and find the system completely frozen.
  • nms
    nms Posts: 671
    edited March 2008
    appadv wrote: »
    Ah, ok. Tried the hotifx? (sorry for sounding like a broken record)
    My system
  • Serendipity
    edited March 2008
    Computer froze before it fully installed. But at least I got up to the point in Windows Update where it says "You need to install an ActiveX Control" or something like that...
  • SKsolutions
    SKsolutions Posts: 1,820
    edited March 2008
    Fire
    Fox.
    -Ignorance is strength -
  • Serendipity
    edited March 2008
    Fire
    Fox.
    I'm having difficulty installing anything...looks like time for a reformat :(
  • SKsolutions
    edited March 2008
    I would try, in order:
    First in msconfig, enable all services/standard boot
    1. Try the simple restore feature first
    2. Some AV software and other programs track registry changes and can be rolled back (reset)
    3. Try the 'R' function in the reinstall disc (your music, ****, and files stay :D ) only Windows gets overwritten.
    3. Backup partition on certain models
    4. Clean install
    Additional reason to never use IE: It is too much a part of the OS. If you F-it up, your OS is F'd up, and that's not nice for most people.
    Hope you can get it worked out. I love a fresh install, but the 'R' function in XP works really well while saving your stuff.
  • Serendipity
    edited March 2008
    4. Clean install
    Crap, apparently I turned off System Restore for some reason a while back so there goes Option # 1. And I recently uninstalled my antivirus software because people were telling me Symantec sucks.
    So, are there any other options besides # 3, and 4?
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited March 2008
    Sell your computer, fix your projector. Problem solved.
  • Serendipity
    edited March 2008
    Thanks for the constructive reply.
  • SKsolutions
    edited March 2008
    The 'R' function will keep most of your files. Otherwise, backup and clean slate. . . or Marks suggestion.:D
  • Serendipity
    edited March 2008
    I have two HP System Recovery discs that came with the laptop. Will those work?
  • SKsolutions
    edited March 2008
    If it has a copy of XP on it, which it should. Do a search on the Repair [R] function of XP to get some instructions. Should be fine, no backup needed unless you want to really make sure you save something. In that case, copy and burn it to CD. Good luck.
  • Serendipity
    edited March 2008
    Well, I have a lot of important files on this laptop. So I'd rather go with the repair method. The interesting thing is, the system hasn't crashed or anything like that - I use it everyday to do my homework and type up papers, and Word works fine.
    Most of my problems are with IE closing in the middle of a session :(
  • Serendipity
    edited March 2008
    I tried putting the CD into the laptop, yet it says "A version of Microsoft Windows is already installed on your computer."
