HELP! Problem w/browsing Club Polk
There is no bloatware on you machine. Other than symantec.
So all the HP junk isn't a problem?
It's very tempting to just uninstall the HP widgets.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
This is all I've used on my desktop for a long time with no problems. Free Tenebril Spy Catcher Express
Im not seeing whatyour seeing, according to the add/remove screen, there is no memory hogs other than Symantec.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Are you downloading AVG and windows defender? Are you uninstalling Symantec?Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Switch off transitions in IE,
goto IE Tools, Internet Options, Advanced Tab, uncheck 'Enable Page Transitions' under the 'Browsing' section. -
I was thinking the exact same thing, but updating to IE7 should fix thisMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Do you have spybot search & destroy and Ad Aware? If so, run them.
Another option, keep an eye on processes that "ignite" when this happens. They'll blink like christmas trees. Then look at the file name of the process, and see if it's legit.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
When uninstalling Symantec, after first disabling auto-protect, during the uninstall process the computer freezes. Interesting that this computer never had this problem before attempting to install IE7.
When trying to install Windows Defender, an error message pops up that says the following:
"Unable to proceed with installation
The Background Intelligent Transfer Service is disabled."
I also can't install AVG without first removing Symantec.polkaudio RT35 Bookshelves
Oh well, now I've got to use this school computer...
Laptop was fine until I tried to install IE7.polkaudio RT35 Bookshelves
Theres alot more wrong with that laptop, obviously.
Just unistall the IE7 , if you installed it. And put everything back to how it was before. What you need it a XP reinstall disk.
If its not letting you install or uninstal anything, then there are major problems..Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
I put everything back to how it was before, and now everything is fine. Except for the occasional SysFader.exe that appears when browsing Club Polk.
The problem with not being able to install/uninstall anything only happened after attempting to install IE7, before that everything was fine. (except for the SysFader.exe popups)polkaudio RT35 Bookshelves
Sysfader, should not pop up at all. I would find a reinstal disk and run a repair. Bu if you happy with the way it is,,,,ok
There should be no problem installing IE7, AVG and windows defender, if there is , then there is a problem..
Im sorry I couldnt helpMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Did you try this yet? -
Yes, it worked fine for a while but then the problem came back:polkaudio RT35 Bookshelves
It's starting to do this a lot again...
At one point it worked fine for a whole 3 hours, now it's all the time:polkaudio RT35 Bookshelves
Do you have an idea what (possibly) could the problem be?polkaudio RT35 Bookshelves
Sysfader is a graphics issue. I would try reinstalling the graphics driver and see, but, if that wouldnt work, go into safemode and download IE7. Or reinstall IE6 in safemode, it might replace any corrupted files.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
When installing IE7 I also got the message:
If it is a graphics issue, could it be caused by using this laptop as a desktop?polkaudio RT35 Bookshelves
IE sux. Go FireFox.
Will that solve the problem?
I still think there is some kind of malware on this PC, do any of you guys know if any programs in my computer look suspicious?polkaudio RT35 Bookshelves
Nope, nothing looks out of place.
Try windows defender. In safe mode.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
When I tried, I couldn't get my internet connection working. Even in "Safe Mode with Networking."
I think it's because some HP network card drivers don't get loaded in "Safe Mode," along with the "HP Wireless Assistant" and other HP drivers.polkaudio RT35 Bookshelves
I still think there is some kind of malware on this PC,This is all I've used on my desktop for a long time with no problems. Free Tenebril Spy Catcher Express
I got ya, just having problems trying to uninstall Symantec before I can install a different anti-virus/anti-spyware program.polkaudio RT35 Bookshelves
Then dont uninstall, just disable.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
So I hear Ad-Aware, Spybot Search and Destroy, and Tenebril Spy Catcher Express are all good anti-spyware programs.
I will try to install all three.polkaudio RT35 Bookshelves
You dont need to. Just install AVG or Windows defender. Alot of those "adware" programs end up installing alot of other just too, expl: tool bars, home pages, buy this buy that..Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
AVG or Windows Defender didn't install, so I was thinking of either Ad-Aware, Spybot, or Tenebril.polkaudio RT35 Bookshelves
How can they not install? If you disable Symantec , then you can install, if thats whats trying to stop the instalation. If one thing can install, then anything could install..
But ok...good luckMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
How can they not install? If one thing can install, then anything could install..
But ok...good luck
Windows Defender locked the system up and said something about "Background Intelligent Transfer Service"
As for AVG, it won't install with Symantec still on my machine.polkaudio RT35 Bookshelves
