HELP! Problem w/browsing Club Polk
12467
  • Serendipity
    Serendipity Posts: 6,975
    edited October 2007
    jakelm wrote: »
    There is no bloatware on you machine. Other than symantec.
    So all the HP junk isn't a problem?
    It's very tempting to just uninstall the HP widgets.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • PolkThug
    PolkThug Posts: 7,532
    edited October 2007
    This is all I've used on my desktop for a long time with no problems. Free Tenebril Spy Catcher Express
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    appadv wrote: »
    Im not seeing whatyour seeing, according to the add/remove screen, there is no memory hogs other than Symantec.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    Are you downloading AVG and windows defender? Are you uninstalling Symantec?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • PolkThug
    edited October 2007
    Switch off transitions in IE,
    goto IE Tools, Internet Options, Advanced Tab, uncheck 'Enable Page Transitions' under the 'Browsing' section.
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    PolkThug wrote: »
    I was thinking the exact same thing, but updating to IE7 should fix this
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • steveinaz
    steveinaz Posts: 19,546
    edited October 2007
    Do you have spybot search & destroy and Ad Aware? If so, run them.
    Another option, keep an eye on processes that "ignite" when this happens. They'll blink like christmas trees. Then look at the file name of the process, and see if it's legit.
  • Serendipity
    edited October 2007
    jakelm wrote: »
    When uninstalling Symantec, after first disabling auto-protect, during the uninstall process the computer freezes. Interesting that this computer never had this problem before attempting to install IE7.
    When trying to install Windows Defender, an error message pops up that says the following:
    "Unable to proceed with installation
    The Background Intelligent Transfer Service is disabled."
    I also can't install AVG without first removing Symantec.
  • Serendipity
    edited October 2007
    Oh well, now I've got to use this school computer...
    Laptop was fine until I tried to install IE7.
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    Theres alot more wrong with that laptop, obviously.
    Just unistall the IE7 , if you installed it. And put everything back to how it was before. What you need it a XP reinstall disk.
    If its not letting you install or uninstal anything, then there are major problems..
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Serendipity
    edited October 2007
    jakelm wrote: »
    I put everything back to how it was before, and now everything is fine. Except for the occasional SysFader.exe that appears when browsing Club Polk.
    The problem with not being able to install/uninstall anything only happened after attempting to install IE7, before that everything was fine. (except for the SysFader.exe popups)
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    appadv wrote: »
    Sysfader, should not pop up at all. I would find a reinstal disk and run a repair. Bu if you happy with the way it is,,,,ok
    There should be no problem installing IE7, AVG and windows defender, if there is , then there is a problem..
    Im sorry I couldnt help
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • PolkThug
    edited October 2007
    PolkThug wrote: »
    Did you try this yet?
  • Serendipity
    edited October 2007
    PolkThug wrote: »
    Yes, it worked fine for a while but then the problem came back:
  • Serendipity
    edited October 2007
    It's starting to do this a lot again...
    At one point it worked fine for a whole 3 hours, now it's all the time:
  • Serendipity
    edited October 2007
    jakelm wrote: »
    Do you have an idea what (possibly) could the problem be?
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    appadv wrote: »
    Sysfader is a graphics issue. I would try reinstalling the graphics driver and see, but, if that wouldnt work, go into safemode and download IE7. Or reinstall IE6 in safemode, it might replace any corrupted files.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Serendipity
    edited October 2007
    jakelm wrote: »
    When installing IE7 I also got the message:
    If it is a graphics issue, could it be caused by using this laptop as a desktop?
  • PolkThug
    edited October 2007
  • Serendipity
    edited October 2007
    PolkThug wrote: »
    IE sux. Go FireFox.
    Will that solve the problem?
    I still think there is some kind of malware on this PC, do any of you guys know if any programs in my computer look suspicious?
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    Nope, nothing looks out of place.
    Try windows defender. In safe mode.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Serendipity
    edited October 2007
    jakelm wrote: »
    When I tried, I couldn't get my internet connection working. Even in "Safe Mode with Networking."
    I think it's because some HP network card drivers don't get loaded in "Safe Mode," along with the "HP Wireless Assistant" and other HP drivers.
  • PolkThug
    edited October 2007
    appadv wrote: »
    PolkThug wrote: »
  • Serendipity
    edited October 2007
    PolkThug wrote: »
    I got ya, just having problems trying to uninstall Symantec before I can install a different anti-virus/anti-spyware program.
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    appadv wrote: »
    Then dont uninstall, just disable.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Serendipity
    edited October 2007
    jakelm wrote: »
    So I hear Ad-Aware, Spybot Search and Destroy, and Tenebril Spy Catcher Express are all good anti-spyware programs.
    I will try to install all three.
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    appadv wrote: »
    You dont need to. Just install AVG or Windows defender. Alot of those "adware" programs end up installing alot of other just too, expl: tool bars, home pages, buy this buy that..
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Serendipity
    edited October 2007
    jakelm wrote: »
    AVG or Windows Defender didn't install, so I was thinking of either Ad-Aware, Spybot, or Tenebril.
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    appadv wrote: »
    How can they not install? If you disable Symantec , then you can install, if thats whats trying to stop the instalation. If one thing can install, then anything could install..
    But ok...good luck
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Serendipity
    edited October 2007
    jakelm wrote: »
    How can they not install? If one thing can install, then anything could install..
    But ok...good luck
    Windows Defender locked the system up and said something about "Background Intelligent Transfer Service"
    As for AVG, it won't install with Symantec still on my machine.
