HELP! Problem w/browsing Club Polk
Hmmm...Thought so....Get IE7
you can always unistall IE7 and go back to IE6 if it doesnt work
No, this didn't happen when installing IE7, it happened when I did the sfc.exe /scannow command and somehow the entire computer locked up.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Downlaod IE7
Are you still using windows 98?
Looks like it from your desktop.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Downlaod IE7
I'm using Windows XP. Windows 98 does not say "Files that are required for Windows to run properly must be copied to the DLL cache. Insert your Windows XP Professional Service Pack 2 CD now."
DUHHH....My badMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Doing a virus scan right now. When that finishes, will start downloading IE7.polkaudio RT35 Bookshelves
Good luck..hope it works...Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Finished the virus scan. Results attached. No spyware scanner though.
Going to download IE7 overnight.polkaudio RT35 Bookshelves
Looks like it's not a virus, or maybe it's one of them that avoids detection.polkaudio RT35 Bookshelves
As long as your antivirus was updated. It looks clear.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Cool, that's good to know.
Will find out if the problem is fixed when IE7 finishes downloading. It is a HUGE download.polkaudio RT35 Bookshelves
Did it work?Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
So - I wake up, go to class, come back to my computer and find it stuck on the portion that says "backing up files." It was still installing IE7. So I wait 30 minutes and find the system completely frozen.
Now what?polkaudio RT35 Bookshelves
Did it work?
Tried uninstalling whatever part of IE7 that did install, and under Add/Remove Programs Internet Explorer 7 is not listed:
So no, it did not install.polkaudio RT35 Bookshelves
Now what?
Sounds like a hardware problem. A video card or PS problem. Or a CPU heat problem. You PC miight need a good cleaning. When the air flow in the case or at the CPU is bad, things get too warm and start causing freezes.
Turn your computer off. Pop the case open clean and swop the RAM cards, check see if the CPU heat sink is clean. Restart computer.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Turn your computer off. Pop the case open clean and swop the RAM cards, just change one for the other. Restart computer.
It's a laptop.
Will post CPU temperature, fan speed, etc.polkaudio RT35 Bookshelves
At the top of add and remove programs..click Show UpdatesMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
It's a laptop.
A laptop....
Down load AVG and run it, to see if its a virus. If its not a virus I still think its a hardware issue so you will need to open the laptop to access the hardware.
Laptops are not as easy to trouble shoot hardware.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
From the BIOS:
CPU Temperature 33.5C / 92.3F
Fan Speed: 3389 RPMpolkaudio RT35 Bookshelves
Something is running or a peice of hardware is messed up, to cause a feeze up.
Lets start with software then to hardware.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
From the BIOS:
Fan Speed: 3389 RPM
Thats fine. Alittle warm but okMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Software - You think it's not spyware, why's that?
Hardware - No hardware errors in event viewer:polkaudio RT35 Bookshelves
Another great program is windows defender. With defender you can see excatly what is running at start up and current.
AVG and windows defender should do a better job than Norton. Lets make sure its not a software issue.
Download AVG free ware and Windows Defender.
Run both programs one after the other.
If computer freezes during scan, reboot in safemode. And run the scan in safemodeMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Would you say the freezes ocured at about the same time as the Dhcp warning?Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dhcp warning is a network card problem.... Or a general internet connection problem.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Maybe, but what bothers me is the amount of bloatware installed in this system from HP:polkaudio RT35 Bookshelves
The only bad thing in there is the symanctec software, That NEEDS to go. First disable it in processes then uninstall it.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
When was the last time you did an update for IE>????Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
You mean turn off the antivirus first then uninstall it?
I was thinking all that HP bloatware might be causing the problem...polkaudio RT35 Bookshelves
Yes turn it off first or it will never uninstall.
There is no bloatware on you machine. Other than symantec.
I have twice the software you do.. And my system is running great. Its not whats installed, its whats running..thats your plroblem. Symantec runs all the time.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
