HELP! Problem w/browsing Club Polk
Serendipity
Hi,
I'm getting this error message on my computer whenever I visit this forum. And then the forum window closes.
Anybody know what might be causing the problem?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
I clicked "OK" and all I get is the following:polkaudio RT35 Bookshelves
I assume you have powered off and back on? If so - try another brower (like firefox or opera) and see if you get a similar error. If they work, reinstall I.E.Mains.............Polk LSi15 (Cherry)
download mozilla, try again.
Yes, I have powered off and back on to no avail. I'd also like to point out that this does not happen on any other website, only when browsing Club Polk.
Forum software problem maybe?
It forces me off every time and I have to restart.polkaudio RT35 Bookshelves
nothing to see here"The secret of happiness is freedom. The secret of freedom is courage." Thucydides
Disc Jockey wrote: »you need to be logged in, otherwise the forum s/w has no idea how many posts you have.
eh? Can you elaborate a bit?polkaudio RT35 Bookshelves
bahh, wrong window, sorry. Was trying to answer somebody else"The secret of happiness is freedom. The secret of freedom is courage." Thucydides
Oh yeah it doesn't depend on whether I'm logged in/out, posting, or just reading.polkaudio RT35 Bookshelves
Try this:
Step 1
On the menu bar, click on 'Tools', then click on ‘Internet Options…’.
Step 2
In the window that pops up, go to the ‘Advanced Tab’. Scroll down to where it says ‘Browsing’.
Step 3
Uncheck the check box beside the phrase that says ‘Enable third-party browser extensions’.
Click on OK and restart Internet Explorer.
It also seems that this process is sometimes initiated by recent software or driver installs. Did you install anything recently? If so, you may want to try uninstalling it or going back to a recent restore point."The secret of happiness is freedom. The secret of freedom is courage." Thucydides -
Disc Jockey wrote: »Try this:
Step 1
On the menu bar, click on 'Tools', then click on Internet Options .
Step 2
In the window that pops up, go to the Advanced Tab. Scroll down to where it says Browsing.
Step 3
Uncheck the check box beside the phrase that says Enable third-party browser extensions.
Did that, but same problem. Also no, I did not install or change anything in the past 3 months on this computer. No new hardware either.polkaudio RT35 Bookshelves
As per going back to a recent restore point, I can't, because apparently System Restore was never enabled on this computer.polkaudio RT35 Bookshelves
Hmm, well I don't have much else to offer you. Maybe someone else will. Good luck."The secret of happiness is freedom. The secret of freedom is courage." Thucydides
Ouch:mad:"The secret of happiness is freedom. The secret of freedom is courage." Thucydides -
Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
I went to that website and looked at the instructions, and to my surprise, the animations were already DISABLED!
Now what?polkaudio RT35 Bookshelves
Please don't tell me it's spyware
scroll down to the bottom of that page, someone posted another method and claims to have workedReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
I looked at that method, but it only applies to systems with IE7.
That's why I'm still using IE6. Waiting until all the bugs are fixed.polkaudio RT35 Bookshelves
I'm starting to think it's spyware. Attached is the processes that are currently running on my system - I don't see anything suspicious but I'm not 100% sure these days.
What's weird is that I have a CPU Usage of 10% when the system is idle.polkaudio RT35 Bookshelves
I'm not sure what it is
Checked on Google: some say it is an Nvidia graphics file
http://www.processlibrary.com/directory/files/sysfader/Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
I don't have a nVidia graphics card on my laptop, only an Intel GMA915 onboard graphics.
Wait - all of a sudden I have a LOAD of processes running on my system, that weren't running before!
WTH?polkaudio RT35 Bookshelves
Have you started simple, and deleted all your temp internet files, cleared your cookies, and re-logged back in?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Yes.polkaudio RT35 Bookshelves
Totally puzzled - why are there 14 more processes running on my system after going on Club Polk?polkaudio RT35 Bookshelves
Somethings up. This might sound odd, but there doesnt seem to be enough precesses running.
IE7 is working great, I suggest getting it.
Under the visual effect tab...check off..let windows choose what best.
But I have been using IE7 for months now without a glitch. Just keep it up to date.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Huh? My system is functioning normally.
I think it could be spyware.polkaudio RT35 Bookshelves
Take another snap shot of processes..
I didnt think you had enough system or user processes running.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
No... I know that sounds wierd, but I don think so.
Get IE7Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Here ya go:polkaudio RT35 Bookshelves
WTH?
Now thats more like it.
Alot of those processes , that werent there, are needed...Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
