Well, I hope you guys are happy now....
15678911»
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited October 2007
    HTrookie wrote: »
    You would be amazed on how much static can build, and what a magnet it is for dust. Not necessary? You don't sound like yourself :p
    LOL. ..but does it work?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • cmy330go
    cmy330go Posts: 2,341
    edited October 2007
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • wingnut4772
    edited October 2007
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • hearingimpared
    hearingimpared Posts: 21,136
    edited October 2007
    Absolutely!!!
  • hearingimpared
    edited October 2007
    cmy330go wrote: »
    Couldn't show better proof than that one!!!
  • TroyD
    TroyD Posts: 13,124
    edited October 2007
    Well I disagree to a certain extent. I've learned how to soak the grooved area without getting it on the label. I feel that the more fluid the easier any dirt or dust particles can float to the top and be sucked off. I read in an extreme article about cleaning records that using the VPI record cleaning fluid in this manner is the best way to ensure that all the crap is removed and I've been doing it since. I've not done any comparisions, I just got into the habit of doing it. Needless to say, I go through a lot of fluid.
    If you would like me to email this article to you let me know. It is extreme but there is some very good info to be had.
    I think we are on the same page, I'm just saying if you are soaking the LP and it runs to the label before you can spread it accross the surface, I think it's too much. Plus, the groove aren't that deep so, you know, it doesn't take THAT much. I use enough that so two revolutions with the suction renders it clean and dry.....it just takes a bit of practice to figger out what's right for you.
    By all means though...send me the article...
    As I've said before, I use an MFSL brush to clean/scrub on the VPI and hit it with the Hunt brush before playing. I've never had an issue with static. YMMV.
    BDT
  • hearingimpared
    edited October 2007
    Troy, I sent the article last night via email.
  • Ricardo
    Ricardo Posts: 10,636
    edited October 2007
    Saw the zerostat demo.....mine is blue, any difference between the blue and the red????
    SOPA
    billbillw Posts: 7,532
    edited October 2007
    HTrookie wrote: »
    Shouldn't be a difference...
    Although, I've been told by a few people that have used both, that the older versions (from 70s/80s) of the ZeroStat work better than the newer ones. YMMV. I have an older one that came with a Discwasher Kit and it works pretty good.
    Overall, I think having a Zerostat is a must for vinyl listeners. I might not use it every time, but when that record comes out of the sleeve and you can FEEL the static, there is no quicker/better way to eliminate the charge.
  • wingnut4772
    edited October 2007
    I ordered one <sigh>. The blue one from Ebay. Ok. That's it no more.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • wingnut4772
    edited October 2007
    Is it ok to play records if they are slightly warped..?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2007
    Darla,
    As long as the stylus tracks and the arm is not jumping back and forth like a dog wagging its tail you will be OK, we are still taking members of Flattener Consortium if your interested......four spots left, HT Rookie is ramroding things, I have the Flattener right now and overall it is nice machine, has done a great job flattening about 3 out 4 records I have pressed in it.
    If you are going to be doing the used Goodwill/Swapmeet thing its a great idea.
    RT1
  • engtaz
    engtaz Posts: 7,669
    edited October 2007
    Darla,
    Sorry to be the bearer of bad news but vinyl is addictive. You aways want more.
    Great to hear you are enjoying the TT.
    engtaz
    engtaz
  • wingnut4772
    edited October 2007
    Well I am still having an issue with popping and static especially with the old records I have bought and it's extremely frustrating because the music itself sounds so much better than digital. That's my only gripe really...and I have been cleaning them with EVERYTHING Joe recommended.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • rskarvan
    rskarvan Posts: 2,374
    edited October 2007
    HTrookie wrote: »
    The red one makes the cat jump farther.
  • hearingimpared
    edited October 2007
    Unfortunately you must listen past the noise. When I find that a record is sounding that bad, I look for a fresher copy. There are some records though that are so awesome and they can't be replaced and you just learn to hear past the noise and enjoy the music.
    EDIT: Just to tease you; the higher up the chain of very very good cartridges you go the less affected by noise their reproduction is. It can get quite expensive but is well worth it. I've saved up my pennies for many many moons to get the cartridge I now own.
  • wingnut4772
    edited October 2007
    Grrrrrrrrrrrr:mad:
    LOL.:p All my new records sound pretty good after cleaning and a couple of the used. I think I will stick to new from now on though.
    I watched the Fremer DVD. He's a funny guy and it was pretty thorough. I think I could do a cartridge after watching it. I don't have a stylus gauge though. Any recommendations?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Ricardo
    edited October 2007
    Get it from Sorasaund (Joe will know the name of the guy); he'll give you a gauge and a zerodust for a bit over $100.
    SOPA
  • wingnut4772
    edited October 2007
    HTrookie wrote: »
    That and a good magnifying glass and I guess I would be set.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
    edited October 2007
    Grrrrrrrrrrrr:mad:
    Don't give up on old records. They can sound wonderful and they are a great bargain. Some sound better than others, some are almost unlistenable. Just don't pay too much for any older album that is unheard $2-$4 is the most I'll pay for any used record unless its graded from a pro record shop.
    You will probably find that the more you listen, the less the occasional static pop will bother you. Trust me. Just let yourself get lost in the music and quit being critical.
    SCompRacer Posts: 9,111
    edited October 2007
    HTrookie wrote: »
    SORAsound is his Audiogon name. His name is Mehran. Formerly of the West coast but now residing in Chicago, IL. High marks for this seller.
  • hearingimpared
    edited October 2007
    SCompRacer wrote: »
    AAAAAAmen on Mehran!!!
  • madmax
    madmax Posts: 12,434
    edited October 2007
    Keep collecting all the records you can, old and new.
    Different speakers handle pops and clicks differently. Different carts and tables often place all this noise off to the side or behind one of the speakers. Different phono pre's handle differently too.
    I have many records I considered un-playable due to noise. Some I can now play and no longer notice the noise that was present with past systems. Enjoy the music, not the system and you will find the little problems seem to take care of themselves.
    Vinyl, the final frontier...
  • wingnut4772
    edited October 2007
    I sent Mehran an email to see if he could hook me up with a starter kit for doing my own cartridge.
    How is the Zerodust? Right now I am using a little brush and a little bottle and it is awkward.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • reeltrouble1
    edited October 2007
    You putting eyeliner on or trying to actually clean the stylus...............
    get the zerodust it is the real deal.
    RT1
  • wingnut4772
    edited October 2007
    RT1
    LOL. Both! And when I mix up the two my eyes burn and my records sound like crap.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Ricardo
    edited October 2007
    madmax wrote: »
    In other words, keep those lousy records until you get old and your hearing deteriorates :D:D
    SOPA
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2007
    Snort....WAAAAAAAAAAAAAAAAAAAA!!!! Too funny Ricardo!
  • hearingimpared
    edited October 2007
    Ricardo wrote: »
    WAAAAAAAAAAAAAAAAAAAAAAA
    hey you traitor!:D
