Started my new custom SDA's today
  • ben62670
    ben62670 Posts: 15,969
    edited May 2007
    One thing that has kinda tickled me is that there is a 16mh inductor in each cab. So that looks like to me reading the schematics that 2 16mh inductors in parallel equal one 8mh inductor if the middle of the IC cable were attached directly to the amp ground.
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    ben62670 wrote: »
    The thing is when I watch movies I will be using the dim drivers for LFE.
    With the sonosub? This should be interesting. Might have a phase problem between the demension drivers (LFE) and the sub (LFE), being both are tuned to different Fr.
    Ben, you have one hell of a project.:D
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • WolfKiyoshi
    WolfKiyoshi Posts: 96
    edited May 2007
    First you have a beautiful daughter :D and second i suggest you lock your volume control somehow or fence the stereo in don't want your kids cranking it up the speakers look like they'll instantly rupture a child's eardrums :S but all of us here can take that kinda volume and still keep turning the knob to 11 right ;) but seriously those are are a pair of beasts! if they sound as good as they look you may need to build a new addition to your house cuz we will all be moving in with you for a while :D
  • Sami
    Sami Posts: 4,634
    edited June 2007
    Speakers look great. As far as piano black goes, why not add some wood look to them as well? Front piano black, sides veneered or something like that?
    ben62670 wrote: »
    They should of said 6.28 instead of pie*2.
    It's never a good idea to round up until the final result. It might not be a big difference in the end result but at least you know you're not rounding the wrong way. It's not really that hard to bit the pi on your calculator, is it? :)
    Even the windows software calculator has it, 2* pi = 6.283185307179586476925286766559. Took me three presses, 6.28 takes 4... :D
  • ben62670
    edited June 2007
    Sami wrote: »
    Smart ****:D Its just a little confusing to guys who might take it as some sort of variable instead of just entering a constant. The cabinets will stay MDF for a little while. I was actually thinking cherry or mahogany sides, and a mild textured black front and rear. My projector screen is right at the edge of my speakers, so I am kinda concerned about reflections from that.
    Ben
  • Sami
    Sami Posts: 4,634
    edited June 2007
    ben62670 wrote: »
    Then again, if you're looking at a technical article that puts in 3.14 instead of pi, it takes a LOT of credibility away. Besides, who doesn't know what pi is?
    ben62670 wrote: »
    Glossy is never a good idea with projectors, I'm having a minor issue with reflections with my LSi15's because of that but luckily nothing major. My suggestion was just to avoid totally black, adding wood (colour) would make them look much better.
  • jakelm
    jakelm Posts: 4,081
    edited June 2007
    They are all wrong Ben.. Start over...:p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited June 2007
    jakelm wrote: »
    I know I should have gone bigger. Maybe I can use these as surrounds:confused:
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited June 2007
    Come on lets go!!! Quit farting around...:eek:
    Where are the rest of the specs? Finish this so we can see damnit!!!:D :p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Deadof_knight
    Deadof_knight Posts: 980
    edited June 2007
    Nah just build 3 more one for center and the other two for surrounds oh yea and one more sonotube Yeah Yeah ! .....although you might need to call PSO to come out and add another transformer to the house with all the power your gonna need......
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • ben62670
    edited June 2007
    I have 200amps 20 feet from me. and anther 200amps 30 feet from me:)
    Now all I need is a ton of money for the equiptment:(
    Ben
  • Systems
    Systems Posts: 14,872
    edited June 2007
    ben62670 wrote: »
    You have the whole back panel,why not just mount the same number of drivers onto it and make it a full bipolar SDA.Bet thats never been done.:D
    Testing
    Testing
    Testing
  • ben62670
    edited June 2007
    GV#27 wrote: »
    I AM NOT BIPOLAR! I have compulsive disorder addictive dysfunction!
    Ben
  • engtaz
    engtaz Posts: 7,675
    edited June 2007
    Too funny?
    engtaz
  • ben62670
    edited June 2007
    I'm testing a new idea on coating for the inside of my cabinets. I was at Lowe's looking at different coatings to help deaden the cabs. What I came up with was driveway sealer. It is rubberized, latex based, and fume friendly. I did a test stick earlier today, and came to the conclusion i have to put 3 thin coats on with plenty of time to dry. On the last coat I will use the sealer as the adhesive for the poly batting. It does indeed help deaden the sound. I tested it on metal too. I compares well will dynomat. $25 a five for the better stuff.
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited June 2007
    Why not use this for the inside for the cabinet? I use this in my center and subs, works like a charm.
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=260-520
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited June 2007
    jakelm wrote: »
    I have almost 100 square feet to cover!
    Ben
  • cmy330go
    cmy330go Posts: 2,341
    edited June 2007
    How close are we to seeing the finished product?
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • ben62670
    edited June 2007
    cmy330go wrote: »
    About next weekend. I will be posting new pics as I go. I have the kids again today. They won't be totally finished as in painted, and veneered for a while. I will have to recoup from this project monetarily.
    Ben
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2007
    ben62670 wrote: »
    What are you estimating as break-in time?
  • ben62670
    edited June 2007
    At 1050 watts per channel clean, about 20 minutes.:D
    Edit
    Just checked on my driveway sealer test sample. No swelling of wood or problems bonding. I put it on very thick. As in I dipped a piece of mdf in the bucket just to see what would happen. I did this to over exaggerate any failures. It has passed the test.
    Ben
  • hearingimpared
    edited June 2007
    ben62670 wrote: »
    I said "break-in" not break-up!!!
  • ben62670
    edited June 2007
    I'll take it easy for a little while. Let them loosen up. I have too much time in these to screw them up.
    I crank my stuff pretty loud, but as soon as I see the distortion lights flicker it goes down a notch.
    Ben
  • hearingimpared
    edited June 2007
    ben62670 wrote: »
    This is where I think there is something wrong Ben. I crank my stuff up to pretty high levels too. Many times I've had to turn it down cause it would make my ears ring but I've never seen the distortion lights flicker or hear the amps give out or back off, ever. I think having plenty of overhead is imperative. Good clean headroom is a must in my book, more so than just outright high power.
  • ben62670
    edited June 2007
    Nothing wrong. Thats driving to levels above 115db at seating position. Everyone is different. My X wifes ears would be ringing at about 110db. I can handle up to 120db for a little while, but typically I like 110 for listening sessions. ;)
    Ben
  • engtaz
    engtaz Posts: 7,675
    edited June 2007
    What did you say eh. LOL
    engtaz
  • ben62670
    edited June 2007
    Oh the sweet sound of success!
    I tried using rubberized latex based driveway sealer for sound deadening.
    It absolutely works!
    I went out today, and banged on the treated end with a hammer.
    Thud thud thud
    Then I banged on the untreated end.
    Ring ring ring.
    Huge difference. It bonded well to. I just dipped the stick in the sealer knowing this is the best way to get the product to fail(peel/crack). It bonded very well. I am going to put a light coat on first, then a heavier coat. Last coat I will use to adhere the poly batting.
    Very happy. Very happy indeed!
    Ben
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited June 2007
    rock on
  • ben62670
    edited June 2007
    First coat applied. I am sweating like a pig, my lips are numb, and my head hurts. It is hot here, and humid. It took about a half gallon to do all four chambers. One good thing is it is drying quick.
    Ben
  • ben62670
    edited June 2007
    Last coat, and poly batting done. These F'ers are heavy. I am going to lay down now! :eek:
    Edit
    Two Gallons of driveway sealer does a 2 car driveway! Or one pair of crazy a$$ custom SDA's
    Ben
