The Dared SL 2000 modification thread
1234568»
  • HalfOhm
    HalfOhm Posts: 51
    This is one of the last ones made I believe. I think 2012. SMD resistors mostly. Different amount of Electro's & Poly caps.
    Mines a mess & quite dusty. Took it apart a couple months ago to get all the values (never had a schematic)..so I ordered & received all the caps about a month ago & just haven't found the time. They've all been desoldered & are hanging by a string. I have some V-cap Odams from another project I'll put on the input.
    It's still a great preamp. I had the earlier model but this one didn't give me the gain issues the older Dared gave me. I've had a few tube preamps, the one I'm currently using probably close to $3k with upgrades & the sound of the little Dared is just kinda special to me. I feel like you can't find this type of sound or presentation in modern gear.
    My favorite tubes were the Tungsram 5z4g & the German made Amperex e81cc PQ gold pins. I preferred the bass of the Tungsram over the soundstage of the Brimar rectifier. Rectifier really affects the presentation on this preamp.
    pitdogg2 Posts: 26,980
    Posting some hopefully higher res pics under the hood for you reference.
    This is the Audience cap version. Would still love to find out what type of remote this uses for the remote volume control, I believe it uses RF (Radio Frequency) signal for the remote control volume? You can see a red wire coiled up, marked ANT. on the board.
    Anybody here, can you look inside your remote and see if there is a FCC ID code inside the remote in the battery compartment and post it? That would help a massive amount. Thnx
    PS: Its sounds nice and quiet with vintage USA tubes & 5Y3G Rect.
    There are pictures on the net from days past where folks used a key fob to fix their original Dared remote. It fit right in the factory hold IIRC.
  • Soundsofmusic
    Soundsofmusic Posts: 3
    HalfOhm wrote: »
    Thank You HalfOhm for the reply, all the info and wonderful pic of the inside of remote; its very useful. And looking forward to seeing pics when you've finished servicing your 2000a
    I've been going down the rabbit hole about RF remotes and programming; it's a deep hole (and not my forte). The Dared has the PT2272-M4 Integrated Circuit chip in the amp, and a HS2262A-R4 in your remote. If this is the case, then the key fob freq could maybe be 433MHz, or a 315MHz; but there's more to it than just the frequency, theirs data streams, output flows.....etc.
    They're super cheap enough on the _Bay to try both. I'll report back, if one of them works.
    Thanks pitdogg2. I'll try a key fob, and if the preamp sounds as good as described with some of the recommended NOS tube & rectifier (I think I may have some stashed away). I may make a remote control case with my mill with key fob board inside.
