You’re doing it wrong…
"Aquadag"
That's what a Pikey calls his Golden Retriever.
....and our poster exits the room in fine fashion, pleased with himself for having made another fine post.....
Sal Palooza -
There is a whole Reddit subpage for that poorly worded question.mrbigbluelight wrote: »
Yes, that:s just what the Germans want you to believe 🤔
Sal Palooza -
There appears to be another 10% of undecided?"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Oh, it's not that they were undecided, it's because they displayed non-çompliant attitudes that did not conform to the approved narrative 🤔Sal Palooza -
10% got the correct answer which is 2. 90% failed algebra.SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub -
Jetmaker737 wrote: »
uffda!
I didn't fail algebra, but I got a needs improvement in reading comprehension!
It is not a simple algebra problem as some suggest. That only works if you ASSUME that Cost=Price. If not, then you have P = price and C = cost, then C = $1 + P/2. Not so simple.
Billbill, we're not using Canadian math here, please stick with the pure mathematicals.Sal Palooza -
Be careful there...we have some fine Canadian forum members here who might argue that the American math is to blame, what with all the Common Core hubbub from some years past.mrbigbluelight wrote: » -
^^^^ Is he about to jump?
"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GAThat's just the way it is ~ Some things'll never change ~ That's just the way it isAh, but don't you believe themBruce Hornsby -
From out in the field today
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
In some municipalities double trap systems are code to keep the sewer monsters where they belong. -
IF your plumbing is vented correctly then a double trap is not needed. Some older houses were not vented at all.
Maybe it was Sunday at 7pm and that was the only fittings on hand to make it work... I'm curious how they managed to seal the two upper halves of the white S trap together, and the one that is upside down will certainly leak where it joins the black trap. It's certainly not racist plumbing, at least.Enjoying the journey while never attaining the destination.
you can rest assured that it did in fact leak in multiple places :-p- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The “S” trap is prohibited under the Uniform Plumbing Code throughout the United States. This is because the “S” trap will siphon or suck water out from the trap which will end up releasing methane (sewer) gases into the home.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »The “S” trap is prohibited under the Uniform Plumbing Code throughout the United States. This is because the “S” trap will siphon or suck water out from the trap which will end up releasing methane (sewer) gases into the home.
Until the code was revised a few years later due to the resurgence of the sewer monsters. FWIW I preferred the outdated double trap to the filter system which sometimes doesn't stop the more agile ones. -
motorstereo wrote: »
Wonder which knot was used in the straps?Expect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
WOW !!
