You’re doing it wrong…
  • mrbigbluelight
    "Aquadag"
    That's what a Pikey calls his Golden Retriever.
    ....and our poster exits the room in fine fashion, pleased with himself for having made another fine post.....
    txcoastal1 Posts: 13,519
  • mrbigbluelight
    mhardy6647 Posts: 35,526
    my brain just divided by zero. :#
    billbillw Posts: 8,125
    There is a whole Reddit subpage for that poorly worded question.
  • mrbigbluelight
    billbillw wrote: »
    Yes, that:s just what the Germans want you to believe 🤔
  • jdjohn
    jdjohn Posts: 3,437
    There appears to be another 10% of undecided?
  • mrbigbluelight
    jdjohn wrote: »
    Oh, it's not that they were undecided, it's because they displayed non-çompliant attitudes that did not conform to the approved narrative 🤔
  • Jetmaker737
    Jetmaker737 Posts: 1,144
    jdjohn wrote: »
    10% got the correct answer which is 2. 90% failed algebra.
    jdjohn wrote: »
    uffda!
    I didn't fail algebra, but I got a needs improvement in reading comprehension!
    ;):#:blush:
    edited October 2024
    It is not a simple algebra problem as some suggest. That only works if you ASSUME that Cost=Price. If not, then you have P = price and C = cost, then C = $1 + P/2. Not so simple.
  • mrbigbluelight
    billbillw wrote: »
    Billbill, we're not using Canadian math here, please stick with the pure mathematicals.
    billbillw wrote: »
    Be careful there...we have some fine Canadian forum members here who might argue that the American math is to blame, what with all the Common Core hubbub from some years past.
  • motorstereo
    motorstereo Posts: 2,415
  • BlueBirdMusic
    ^^^^ Is he about to jump? :#
    Harry / Marietta GA
  • mrbigbluelight
    I bet his name is Floyd. 🤔
  • bcwsrt
    bcwsrt Posts: 2,651
    Maybe just admiring his work?
    Brian
    VR3 Posts: 29,708
    From out in the field today
    Gonna be the splash graphic in the next Harbor Freight sales flyer/email!
  • Willow
    Willow Posts: 11,343
    VR3 wrote: »
    Oreo piping... It's a new trend, look it up.
  • motorstereo
    VR3 wrote: »
    In some municipalities double trap systems are code to keep the sewer monsters where they belong.
    pitdogg2 Posts: 27,788
    IF your plumbing is vented correctly then a double trap is not needed. Some older houses were not vented at all.
  • newbie308
    newbie308 Posts: 836
    Maybe it was Sunday at 7pm and that was the only fittings on hand to make it work... I'm curious how they managed to seal the two upper halves of the white S trap together, and the one that is upside down will certainly leak where it joins the black trap. It's certainly not racist plumbing, at least.
    VR3 Posts: 29,708
    you can rest assured that it did in fact leak in multiple places :-p
    The “S” trap is prohibited under the Uniform Plumbing Code throughout the United States. This is because the “S” trap will siphon or suck water out from the trap which will end up releasing methane (sewer) gases into the home.
    Willow wrote: »
    VR3 wrote: »
  • motorstereo
    txcoastal1 wrote: »
    Until the code was revised a few years later due to the resurgence of the sewer monsters. FWIW I preferred the outdated double trap to the filter system which sometimes doesn't stop the more agile ones.
  • CGTIII
    CGTIII Posts: 1,271
    Wonder which knot was used in the straps?
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
    treitz3 Posts: 20,302
    WOW !!
