1…185186188190191…207
  • newbie308
    My turntable rig has been on the back burner since I introduced a streamer to my system, but my internet quit working, so I couldn't stream for a while. Last night I added an isolation platform under the turntable and I am blown away by how much it improved the sound quality. I thought my analog setup was near critical mass, but this isolation really improves the retrieval of details, channel separation, and the sound stage is more in focus. Amazing what a slab of butcher block and four dollar store rubber balls can do!
  • skipshot12
    skipshot12 Posts: 2,163
    edited September 2024
    Drove down to PS Audio to pick up my P1000.
    Gonna put her back in the system tonight and take out the Monster 3500.
    treitz3 Posts: 20,365
    Interesting. All of those outlets but with a 15 amp IEC PC. :o
    VR3 Posts: 29,752
    And the outlets are 20 amp outlets hehe
    That's cray-cray right there bro'. Photo was too small on the phone to even notice that....but that's even more interesting.
    Kind of bass ackwards, eh?
    VR3 Posts: 29,752
    I mean ultimately it is a 15 Amp device, why install 20 amp outlets? For an uninformed user this is kind of misleading.
    Does PS Audio even make a 15 amp upgraded outlet? I don't recall seeing one.
    But still...
  • newbie308
    newbie308 Posts: 845
    Furman does the same thing on their 15A IT reference. In fact, I think it has the same number of outlets.
    That's an isolated outlet, not a 20 amp outlet.
    VR3 Posts: 29,752
    Yeah those are 15 Amp outlets in the photo
  • agingboomer
    Yesterday I reinstalled the four MW drivers in my SDA CRS+ pair. They were all frozen when the speakers were delivered. Thanks to the skillful and generous ministrations of @lawdogg (many thanks again), they have been resucitated and are back in the business of delivering aural bliss. Right now, Ron Carter is plucking his bass in the middle of my living room.
  • skipshot12
    ^ Bahahaaaa,
    15 amp cord why all the outlets.
    Clowns... you made me raff.
    VR3 Posts: 29,752
    Not understanding your posts.
    I know of several amps that can draw well over 15 amps from the wall... So to have a conditioner designed to run all of that gear and an amplifier on a single 15 Amp outlet seems pointless to me?
  • Gardenstater
    Gardenstater Posts: 4,961
    Doesn't surprise me that they used their own PS Audio Power Port outlets which just happen to be 20 Amp outlets. I have one and it did improve my transient response and bass impact.
    So.........just make sure that the sum total of all the equipment you plug in doesn't exceed 15 amps in this case. Maybe they could have put some warning stickers at each outlet. -DO NOT EXCEED 15 AMPS DRAW TOTAL-
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Gardenstater
    ^^ Actually doing a little research it turns out the output is 1,000W maximum, which I should've realized from the model name "P1000". Lots of power storage in 16 3,300 uF capacitors I would imagine, to handle short term peak draws. Does it put out more than 1,000W short term because of that? PS Audio has downloads for vintage equipment models, but the one for the P1000 is a link that is not functioning (of course lol).
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • skipshot12
    “Power Filtering” (Shunyata, Niagra, Monster etc.), “Regeneration” (PS Audio) and what I consider the top of the line “Isolation” (Equitech) are different designs/nomenclature in providing cleaner power to your equipment.
    In Isolation/regeneration one is limited to the size of the transformer used.
    In PS Audio’s approach if one needs unlimited power, at least what the wall outlet can output, they have a strictly filtered outlet.
    Looking at the back of the P1000 the outlet at bottom rear is filtered power only, that outlet is restricted to what the wall outlet can provide, not the Toroidal used inside the unit.
  • Gardenstater
    VR3 wrote: »
    Just for the sake of discussion. Since W = VA x P.F. , an amplifier with max. 15 A draw from the outlet and a typical 0.58 power factor (that's what it is for my Onkyo A-8017 anyways) would be drawing 1,044 W which would exceed the max output of the P-1000 but only slightly. That would only be happening when the amp was putting out it's maximum rated continuous output and probably would never occur in actual use playing music.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • skipshot12
    Basically, what the P1000 is is a Class AB Transformer.
    Along with their P600, P1000, P1200 and the very rare P2000.
  • skipshot12
    Really is quite the exceptional piece of gear, not only can you adjust the voltage output but also the voltage frequency. And, it makes quite a surge suppressor impression.
    An informative read...
    https://6moons.com/audioreviews/psaudio2/p1000.html
    Not your ordinary power strip filter.
  • skipshot12
    VR3 wrote: »
    That's why you would have purchased the P1200...
    https://hometheaterhifi.com/volume_8_2/ps-audio-p1200-6-2001.html
    Higher power draw amps then go with the P2000, but beware that they were over 200 lbs.
    Or go with PS Audio's new approach to power regeneration and grab the P20.
    At 3600 watts of peak power it should power your Onkyo amp, at a cost of 10 grand.
  • skipshot12
    https://www.manualslib.com/manual/303074/Ps-Audio-Power-Plant-P1000.html#manual
    https://www.aspera-audio.com/pdf/manuals/P1200-manual1.pdf
    May have been prior to the P1000?
  • skipshot12
    Apologies on the thread take over, I'll go have some frosty beverages now.....
  • Gardenstater
    skipshot12 wrote: »
    First beer at 9:30 Mountain time tsk tsk ⌚🍺👌
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • invalid
    invalid Posts: 1,559
    Doesn't really seem like a lot, my 300 watt amplifier has 272,000 UF.
  • Gardenstater
    invalid wrote: »
    Perhaps not, but it is additive to what is in your amplifier. In your case it won't make a lot of difference. Circuit Breaker boxes are 0 uf though.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • skipshot12
    skipshot12 wrote: »
    Bahahaaaa, retirement has its perks big daddy.
  • skipshot12
    invalid wrote: »
    What amplifier do you have?
    I need to look inside my WOPL phase linear 700 and see what the power supply capacitance is. It is 500w per side.
