You’re doing it wrong…
1…3839414344…132
    mhardy6647 Posts: 35,561
    Ratchet?
    No? Close, though.
  • motorstereo
    motorstereo Posts: 2,427
    Ratchet; batch it; a smelly old ...........ahh nevermind banilla won't let it thru anyways.
    msg Posts: 10,650
    Toss in a can of AeroKroil
    for good measure to
    Kroil's great stuff for easing old fasteners. An old machinist recommended it to me once.
    For anyone who works on their own stuff, a light coat of anti-sieze compound on the threads of all the wheel lugs is the real preventive for lug nut issues. Good to put a little on the wheel to lug nut interface as well.
    I was just going to ask why you guys are all using breaker bars instead of the supplied tire changing tools, but then I just remembered that I use a long ratchet for wheel work. Definitely more convenient. 4" extension, as well.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    Also not mentioned but always proves useful is the excessive use of foul and profane language to the point that would make a sailor blush.
    Also works in getting them sammiches made in a more prompt and timely manner.
    Try it, you'll see the difference 👍
    msg Posts: 10,650
    msg wrote: »
    Dammit. Seize!
    context:
  • ken brydson
    ken brydson Posts: 9,100
  • ken brydson
  • mrbigbluelight
    We need a "Fabulous" button 🤔
    Ab Fab
    msg Posts: 10,650
    Outrageous program.
  • motorstereo
  • CottageChz
    CottageChz Posts: 424
    Wow, that float switch is incredible
  • motorstereo
    CottageChz wrote: »
    The fellow was also thinking safety as that appears to be a GFCI box.
  • OleBoot
    OleBoot Posts: 3,138
    CottageChz wrote: »
    I'm rather impressed, actually.
    treitz3 Posts: 20,357
    Damn.
    F1nut Posts: 52,407
    Yuck
  • daddyjt
    daddyjt Posts: 3,256
    ― Aleksandr Solzhenitsyn
    ^^^ I would totally do that. Or put a stub of pipe on that tee, get one of those caps, you know, and drill a hole in it, then glue in a piece of the small-diameter pipe with some PVC cement. The solution above is more elegant though.
  • daddyjt
    I have certainly utilized some creative PVC fitting combinations over the years… In a pinch you use what you have;-)
    Clipdat Posts: 13,104
    audioluvr Posts: 6,079
    Clipdat wrote: »
    That setup rocks! Those are some museum quality pieces!
    Then put them in a museum, instead of on the top of a pair of speakers.
  • Unknown
  • OleBoot
  • sucks2beme
    sucks2beme Posts: 5,703
    That guy better have an inner tube inside that tire.
  • CGTIII
    CGTIII Posts: 1,274
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
    sucks2beme wrote: »
    For what? The next mile and a half? If that...
