You’re doing it wrong…
There's a strap on/nuts joke in there somewhere.
He's going to break the rachel. With any luck, the strap will
Snap back and it will scratch the door. I would almost pay
To watch that.
"The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
sucks2beme wrote: »He's going to break the rachel. With any luck, the strap will
To watch that.
I don't think rachel will break, she's a tough girl.
President of Club Polk -
To watch that.
I bet he got the lug nut off with no damage. Put some tension on the ratchet and give it a good solid kick to finish it. Run what you brung if don't have what you need.
This is nothing compared to what a resourceful paving crew can do with limited tools when there's a flat or other issue on the company truck headed home after a long day. -
I keep a breaker bar and 19 mm socket in the "trunk".
Stuff does, indeed, happen.
I am still (relatively) strong.
OK, I have no idea how ratchet became Rachel. Best guess
Is the typed t didn't take and it auto corrected. So much for
Typing on small screens with thumbs.
I keep a 24" breaker bar and an impact socket in both cars.
Full size spares as well. I had a flat in the Mustang years ago
and found a can of goo and a mini compressor instead of
an idiot spare. Had to wait for a tow and to get a new tire
Installed for hours. I keep a jump box in the trunk as well.
Seems modern cars don't like jumper cables."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
A heads up to those that are always prepared. Far more important than the breaker bar-right sized socket and Aerokroil is to make sure the key or special socket to unlock the locking lug is with you.
sucks2beme wrote: »OK, I have no idea how ratchet became Rachel..
Perhaps with the help of WD40 and some duct tape? We shouldn’t judge..The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I would like to know more about how Rachel became ratchet.
RE: Rachels/Ratchets
I'm not touching that with a 10' pole. ,🤫Sal Palooza -
mrbigbluelight wrote: »Toss in a can of AeroKroil
for good measure to
In my part of the world, rust isn't much of an issue.
I did pull the goofy anti-theft lug nuts off on the wife's car.
But lately it seems like a bullet proof vest would be a good
idea for highway driving around here. Welcome to modern
America.
Ratchet?
No? Close, though.
Ratchet; batch it; a smelly old ...........ahh nevermind banilla won't let it thru anyways.
Kroil's great stuff for easing old fasteners. An old machinist recommended it to me once.mrbigbluelight wrote: »Toss in a can of AeroKroil
for good measure to
For anyone who works on their own stuff, a light coat of anti-sieze compound on the threads of all the wheel lugs is the real preventive for lug nut issues. Good to put a little on the wheel to lug nut interface as well.
I was just going to ask why you guys are all using breaker bars instead of the supplied tire changing tools, but then I just remembered that I use a long ratchet for wheel work. Definitely more convenient. 4" extension, as well.
I disabled signatures. -
Also not mentioned but always proves useful is the excessive use of foul and profane language to the point that would make a sailor blush.
Also works in getting them sammiches made in a more prompt and timely manner.
Try it, you'll see the difference 👍Sal Palooza -
mrbigbluelight wrote: »Also not mentioned but always proves useful is the excessive use of foul and profane language to the point that would make a sailor blush.
context:
Wow, that float switch is incredible
CottageChz wrote: »Wow, that float switch is incredible
The fellow was also thinking safety as that appears to be a GFCI box. -
I'm rather impressed, actually. -
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
Damn.
Tom~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
