You’re doing it wrong…
Wow, that float switch is incredible
CottageChz wrote: »Wow, that float switch is incredible
The fellow was also thinking safety as that appears to be a GFCI box. -
I'm rather impressed, actually. -
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
Damn.
Yuck
― Aleksandr Solzhenitsyn -
^^^ I would totally do that. Or put a stub of pipe on that tee, get one of those caps, you know, and drill a hole in it, then glue in a piece of the small-diameter pipe with some PVC cement. The solution above is more elegant though.
mhardy6647 wrote: »^^^ I would totally do that. Or put a stub of pipe on that tee, get one of those caps, you know, and drill a hole in it, then glue in a piece of the small-diameter pipe with some PVC cement. The solution above is more elegant though.
I have certainly utilized some creative PVC fitting combinations over the years… In a pinch you use what you have;-)“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
Then put them in a museum, instead of on the top of a pair of speakers.
Yea you need clay pots with plants on top to give them a glow ..after watering
That guy better have an inner tube inside that tire."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson
sucks2beme wrote: »That guy better have an inner tube inside that tire.
For what? The next mile and a half? If that...
For the cheap amusement of watching the guys at discount tire try to remove the tire
from the rim. They don't know how to deal with an inter tube. I saw this once. Those guys
are so used to no braining their work, their heads exploded. That tire didn't look much
better than the one pictured."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
That's like that meme someone posted recently about the guy who went to an auto parts store asking for some specific bulk fuel line, and the counter rep's brain suffered an unexpected reboot, requiring year, make and model to be able to function.I disabled signatures.
Deleted User wrote: »
That happened to me today. I went into NAPA and asked for a gallon jug of Mobil 1 5w40 turbo diesel truck oil.Gustard X26 Pro DAC
There is a better way to check for air leaks.....I guess this cat didn't get the memo...
Well Tom, like mentioned before…It’s effing hot…a dip in the pool to cool off2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Well, I am glad today's a slow news day.
That's about all I have to say.
^ Not anymore….
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Still buzzing the tower...
Can this year get any weirder?
That should be a thread…..
