The Dared SL 2000 modification thread
For what it's worth, I have some hum as well. It's very low, and is inaudible when the music is playing. However, between songs, if I'm close enough to the speakers then I can hear the hum. I'd love to solve it, but it hasn't been enough of a nuisance for me to rip apart my system looking for the cause.
Anyone else have hum with the sl2000a, and find a solution? Is it the unit, or other factors?
Also, the hum stays at a constant level, regardless of how low/high the Dared is set. -
Mine is almost silent. If I put my ear to the speaker I can hear a very slight, almost inaudible hiss. Maybe try some different cables. I'm using AVt2s throughout my rig. Tube dampers also if you're not already.
Yeah, I'll have to give different cables a shot. Already have Herbie's tube dampers on my tubes. Part of my problem might be that my amp has 32 db of gain, so the background noise will be a bit louder than amps with only 29 db of gain. I'll have to switch to one of my Adcoms to see if that helps. -
audio_alan wrote: »Yeah, I'll have to give different cables a shot. Already have Herbie's tube dampers on my tubes. Part of my problem might be that my amp has 32 db of gain, so the background noise will be a bit louder than amps with only 29 db of gain. I'll have to switch to one of my Adcoms to see if that helps.
The hum/noise I'm dealing with can be heard 15 ft. away from the speakers. I've tried everything except changing tubes, which I'll do as soon as finances get better. I've thought about sending mine in to see if something got loose during shipping. -
Hi mf, could you send me a another clear photo from the inside. Changing the caps, I interrupt a
small black wire (on the backside) and now not know where I have to resolder.
Thanks in advance,
tubettoHi, all. This thread was what got me to join the forum. Great stuff.
I'm wondering if someone could forward me a copy of the schematics. I've attached photos of the unit with the back off so it is clear which edition I've got.
Thanks in advance.
-Matt.
Attachment not found.Attachment not found. -
Hi all,
is there somebody who could help and send a photo from the inside (rear part) because I must find where the black wire was fixed. -
George or mfg,do either of you gents now have the schem?
Do you still have?
Can't find it Fred. I'll keep looking. If I can find the hard copy I can scan it and send it.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
As soon as I posted I couldn't find it, I FOUND it.
Send me an addy Fred, I will honor Joe at Dared and not post it for the general public.
George,
I know this is an old thread, but first do you still have the extra caps? Second I was thinking of making a 3/4"-1" riser for the bottom to give it some extra working room. Thoughts?
I haven't takin it apart to look inside but the pics look to be a little tight..
I came close to selling this unit a couple of times, as I hardly use it. But started thinking about this thread, Mod it? LOL!! -
I still have the Obligattos for sure--I'll take a peek and see if I have anymore of the teflon caps(input),,
You want em?JC approves....he told me so. (F-1 nut) -
Hey, Tubetto and FTGV- I'm writing to apologize for having not replied to your (2013) postings seeking schematics. I had neglected to subscribe to the thread, and just returned today and saw your messages.
It appears that George and H9 had come through for you, but I do have the schematics now should anyone still have a need.
-Matt-Matt -
Looking for help with my new Dared SL2000-A preamp mod. I went and bought 2- .22 Auricapxo for the input,
And went by the old build that said 4- 1.0 uf caps for the coupling.
In my Hew unit it does not have the 2 Square caps in back ,and 4 - side by side yellow caps.
Mine has 2- yellow square caps 7 blue round-oval shiny caps and maybe a black cap under the frame.
Could someone Pleaee help me .my unit is stuck in the shop waiting on help.Joe at dared sent my 2- older schematics thst donot apply
I am at finetunes1@hotmail.com. Any help would great be appreciated thank you,Paul. -
Hi, recently the left channel of my Dared SL -2000A became noisy, it sounds like deep frying. My tech friend can't seem to isolate the problem. I would appreciate it much if someone could tell me where to find spare boards or maybe used units for sale. Thanks very much.
Auction sites.
Try new tubes? -
Auction sites.
Try new tubes?
Hi, tried new tubes, still noisy. Nothing on ebay. Will call Mike of Deltronics for a spare board. Thanks for the comment. -
Auction sites.
Try new tubes?
Hi,
Need assistance, if anyone comes across a used Dared SL-2000a or a circuit board for sale please let me know, I will appreciate it much. Thanks. -
I’m going to pull this from the grave…
Does anyone have the schematic for the SL2000A?
I can’t find one online.
I emailed Dared, no response.
I also tried to get in touch with Deltronics, in Chicago as they were an authorized repair center for Dared in the past.
No response to email and no one seems to answer the phone.
My SL2000A developed a hiss and static in the left channel.
Thanks in advance! -
I couldn't find one in any of my searches, good luck.
Yeah, I was worried that was going to be the answer.
I'd run into a problem with uploading the file, but it now looks like it has posted properly. If not, let me know and I can try sending it to you another way.-Matt
Awesome!
Really helpful! -
Quick update, couldn't really figure it out on my own and I ended up hearing back from Deltronics.
Ended up sending it into them, they called about a week later that they found some poor capacitors.
Gave the okay to repair and I hope to get it back within a few weeks. -
Follow up, received back from Deltronics.
Absolutely not a quick process…
They had it for 3 full months.
Either way, it’s home and back up and running.
They did a full re-cap on it and it’s sounding better than ever!
I’ll run this for now, till I find my “forever” preamp!
