Post a picture... any picture
That '70's HOT!! pic above is Jane Seymour....she was a crush....still got it in her 70's
WTH is going on here?
It’s how a Tie fighter is born.
It’s going to grow up to be a majestic star fighter, that will get easily blown up by a X-Wing fighter…
― Aleksandr Solzhenitsyn -
Probably for heating up the housing to install new bearing races and seals. If you put the races and seals in the deep freezer they will slide right in.Gustard X26 Pro DAC
Jfc, look at her quads...
You know she squats a lot. Makes sense when you see those jumps she does.
I disabled signatures. -
Possibly attempting 'seasoning' (heat treating) the cast iron?
The pinion bearing races are easy to knock out with a drift punch, alternating side to side. Installing the differential bearing preload shims can be easier with a case spreader, though you can use steel shims and drive them in with a punch.
The factory uses a case spreader and typically used ground flat cast-iron shims to set ring gear backlash and bearing preload. Those cast shims can crack easily if you pound them in under tension. If you replace diff bearings, tolerance stack ups can make the OEM cast shims useless for preload and setting backlash.
Removable third members typically have screw adjusters for backlash/bearing preload.
The pictured diff housing uses a full-floating axle. On a full floater, a spindle is attached to the outer end of the axle housing. The wheel hub is mounted on this spindle and rides on tapered roller bearings. It is this assembly that carries the vehicle weight. A full-floating axle system is considerably stronger than an equivalently sized semi-floating system. Semi-float the axle rides on a bearing in diff housing and the wheel bolts directly to it.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Buick created the first car touchscreen all the way back in 1986. The technology was dropped because customers were complaining about taking their eyes off the road, and it wouldn’t been seen again for some time. (source: rarehistoricalphotos.com)
aprazer402 wrote: »
And touchscreens came back when drivers no longer cared if their eyes weren’t on the road.See my profile for list of gear. -
Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
B.A. Baracus's flashier brother's ride.mhardy6647 wrote: »
Its hidden compartments are full of stuff that is other than Kalashnikov. Brighter, happier stuff.
I was thinking a modern Cheech n Chong mobile2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
(ASR)
^^^^^ "statistically speaking, that statement is correct"2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
^^^ Tapped a few times.
