Post a picture... any picture
1…99599699810001001…1125
    txcoastal1 Posts: 13,520
    That '70's HOT!! pic above is Jane Seymour....she was a crush....still got it in her 70's
  • Upstatemax
    Upstatemax Posts: 2,865
    Toolfan66 wrote: »
    WTH is going on here?
    It’s how a Tie fighter is born.
    It’s going to grow up to be a majestic star fighter, that will get easily blown up by a X-Wing fighter…
  • Unknown
    edited December 2023
  • daddyjt
    daddyjt Posts: 3,263
    Toolfan66 wrote: »
    Vintage Boston
    ― Aleksandr Solzhenitsyn
    audioluvr Posts: 6,079
    Toolfan66 wrote: »
    Probably for heating up the housing to install new bearing races and seals. If you put the races and seals in the deep freezer they will slide right in.
    msg Posts: 10,650
    Toolfan66 wrote: »
    Nickelback?
    Creed?
    msg Posts: 10,650
    Toolfan66 wrote: »
    Cooking a pumpkin?
    msg Posts: 10,650
    Toolfan66 wrote: »
    Jfc, look at her quads...
    You know she squats a lot. Makes sense when you see those jumps she does.
    SCompRacer Posts: 9,396
    Toolfan66 wrote: »
    Possibly attempting 'seasoning' (heat treating) the cast iron?
    The pinion bearing races are easy to knock out with a drift punch, alternating side to side. Installing the differential bearing preload shims can be easier with a case spreader, though you can use steel shims and drive them in with a punch.
    The factory uses a case spreader and typically used ground flat cast-iron shims to set ring gear backlash and bearing preload. Those cast shims can crack easily if you pound them in under tension. If you replace diff bearings, tolerance stack ups can make the OEM cast shims useless for preload and setting backlash.
    Removable third members typically have screw adjusters for backlash/bearing preload.
    The pictured diff housing uses a full-floating axle. On a full floater, a spindle is attached to the outer end of the axle housing. The wheel hub is mounted on this spindle and rides on tapered roller bearings. It is this assembly that carries the vehicle weight. A full-floating axle system is considerably stronger than an equivalently sized semi-floating system. Semi-float the axle rides on a bearing in diff housing and the wheel bolts directly to it.
  • jdjohn
    jdjohn Posts: 3,443
    Toolfan66 wrote: »
    Rotisserie!!!
  • BlueBirdMusic
    Harry / Marietta GA
  • Willow
    Willow Posts: 11,364
    msg wrote: »
    Toolfan66 wrote: »
    Nickelback?
    Creed?
    Celine Dion and Justin Beebs
  • BlueBirdMusic
    Harry / Marietta GA
  • OleBoot
    OleBoot Posts: 3,138
    mhardy6647 Posts: 35,562
    Toolfan66 wrote: »
    Ummm...
  • aprazer402
    aprazer402 Posts: 3,463
    Buick created the first car touchscreen all the way back in 1986. The technology was dropped because customers were complaining about taking their eyes off the road, and it wouldn’t been seen again for some time. (source: rarehistoricalphotos.com)
  • TEAforONE
    TEAforONE Posts: 1,101
    aprazer402 wrote: »
    And touchscreens came back when drivers no longer cared if their eyes weren’t on the road.
  • Geoff4rfc
    Geoff4rfc Posts: 3,053
    Toolfan66 wrote: »
    LOL...dude, you are twisted....I love it
    Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
    msg Posts: 10,650
    Toolfan66 wrote: »
    Nice! Christmas light underwears!
    msg Posts: 10,650
    Toolfan66 wrote: »
    Ummm...
    B.A. Baracus's flashier brother's ride.
    Its hidden compartments are full of stuff that is other than Kalashnikov. Brighter, happier stuff.
    I was thinking a modern Cheech n Chong mobile
    Viking64 Posts: 7,813
    ^^^^^ "statistically speaking, that statement is correct"
    F1nut Posts: 52,406
    OleBoot wrote: »
    Geoff4rfc wrote: »
    Toolfan66 wrote: »
    The nut hole looks worn/stripped out. I mean, that is a big hole...
  • aprazer402
    ^^^ Tapped a few times.
  • bcwsrt
    bcwsrt Posts: 2,691
    Brian
  • OleBoot
