Post a picture... any picture
1…10111012101410161017…1153
    Tony M Posts: 11,999
    edited December 2023
    Toolfan66 wrote: »
    I missed a pr. on Craig's list or Facebook marketplace. about a year or less ago. It had just been posted 2 hrs. (I think) before I saw the ad for very little money $125 to $250 max I think.
    I responded I wanted to buy them. They responded, sorry, they're sold. :s
    I think I posted on here about that miss. I was that (-) close! :D
  • skipshot12
    skipshot12 Posts: 2,141
    Toolfan66 wrote: »
    Don’t remember if I posted this..
    Why?
    skipshot12 wrote: »
    Toolfan66 wrote: »
    Why?
    To win competition trophies and cash maybe? :|
    mhardy6647 Posts: 35,551
    Hifihaven
    Toolfan66 Posts: 18,412
    Viking64 Posts: 7,803
  • odcics2
    odcics2 Posts: 396
    Viking64 wrote: »
    Rudolph! You have so much to live for. Don't do it!
    Meanwhile, elsewhere up in the frozen white north...
    txcoastal1 Posts: 13,520
    That '70's HOT!! pic above is Jane Seymour....she was a crush....still got it in her 70's
    WTH is going on here?
  • Upstatemax
    Upstatemax Posts: 2,862
    Toolfan66 wrote: »
    It’s how a Tie fighter is born.
    It’s going to grow up to be a majestic star fighter, that will get easily blown up by a X-Wing fighter…
    pitdogg2 Posts: 27,877
    Toolfan66 wrote: »
    She really makes those shoes look HOT!!
  • daddyjt
    daddyjt Posts: 3,244
    Toolfan66 wrote: »
    Vintage Boston
    ― Aleksandr Solzhenitsyn
    audioluvr Posts: 6,065
    Toolfan66 wrote: »
    Probably for heating up the housing to install new bearing races and seals. If you put the races and seals in the deep freezer they will slide right in.
    msg Posts: 10,636
    Toolfan66 wrote: »
    Nickelback?
    Creed?
    msg Posts: 10,636
    Toolfan66 wrote: »
    Cooking a pumpkin?
    msg Posts: 10,636
    Toolfan66 wrote: »
    Jfc, look at her quads...
    You know she squats a lot. Makes sense when you see those jumps she does.
    SCompRacer Posts: 9,380
    Toolfan66 wrote: »
    Possibly attempting 'seasoning' (heat treating) the cast iron?
    The pinion bearing races are easy to knock out with a drift punch, alternating side to side. Installing the differential bearing preload shims can be easier with a case spreader, though you can use steel shims and drive them in with a punch.
    The factory uses a case spreader and typically used ground flat cast-iron shims to set ring gear backlash and bearing preload. Those cast shims can crack easily if you pound them in under tension. If you replace diff bearings, tolerance stack ups can make the OEM cast shims useless for preload and setting backlash.
    Removable third members typically have screw adjusters for backlash/bearing preload.
    The pictured diff housing uses a full-floating axle. On a full floater, a spindle is attached to the outer end of the axle housing. The wheel hub is mounted on this spindle and rides on tapered roller bearings. It is this assembly that carries the vehicle weight. A full-floating axle system is considerably stronger than an equivalently sized semi-floating system. Semi-float the axle rides on a bearing in diff housing and the wheel bolts directly to it.
  • jdjohn
    jdjohn Posts: 3,438
    Toolfan66 wrote: »
    Rotisserie!!!
