The Grande Utopia Project
Piano in the dark is lovely. Sounds great playing thru the desktop rig here too. Great work in progress there as always.Don't take experimental gene therapies from known eugenicists.
Thank you good sir! I appreciate it. One day I will do the whole speaker haha- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Could you "guestimate" what sound (Db level) that was recorded at?
Please advise and thanks.
The last one?
Vocals were probably 95db peaks, possibly louder- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Part of the next stage has arrived! 5 of these per speaker
What performance gain do you get with the bic lighters?Gustard X26 Pro DAC
Really adds the fire on the high notes- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
What are you lighting with that lighter?
Those are monsters, too bad they don't make 200v versions
OOOOH FLAMES HONEY YAAAAASSS QUEEN YAAAAASSS!!! -
I'm kind of disappointed @pitdogg2 didn't reference something with a high THC content. Always makes audio more epic.Gustard X26 Pro DAC
So in my resistor shoot out, I have tried all three and have reached a conclusion.
Top choice, path audio. This resistor just has it all, soundstage, bloom, detail, musicality, it is just a great sounding resistor.
Second choice, mundorf 30 watt ultra. This is the new hifi sound. Super detailed, super analytical... When it's on... Man it's on. Poor recording? Definitely won't bring out the musicality you may otherwise experience. I really enjoyed this sound for a few weeks but after a while it started to develop a hard characteristic as I don't just listen to Dianna Krall every track. haha. Lesser quality recordings it really holds nothing back.
Duelund cast, not gonna lie. I was incredibly disappointed in these in my system with my speakers. I have used these before with much success but I just didn't experience that in my system, pointing to system synergy. Very 2 dimensional, veiled and just did not compete with the other resistors in any category for my setup.
All resistor values were confirmed before and after installation and during change outs.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thank goodness. I was beginning to wonder if the Mezzo Utopia crossovers you did for me were going to need some updating, but luckily, they have Path resistors"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
The mundorfs are very, VERY, good but they simply don't provide the musicality of the paths... The paths sound very good on any music I throw at it where as the mundorfs craved the perfect recording. But like I said, man when it's on, it's on like donkey kong. Super fast detailed- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Did you ground the Path?
I did not, I removed the ground wire since I wanted the tweeter and midrange network circuit separate. Using the ground wire would have joined the circuits thru the heat sink
Edit, I did install all resistors on the heat sink using a thermal compound- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'd love a set of those Path resistors for my 2.3tl's !! Bummer they do not come in my ohm value.
I thought you did the group buy a while back? They require quantity 20 for special order- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
No I had just finished my boards and spent my wad. I missed that.
I do know someone here who is sitting on some....😁😉 -
Yeah Jesse may install them in the year 2030- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Do vampires recognize a human timekeeping scale like a calendar?"Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
I mean.. When you live forever?? 🚀😁- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Guess it's time for my yearly update on how I'm done yet have changed everything!
Optical in from road
3 x Dedicated 20 amp circuits
Provider provided ont
>Audiolund true silver Ethernet Cat8 and audiolund reference DC power cable
Netgear MK83 Tri Band Mesh router hub
> Netagear devices powered by Teradak W200 linear power supply with Audiolund Reference PC
Netgear s8000 switch
Network acoustics muon filter and cable
Mini dsp sdh
>s booster linear power supply
>Audiolund Signature PC
>Audiolund Xtreme 1.5M Digital Cable with BNC ends
Abbas 2.4se dac, 6sn7
>stock tubes
> Audiolund Xtreme RCA Cables, 1m
Mark levinson 335, fully rebuilt
>Audiolund Xtreme Power Cable, High Powered Version
> Audiolund Xtreme 6 wire version speaker cables with Furutech ends
1998 Jm Lab Grande Utopia with partially modded crossoversSo funny to return back to this thread and see this comment from April and how different the system is now... I am very close to doing everything I can think of sans replacing stuff inside the components... lol
Setup now...
RG11 belden, 14 awg OFC copper from outdoor cable box to modem direct wired
Netgear CM2000 modem
>Audiolund Reference Ethernet Cat8 and DC power cable
Lumin U1
>Lumin X1 Power supply, stock umbilical
ANK PRO5.1 DAC
>Emission Labs Mesh 5u4g rectifier tube, Tung Sol 12au7, JJ Ecc99
Musical Fidelity KW750
>Revelation Audio umbilical cables
>1998 Jm Lab Grande Utopia with partially modded crossoversI believe the rig is where it needs to be.
Lumin U1 with Kenneth Lau umbilical using LEEDH processing volume
Wireworld Starlight BNC
ANK DAC 5.1 Pro with Quad C Cores
Duelund Dca 16 awg ICs
Musical fidelity kw750 amplifier with revelation audio umbilical cables
Duelund dca 12 speaker cabling
JM Lab Grande Utopia with the band aid mod
Duelund Dca 12 600v power cabling thru out
All network components have linear power supplies, supra ethernet. Nighthawk mesh system and modem.
Surprised to see Silver in the mix, Trey. Kudos.
I've found it to work well in the source part of the chain but once it leaves the amplifier I like to keep silver away from the titanium domes. The Focals really like tin plated copper- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Same here (in the signal chain). I never in a million years would have thought you would have tried it though. Anywhere in the system. I kinda reared my head back when I read that, TBT.
Of course, you know I use silver elsewhere but placed in strategic positions and mixed with different metalurgies. As you already know, silver can be a double edged sword, if you will. It can make or break a system.
Oh for sure, I use to run all silver many moons ago... Solid silver dh labs interconnects and silver plated copper speaker cables... But they just don't mix with the focals
Now the ethernet cables on the other hand edged out a little more detailing and clarity over the tin plated copper in the system, not night and day but definitely a shimmer, if that makes sense.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
