The Grande Utopia Project
    VR3 Posts: 28,108
    xschop Posts: 4,726
    Piano in the dark is lovely. Sounds great playing thru the desktop rig here too. Great work in progress there as always.
    VR3 Posts: 28,108
    Thank you good sir! I appreciate it. One day I will do the whole speaker haha
    treitz3 Posts: 18,405
    Could you "guestimate" what sound (Db level) that was recorded at?
    Please advise and thanks.
    VR3 Posts: 28,108
    edited December 2023
    The last one?
    Vocals were probably 95db peaks, possibly louder
    VR3 Posts: 28,108
    Part of the next stage has arrived! 5 of these per speaker
    audioluvr Posts: 5,457
    VR3 wrote: »
    What performance gain do you get with the bic lighters?
    VR3 Posts: 28,108
    Really adds the fire on the high notes
    Clipdat Posts: 12,623
    What are you lighting with that lighter?
    pitdogg2 Posts: 24,631
    Those are monsters, too bad they don't make 200v versions
  • honestaquarian
    audioluvr wrote: »
    VR3 wrote: »
    OOOOH FLAMES HONEY YAAAAASSS QUEEN YAAAAASSS!!! >:):p
    I'm kind of disappointed @pitdogg2 didn't reference something with a high THC content. Always makes audio more epic.
    VR3 Posts: 28,108
    So in my resistor shoot out, I have tried all three and have reached a conclusion.
    Top choice, path audio. This resistor just has it all, soundstage, bloom, detail, musicality, it is just a great sounding resistor.
    Second choice, mundorf 30 watt ultra. This is the new hifi sound. Super detailed, super analytical... When it's on... Man it's on. Poor recording? Definitely won't bring out the musicality you may otherwise experience. I really enjoyed this sound for a few weeks but after a while it started to develop a hard characteristic as I don't just listen to Dianna Krall every track. haha. Lesser quality recordings it really holds nothing back.
    Duelund cast, not gonna lie. I was incredibly disappointed in these in my system with my speakers. I have used these before with much success but I just didn't experience that in my system, pointing to system synergy. Very 2 dimensional, veiled and just did not compete with the other resistors in any category for my setup.
    All resistor values were confirmed before and after installation and during change outs.
    VR3 Posts: 28,108
    Same track as above with path audio
    https://youtu.be/xw7dqhFOVnw?si=8zR0bMb2Llo_nFGX
  • jdjohn
    jdjohn Posts: 3,011
    Thank goodness. I was beginning to wonder if the Mezzo Utopia crossovers you did for me were going to need some updating, but luckily, they have Path resistors B)
    VR3 Posts: 28,108
    The mundorfs are very, VERY, good but they simply don't provide the musicality of the paths... The paths sound very good on any music I throw at it where as the mundorfs craved the perfect recording. But like I said, man when it's on, it's on like donkey kong. Super fast detailed
    Did you ground the Path?
    VR3 Posts: 28,108
    I did not, I removed the ground wire since I wanted the tweeter and midrange network circuit separate. Using the ground wire would have joined the circuits thru the heat sink
    Edit, I did install all resistors on the heat sink using a thermal compound
    I'd love a set of those Path resistors for my 2.3tl's !! Bummer they do not come in my ohm value.
    VR3 Posts: 28,108
    I thought you did the group buy a while back? They require quantity 20 for special order
    VR3 wrote: »
    No I had just finished my boards and spent my wad. I missed that.
    I do know someone here who is sitting on some....😁😉
    VR3 Posts: 28,108
    Yeah Jesse may install them in the year 2030
  • ZLTFUL
    ZLTFUL Posts: 5,640
    VR3 wrote: »
    Do vampires recognize a human timekeeping scale like a calendar?
    VR3 Posts: 28,108
    I mean.. When you live forever?? 🚀😁
    VR3 Posts: 28,108
    Guess it's time for my yearly update on how I'm done yet have changed everything!
    Optical in from road
    3 x Dedicated 20 amp circuits
    Provider provided ont
    >Audiolund true silver Ethernet Cat8 and audiolund reference DC power cable
    Netgear MK83 Tri Band Mesh router hub
    > Netagear devices powered by Teradak W200 linear power supply with Audiolund Reference PC
    Netgear s8000 switch
    Network acoustics muon filter and cable
    Mini dsp sdh
    >s booster linear power supply
    >Audiolund Signature PC
    >Audiolund Xtreme 1.5M Digital Cable with BNC ends
    Abbas 2.4se dac, 6sn7
    >stock tubes
    > Audiolund Xtreme RCA Cables, 1m
    Mark levinson 335, fully rebuilt
    >Audiolund Xtreme Power Cable, High Powered Version
    > Audiolund Xtreme 6 wire version speaker cables with Furutech ends
    1998 Jm Lab Grande Utopia with partially modded crossovers
    VR3 wrote: »
    So funny to return back to this thread and see this comment from April and how different the system is now... I am very close to doing everything I can think of sans replacing stuff inside the components... lol
    Setup now...
    RG11 belden, 14 awg OFC copper from outdoor cable box to modem direct wired
    Netgear CM2000 modem
    >Audiolund Reference Ethernet Cat8 and DC power cable
    Lumin U1
    >Lumin X1 Power supply, stock umbilical
    ANK PRO5.1 DAC
    >Emission Labs Mesh 5u4g rectifier tube, Tung Sol 12au7, JJ Ecc99
    Musical Fidelity KW750
    >Revelation Audio umbilical cables
    VR3 wrote: »
    I believe the rig is where it needs to be.
    Lumin U1 with Kenneth Lau umbilical using LEEDH processing volume
    Wireworld Starlight BNC
    ANK DAC 5.1 Pro with Quad C Cores
    Duelund Dca 16 awg ICs
    Musical fidelity kw750 amplifier with revelation audio umbilical cables
    Duelund dca 12 speaker cabling
    JM Lab Grande Utopia with the band aid mod
    Duelund Dca 12 600v power cabling thru out
    All network components have linear power supplies, supra ethernet. Nighthawk mesh system and modem.
    Surprised to see Silver in the mix, Trey. Kudos.
    VR3 Posts: 28,108
    I've found it to work well in the source part of the chain but once it leaves the amplifier I like to keep silver away from the titanium domes. The Focals really like tin plated copper
    Same here (in the signal chain). I never in a million years would have thought you would have tried it though. Anywhere in the system. I kinda reared my head back when I read that, TBT.
    Of course, you know I use silver elsewhere but placed in strategic positions and mixed with different metalurgies. As you already know, silver can be a double edged sword, if you will. It can make or break a system.
    VR3 Posts: 28,108
    Oh for sure, I use to run all silver many moons ago... Solid silver dh labs interconnects and silver plated copper speaker cables... But they just don't mix with the focals
    Now the ethernet cables on the other hand edged out a little more detailing and clarity over the tin plated copper in the system, not night and day but definitely a shimmer, if that makes sense.
